Thinner. Lighter. More secure. The ThinkPad X1 Yoga Gen 4 features the renowned 360-degree hinge to accommodate your style. This 14" 2-in-1 laptop features a built-in suite of ThinkShield security features to protect all your critical data. And with the choice of a 4K display with Dolby Vision and Dolby Atmos Speaker System, you can take your creativity - and your entertainment - to new levels.
Raw power, super-speed
Powered by an Intel Core processor and robust memory, the X1 Yoga Gen 4 packs a big punch. The PCIe solid-state drive (SSD) delivers speedy performance sure to delight with its responsiveness. -
Unlimited creativity
The X1 Yoga Gen 4 includes a rechargeable ThinkPad Pen Pro. Sketch. Sign documents. Take notes. Even color! Never worry about running out of ink or needing batteries, as it charges while it's stored in your system. Plus, with a garaged slot, you won't need to worry about misplacing or leaving it behind. Go ahead and create - there are no limits to where your imagination can take you. -
Surround sound
The X1 Yoga Gen 4 laptop includes surround-sound with the Dolby Atmos Speaker System. Two up-firing speakers alongside the keyboard combine with two down-firing woofers on the bottom of the machine. The result? Enhanced audio that seemingly flows all around you. What's more, four 360-degree microphones cancel unwanted noise when you're on calls, and pick up your voice from across the room - so you can use voice activation to wake your system, play music, and more. -
Built for life's extremes
Like all ThinkPad laptops, the X1 Yoga Gen 4 is tested against 12 military-grade requirements and more than 200 quality checks to ensure it runs in extreme conditions. From the Arctic wilderness to desert dust storms, from zero gravity to spills and drops, you can trust this laptop to handle whatever life throws your way. -
Lenovo has got your back - and your front
Keep your business data - and your privacy - safe with the X1 Yoga Gen 4 laptop's comprehensive suite of ThinkShield security features. Its discrete Trusted Platform Module (dTPM) encrypts data and ThinkShutter, a physical camera cover, blocks the lens to ensure that you're only seen when you want to be.
- Lenovo ThinkPad X1 Yoga (4th Gen) - 14" - Core i5 8265U - 16 GB RAM - 256 GB SSD - UK
- Product Type
- Notebook - flip design
- Operating System
- Win 10 Pro 64-bit - English
- Processor
- Intel Core i5 (8th Gen) 8265U / 1.6 GHz (3.9 GHz) / 6 MB Cache
- Memory
- 16 GB LPDDR3 (provided memory is soldered)
- Storage
- 256 GB SSD - TCG Opal Encryption 2, NVMe
- Optical Drive
- No optical drive
- Display
- 14" LED backlight touchscreen 2560 x 1440 / WQHD
- Graphics
- Intel UHD Graphics 620
- Input Device
- Digitizer, TrackPoint, digital pen, UltraNav
- Keyboard
- UK
- Keyboard Backlight
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac, NFC, Bluetooth 5.0, Gigabit Ethernet
- Wireless Broadband (WWAN)
- 4G
- Battery
- Up to 18.1 hours
- 3-axis gyro sensor, 3-axis accelerometer
- Dockable
- Security
- Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader
- Iron grey
- 32.3 cm x 21.8 cm x 1.55 cm
- 1.36 kg
- Localisation
- Manufacturer Selling Program
- TopSeller
- Environmental Standards
- ENERGY STAR Qualified
- SAR
- 1.571 W/kg (body), 1.571 W/kg (limb)
- Limited warranty - 3 years - on-site , Limited warranty - battery - 1 year
- Product Type
- Operating System
- Windows 10 Pro 64-bit Edition - English
Processor / Chipset
- CPU
- Max Turbo Speed
- 3.9 GHz
- Number of Cores
- Quad-Core
- Cache
- 6 MB
- 64-bit Computing
- Integrated memory controller
- RAM
- 16 GB (provided memory is soldered)
- Technology
- LPDDR3 SDRAM
- Speed
- 2133 MHz
- Rated Speed
- 2133 MHz
Storage
- Main Storage
- 256 GB SSD M.2 2280 PCIe - TCG Opal Encryption 2, NVM Express (NVMe)
Display
- 14" - IPS
- LCD Backlight Technology
- LED backlight
- Touchscreen
- Yes (10-point multi-touch)
- Resolution
- 2560 x 1440 (WQHD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Image Brightness
- 300 cd/m²
- Bezel Type
- Flat front
- Glossy, anti-reflective, 72% colour gamut, anti-smudge
Audio & Video
- Graphics Processor
- Camera
- Yes - 720p
- Camera Features
- IR camera, ThinkShutter camera privacy
- Sound
- Stereo speakers, quad array microphone
- Codec
- Realtek ALC1012L
- High Definition Audio, Dolby Atmos
Input
- Keyboard, digitizer, TrackPoint, digital pen, UltraNav
- Keyboard Layout
- UK
- Spill-resistant, multi-touch touchpad
Communications
- Wireless
- Wireless Controller
- Intel Wireless-AC 9560 - M.2 Card
- Network Interface
- Gigabit Ethernet
- Ethernet Controller
- Intel I219-V
- Generation
- 4G
- Technology
- LTE Advanced
- Controller
- FIBOCOM L850-GL - M.2 Card
Navigation
- Receiver
- GPS
- Technology
- Lithium Ion
- Capacity
- 51 Wh
- Run Time
- Up to 18.1 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 65 Watt
Connections & Expansion
- Slots
- 1 x Nano-SIM card (1 free)
- USB 3.1 Gen 1 , USB 3.1 Gen 1 (Always On) , 2 x USB-C 3.1 Gen 2/Thunderbolt 3/DisplayPort (Power Delivery) , HDMI , Lenovo Ethernet extension connector , Headphone/microphone combo jack , LAN (on supplied cable) , Dock
- Iron grey
- Case Material
- Aluminum, magnesium alloy
- Integrated Options
- Dockable
- Security
- Administrator password, hard drive password, power-on password, MIL-STD-810G tested
- Theft/Intrusion Protection
- Security Slot Type
- Kensington mini security slot
- Included Accessories
- ThinkPad Pen Pro, USB-C power adapter, ThinkPad Ethernet Extension Cable Gen 2
- RoHS
- SAR Value
- Localization
- TopSeller
- 1.36 kg
- ENERGY STAR Certified
Get more from your purchase from one of our essential accessories
Lenovo Microsaver Security Cable Lock | In Stock | £23.65 |
