Lenovo ThinkPad X1 Yoga Intel Core i7-8565U 16GB 512GB SSD 14" Windows 10 Professional 64-bit
Quicklinx: FDGYWS00 Mfr#: 20QF00ADUK
Display Size: 14in
Processor Model: I7-8565U
Operating System: Windows 10 Pro 64-bit Edition
Installed Memory: 16GB
Hard Drive Capacity: 512GB
  • Core i7
  • IEEE 802.11n
£1,528.93 ex VAT
£1,834.71 inc VAT
Thinner. Lighter. More secure. The ThinkPad X1 Yoga Gen 4 features the renowned 360-degree hinge to accommodate your style. This 14" 2-in-1 laptop features a built-in suite of ThinkShield security features to protect all your critical data. And with the choice of a 4K display with Dolby Vision and Dolby Atmos Speaker System, you can take your creativity - and your entertainment - to new levels.
  • Raw power, super-speed
    Powered by an Intel Core processor and robust memory, the X1 Yoga Gen 4 packs a big punch. The PCIe solid-state drive (SSD) delivers speedy performance sure to delight with its responsiveness.
  • Unlimited creativity
    The X1 Yoga Gen 4 includes a rechargeable ThinkPad Pen Pro. Sketch. Sign documents. Take notes. Even color! Never worry about running out of ink or needing batteries, as it charges while it's stored in your system. Plus, with a garaged slot, you won't need to worry about misplacing or leaving it behind. Go ahead and create - there are no limits to where your imagination can take you.
  • Surround sound
    The X1 Yoga Gen 4 laptop includes surround-sound with the Dolby Atmos Speaker System. Two up-firing speakers alongside the keyboard combine with two down-firing woofers on the bottom of the machine. The result? Enhanced audio that seemingly flows all around you. What's more, four 360-degree microphones cancel unwanted noise when you're on calls, and pick up your voice from across the room - so you can use voice activation to wake your system, play music, and more.
  • Built for life's extremes
    Like all ThinkPad laptops, the X1 Yoga Gen 4 is tested against 12 military-grade requirements and more than 200 quality checks to ensure it runs in extreme conditions. From the Arctic wilderness to desert dust storms, from zero gravity to spills and drops, you can trust this laptop to handle whatever life throws your way.
  • Lenovo has got your back - and your front
    Keep your business data - and your privacy - safe with the X1 Yoga Gen 4 laptop's comprehensive suite of ThinkShield security features. Its discrete Trusted Platform Module (dTPM) encrypts data and ThinkShutter, a physical camera cover, blocks the lens to ensure that you're only seen when you want to be.
Lenovo ThinkPad X1 Yoga (4th Gen) - 14" - Core i7 8565U - 16 GB RAM - 512 GB SSD - UK
Notebook - flip design
Operating System
Win 10 Pro 64-bit - English
Intel Core i7 (8th Gen) 8565U / 1.8 GHz (4.6 GHz) / 8 MB Cache
16 GB LPDDR3 (provided memory is soldered)
Storage
512 GB SSD TCG Opal Encryption 2, NVMe
Optical Drive
No optical drive
Display
14" LED backlight touchscreen 3840 x 2160 / Ultra HD 4K
Graphics
Intel UHD Graphics 620
Input Device
Digitizer, TrackPoint, digital pen, UltraNav
Keyboard
Keyboard Backlight
Integrated Webcam
802.11a/b/g/n/ac, NFC, Bluetooth 5.0, Gigabit Ethernet
Wireless Broadband (WWAN)
4G
Up to 18.1 hours
3-axis gyro sensor, 3-axis accelerometer
Dockable
Security
Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader
Iron grey
32.3 cm x 21.8 cm x 1.55 cm
1.36 kg
Manufacturer Selling Program
TopSeller
Environmental Standards
ENERGY STAR Qualified
SAR
1.571 W/kg (body), 1.571 W/kg (limb)
Limited warranty - 3 years - on-site , Limited warranty - battery - 1 year
Operating System
Windows 10 Pro 64-bit Edition - English
Processor / Chipset
CPU
Max Turbo Speed
4.6 GHz
Number of Cores
Quad-Core
Cache
8 MB
64-bit Computing
Integrated memory controller
RAM
16 GB (provided memory is soldered)
LPDDR3 SDRAM
Speed
2133 MHz
Rated Speed
2133 MHz
Storage
Main Storage
512 GB SSD - (M.2 2280) PCIe - TCG Opal Encryption 2, NVM Express (NVMe)
Display
14" - IPS
LCD Backlight Technology
LED backlight
Touchscreen
Yes (10-point multi-touch)
Resolution
3840 x 2160 (Ultra HD 4K)
Widescreen
Image Aspect Ratio
16:9
Image Brightness
500 cd/m²
Glossy, anti-reflective, 90% colour gamut, anti-smudge, Dolby Vision, HDR 400 compatible
Audio & Video
Graphics Processor
Camera
Yes - 720p
Camera Features
IR camera, ThinkShutter camera privacy
Sound
Stereo speakers, quad array microphone
Codec
Realtek ALC1012L
High Definition Audio, Dolby Atmos
Input
Keyboard, digitizer, TrackPoint, digital pen, UltraNav
Keyboard Backlight
Keyboard Layout
Spill-resistant, multi-touch touchpad
Communications
Wireless
Wireless Controller
Intel Wireless-AC 9560 - M.2 Card
Network Interface
Gigabit Ethernet
Ethernet Controller
Intel I219-V
Generation
4G
LTE Advanced
Controller
FIBOCOM L850-GL - M.2 Card
Navigation
Receiver
GPS
Lithium Ion
51 Wh
Run Time
Up to 18.1 hours
AC Adapter
Input
Output
65 Watt
Connections & Expansion
Slots
1 x Nano-SIM card (1 free)
USB 3.1 Gen 1 , USB 3.1 Gen 1 (Always On) , 2 x USB-C 3.1 Gen 2/Thunderbolt 3/DisplayPort (Power Delivery) , HDMI , Lenovo Ethernet extension connector , Headphone/microphone combo jack , LAN (on supplied cable) , Dock
Iron grey
Case Material
Aluminum, magnesium alloy
Integrated Options
Dockable
Security
Administrator password, hard drive password, power-on password, MIL-STD-810G tested
Theft/Intrusion Protection
Security Slot Type
Kensington mini security slot
ThinkPad Pen Pro, USB-C power adapter, ThinkPad Ethernet Extension Cable Gen 2
RoHS
SAR Value
Localization
TopSeller
1.36 kg
ENERGY STAR Certified
Essential Accessories (1)
Get more from your purchase from one of our essential accessories
FDGY Lenovo Microsaver Security Cable Lock In Stock £34.29
Other bundles (1)
FDGY Lenovo Optical 3-button W/Mouse USB In Stock £13.83
Display Size: 14in
Optical Storage: None
Graphics: Intel UHD Graphics 620
Hard Drive Type: SSD
Touchscreen: Yes
Type: Laptop
Brand: Lenovo
Price Range Ex VAT: 1500+
