Lenovo ThinkPad X1 Yoga Intel Core i5-8265U 16GB 256GB SSD 14" Windows 10 Professional 64-bit
Quicklinx: FDGWWS00 Mfr#: 20QF00AFUK
  • Core i5
  • IEEE 802.11n
Thinner. Lighter. More secure. The ThinkPad X1 Yoga Gen 4 features the renowned 360-degree hinge to accommodate your style. This 14" 2-in-1 laptop features a built-in suite of ThinkShield security features to protect all your critical data. And with the choice of a 4K display with Dolby Vision and Dolby Atmos Speaker System, you can take your creativity - and your entertainment - to new levels.
  • Leave your power cord behind
    At 17% smaller than its predecessor, the X1 Yoga Gen 4 features a lightweight aluminum chassis. This 2-in-1 weighs only 2.99lb/1.35kg. With a battery life of up to 18 hours, it begs to accompany you everywhere. And when you do need more juice, Rapid Charge boosts your battery up to 80% in just 60 minutes-giving you 14.4 more hours unplugged.
  • Raw power, super-speed
    Powered by 8th Gen Intel Core processors and robust memory, the X1 Yoga Gen 4 packs a big punch. The PCIe solid-state drive (SSD) delivers speedy performance sure to delight with its responsiveness.
  • Unlimited creativity
    The X1 Yoga Gen 4 includes a rechargeable ThinkPad Pen Pro. Sketch. Sign documents. Take notes. Even color! Never worry about running out of ink or needing batteries, as it charges while it's stored in your system. Plus, with a garaged slot, you won't need to worry about misplacing or leaving it behind. Go ahead and create-there are no limits to where your imagination can take you.
  • Like a cinema in your lap
    With the optional 4K High Dynamic Range (HDR) display, you'll enjoy life-like accuracy. Add Dolby Vision into the mix, and you'll get vibrant visuals where colors pop, contrast is expanded, brightness increases, and details are much more refined. So whether you're watching a video, Skyping across the world, or sketching, the X1 Yoga Gen 4 delivers a stunning experience. Or choose from several displays, including an FHD panel with PrivacyGuard if you're more concerned with screen security.
  • Surround sound
    The X1 Yoga Gen 4 laptop includes surround-sound with the Dolby Atmos Speaker System. Two up-firing speakers alongside the keyboard combine with two down-firing woofers on the bottom of the machine. The result? Enhanced audio that seemingly flows all around you. What's more, four 360-degree microphones cancel unwanted noise when you're on calls, and pick up your voice from across the room-so you can use voice activation to wake your system, play music, and more.
  • Built for life's extremes
    Like all ThinkPad laptops, the X1 Yoga Gen 4 is tested against 12 military-grade requirements and more than 200 quality checks to ensure it runs in extreme conditions. From the Arctic wilderness to desert dust storms, from zero gravity to spills and drops, you can trust this laptop to handle whatever life throws your way.
  • Well-connected
    When you're out and about, the X1 Yoga Gen 4 2-in-1 laptop can keep you online even when there's no WiFi. Choose the optional LTE-A card and the WWAN technology lets your laptop function like a smartphone-where there's cellular service you can always jump online. And you can trust that your connection is secure.
  • We've got your back-and your front
    Keep your business data-and your privacy-safe with the X1 Yoga Gen 4 laptop's comprehensive suite of ThinkShield security features. Its discrete Trusted Platform Module (dTPM) encrypts data and works in conjunction with Windows 10 security. ThinkShutter, a physical camera cover, blocks the lens to ensure that you're only seen when you want to be. And the fingerprint reader uses biometrics to log you in with a simple touch.
  • For your eyes only
    As part of ThinkShield security, we offer a combination of hardware and software that work together to ensure what's on your display is for your eyes only. PrivacyGuard is an electronic privacy filter built into your system that decreases the angle of vision on your display, such that only your eyes, when facing head-on, can see content. All others see a darkened screen. PrivacyAlert is an integrated software that works with the IR camera to ensure that if others look over your shoulder, then a popup notifies you of the potential threat.
Lenovo ThinkPad X1 Yoga (4th Gen) - 14" - Intel Core i5 - 8265U - 16 GB RAM - 256 GB SSD - 4G LTE-A - UK
Notebook - flip design
Operating System
Win 10 Pro 64-bit - English
Intel Core i5 (8th Gen) - 8265U / 1.6 GHz (3.9 GHz) / 6 MB Cache
16 GB LPDDR3 (provided memory is soldered)
Storage
256 GB SSD - TCG Opal Encryption 2, NVMe
Display
14" LED backlight touchscreen 2560 x 1440 / WQHD
Graphics
Intel UHD Graphics
Input Device
Digitizer, TrackPoint, digital pen, UltraNav
Keyboard
Keyboard Backlight
Integrated Webcam
802.11a/b/g/n/ac, NFC, Bluetooth 5.0, Gigabit Ethernet
Wireless Broadband (WWAN)
4G LTE Advanced
Up to 18.1 hours
3-axis gyro sensor, 3-axis accelerometer
Dockable
Security
Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader
Iron grey
32.3 cm x 21.8 cm x 1.55 cm
1.36 kg
Manufacturer Selling Program
TopSeller
Environmental Standards
ENERGY STAR Qualified
SAR
1.571 W/kg (body), 1.571 W/kg (limb)
Limited warranty - 3 years - on-site , Limited warranty - battery - 1 year
Operating System
Windows 10 Pro 64-bit Edition - English
Processor / Chipset
CPU
Intel Core i5 (8th Gen) 8265U / 1.6 GHz
Max Turbo Speed
3.9 GHz
Number of Cores
Quad-Core
Cache
6 MB
64-bit Computing
Integrated memory controller
RAM
16 GB (provided memory is soldered)
LPDDR3 SDRAM
Speed
2133 MHz
Rated Speed
2133 MHz
Storage
Main Storage
256 GB SSD M.2 2280 PCIe - TCG Opal Encryption 2, NVM Express (NVMe)
Display
14" - IPS
LCD Backlight Technology
LED backlight
Touchscreen
Yes (10-point multi-touch)
Resolution
2560 x 1440 (WQHD)
Widescreen
Image Aspect Ratio
16:9
Image Brightness
300 cd/m²
Colour Gamut
72%
Glossy, anti-reflective, anti-smudge
Audio & Video
Graphics Processor
Intel UHD Graphics
Camera
Yes - 720p
Camera Features
IR camera, ThinkShutter camera privacy
Sound
Stereo speakers, quad array microphone
Codec
Realtek ALC1012L
High Definition Audio, Dolby Atmos
Input
Keyboard, digitizer, TrackPoint, digital pen, UltraNav
Keyboard Backlight
Keyboard Layout
Spill-resistant, multi-touch touchpad
Communications
Wireless
Wireless Controller
Intel Wireless-AC 9560 - M.2 Card
Network Interface
Gigabit Ethernet
Ethernet Controller
Intel I219-V
Generation
4G
LTE Advanced
Controller
FIBOCOM L850-GL - M.2 Card
Navigation
Receiver
GPS
Lithium Ion
51 Wh
Run Time
Up to 18.1 hours
AC Adapter
Input
Output
65 Watt
Connections & Expansion
Slots
1 x Nano-SIM card (1 free)
USB 3.1 Gen 1 , USB 3.1 Gen 1 (Always On) , 2 x USB-C 3.1 Gen 2 (supports Thunderbolt 3, DisplayPort Alt Mode) (Power Delivery) , HDMI , Lenovo Ethernet extension connector , Headphone/microphone combo jack , LAN (on supplied cable) , Dock
Iron grey
Case Material
Aluminum, magnesium alloy
Integrated Options
Dockable
Security
Administrator password, hard drive password, power-on password, MIL-STD-810G tested
Theft/Intrusion Protection
Security Slot Type
Kensington mini security slot
ThinkPad Pen Pro, USB-C power adapter, ThinkPad Ethernet Extension Cable Gen 2
RoHS
SAR Value
Localization
TopSeller
1.36 kg
Sustainability Information
ENERGY STAR Certified
Essential Accessories (6)
Get more from your purchase from one of our essential accessories
FDGW Lenovo 3M 14.0W Privacy Filter In Stock £37.84
FDGW Lenovo 45W Standard AC Adapter (USB Type-C) Power Adapter In Stock £26.01
FDGW Lenovo 65W Standard AC Adapter USB-C In Stock £29.56
FDGW Lenovo USB-C 65W AC Adapter AC 100-240 V 65Watt for ThinkPad A275 In Stock £29.56
FDGW Lenovo ThinkPad Hybrid USB-C with USB-A Dock - Do In Stock £194.89
FDGW Kensington Security Cable Lock In Stock £23.65
Other bundles (14)
FDGW Lenovo ThinkPad USB 3.0 Secure HDD-500GB In Stock £143.11
FDGW Lenovo HDMI to VGA Monitor Adapter In Stock £23.20
FDGW Lenovo USB3.0 To VGA/HDMI Adapter In Stock £63.85
FDGW Lenovo 2m HDMI Cable In Stock £17.02
FDGW Lenovo Essential Wireless Keyboard and Mouse Combo - UK English 166 In Stock £41.29
FDGW Lenovo Professional Wireless Keyboard In Stock £53.21
FDGW Lenovo ThinkPad Ethernet Extension Adapter Gen 2 In Stock £25.51
FDGW Lenovo ThinkPad USB3.0 to Ethernet Adapter In Stock £16.07
FDGW Lenovo Essential Wired Keyboard and Mouse Combo - UK English In Stock £26.08
FDGW Lenovo ThinkVision M14 14" 1920x1080 6ms USB-C IPS LED Monitor In Stock £258.14
FDGW Lenovo ThinkVision T24d 24" 1920x1080 VGA HDMI DisplayPort IPS LED Monitor In Stock £201.00
FDGW Lenovo ThinkVision T27p-10 27" 3840x2160 HDMI DisplayPort USB-C IPS LED Monitor In Stock £454.54
FDGW Lenovo ThinkVision P27h-20 27" 2560x1440 6ms HDMI DisplayPort IPS LED Monitor In Stock £336.70
FDGW Lenovo ThinkVision T27q-20 27" 2560x1440 4ms HDMI DisplayPort IPS LED Monitor In Stock £314.26
