A carbon fiber roll cage with reinforcement throughout makes the X1 Carbon Ultrabook ultralight, ultradurable and highly portable. Stay unplugged all day, but when needed, boost your battery up to 80% capacity in just 35 minutes.
An IT admin's dream
ThinkPad X1 Carbon offers robust security features, including ThinkShutter, which covers the front-facing HD webcam, and match-on-chip fingerprint readers with anti-spoofing technology that helps safeguard company data while providing more secure authentication and log-in. -
Audio so amazing you'll think it's live
Speakers on the X1 Carbon deliver high-quality sound with Dolby Audio Premium, which energizes your entertainment with rich, powerful sound. It dynamically adjusts audio to deliver home theater quality in a virtual surround sound experience for all your entertainment. Boosted bass and enhanced volume turn it all up for sound that's loud and clear enough to share. And for times you need to plug in your headphones, enter a whole world of sound with Dolby Atmos, for an immersive experience that puts you inside the action. -
Make your voice heard
With Cortana Premium, you can speak commands to your ThinkPad X1 Carbon from 4 meters / 13 feet. The integrated 360-degree far field microphones ensure your voice is heard across the room. Wake your device with a simple phrase. Quickly and easily find files and calendar events. Even put your system into Modern Standby mode, which improves battery performance. So go ahead and speak your mind and boost your productivity at the same time. -
Built to go on and on
Like all ThinkPads, the X1 Carbon is tested against 12 military-grade requirements and more than 200 quality checks to ensure they run in extreme conditions. With a chassis constructed of four layers of reinforced carbon fiber and a magnesium alloy roll-cage for added strength, you'll trust this laptop to handle whatever life throws your way. -
Flick your finger for privacy
Minimize concerns about being watched or inadvertently turning on the webcam with ThinkShutter. This built-in sliding cover ensures front-facing camera privacy and security when you opt for the HD camera. It's easy to use and delivers strong protection.
- Lenovo ThinkPad X1 Carbon (5th Gen) - 14" - Intel Core i7 - 7500U - 8 GB RAM - 256 GB SSD - 4G LTE-A - UK
- Product Type
- Ultrabook
- Operating System
- Win 10 Pro 64-bit
- Processor
- Intel Core i7 (7th Gen) - 7500U / 2.7 GHz, up to 3.5 GHz / 4 MB Cache
- Memory
- 8 GB LPDDR3 (provided memory is soldered)
- Storage
- 256 GB SSD - TCG Opal Encryption 2, NVMe
- Display
- 14" LED backlight 1920 x 1080 / Full HD
- Graphics
- Intel HD Graphics 620
- Input Device
- TrackPoint, UltraNav
- Keyboard
- UK
- Keyboard Backlight
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac, Bluetooth 4.1, Gigabit Ethernet
- Wireless Broadband (WWAN)
- 4G LTE Advanced
- Service Provider
- Lenovo
- Battery
- 3-cell - up to 15.5 hours
- Security
- Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader
- Black
- 32.35 cm x 21.71 cm x 1.595 cm
- 1.13 kg
- Localisation
- Manufacturer Selling Program
- TopSeller
- Environmental Standards
- - ENERGY STAR Qualified EPEAT Climate+
- Limited warranty - 3 years - on-site , Limited warranty - battery - 1 year
- Product Type
- Ultrabook
- Operating System
- Windows 10 Pro 64-bit Edition
Processor / Chipset
- CPU
- Intel Core i7 (7th Gen) 7500U / 2.7 GHz
- Max Turbo Speed
- 3.5 GHz
- Number of Cores
- Dual-Core
- Cache
- 4 MB
- 64-bit Computing
- Hyper-Threading Technology, integrated memory controller, Intel Turbo Boost Technology 2.0, Intel Smart Cache
- RAM
- 8 GB (provided memory is soldered)
- Technology
- LPDDR3 SDRAM
- Speed
- 1866 MHz
Storage
- Main Storage
- 256 GB SSD M.2 PCIe - TCG Opal Encryption 2, NVM Express (NVMe)
Display
- 14" - IPS
- LCD Backlight Technology
- LED backlight
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Image Brightness
- 300 cd/m²
- Anti-glare
Audio & Video
- Graphics Processor
- Camera
- Yes - 720p
- Sound
- Stereo speakers, dual array microphone
- Codec
- CX11871
- High Definition Audio
Input
- Keyboard, TrackPoint, UltraNav
- Keyboard Layout
- UK
- Spill-resistant, multi-touch touchpad, buttonless touchpad
Communications
- Wireless
- Wireless Controller
- Intel Dual Band Wireless-AC 8265 - M.2 Card
- Network Interface
- Gigabit Ethernet
- Ethernet Controller
- Intel I219-V
- Generation
- 4G
- Technology
- UMTS, HSPA, HSPA+, DC-HSPA+, LTE Advanced
- Controller
- Sierra Wireless EM7455 - M.2 Card
- Service Provider
- Lenovo
Navigation
- Receiver
- GPS
- Technology
- 3-cell Lithium Ion
- Capacity
- 57 Wh
- Run Time
- Up to 15.5 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 65 Watt
Connections & Expansion
- Interfaces Details
- USB 3.1 Gen 1/USB 3.0 (Always On) , USB 3.1 Gen 1/USB 3.0 , 2 x USB-C 3.1 Gen 2 (supports Thunderbolt 3, DisplayPort Alt Mode) (Power Delivery 2.0) , HDMI , Headphone/microphone combo jack , Lenovo Ethernet extension connector
- Memory Card Reader
- Yes (microSDXC UHS-II)
Software
- Software Included
- Lenovo Companion, Lenovo Settings
- Black
- Case Material
- Glass-fibre reinforced plastic, magnesium alloy, carbon fibre reinforced plastic
- Security
- Administrator password, hard drive password, power-on password, RapidCharge, MIL-STD-810G tested
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- Included Accessories
- Power adapter, Lenovo Connect SIM card
- RoHS
- Localization
- TopSeller
- 1.13 kg
Sustainability Information
- TCO Certified
- EPEAT Compliant
- EPEAT Climate+
- ENERGY STAR Certified
