Redesigned from the ground up, ThinkPad X1 Tablet gives you power, productivity, and portability in a premium detachable 2-in-1 that means business. From the enlarged edge-to-edge display to the enhanced security hardware, to the responsive voice experience that wakes your device even faster, the X1 Tablet is the perfect solution for professionals on the go.
An IT admin's dream
The ThinkPad X1 Tablet includes dual Intel Thunderbolt ports, which enable both blazing fast data speeds and versatile video output. Login credentials are even more secure with Windows Hello, integrated with the optional IR camera and the touch fingerprint reader. Both the SSD and the battery are Field Serviceable, which means that in the event of a failure, we send a certified technician to you, to replace the parts, so you don't need to mail in the device. And lastly, this tablet is available as Microsoft AutoPilot ready, which offers business-ready preloads. What more could an IT administrator ask for! -
Lightweight in chassis-not performance
With the dazzling 13" 3k display, the ThinkPad X1 Tablet weighs less than 2 pounds. This redesigned 2-in-1 includes a newly designed kickstand and two convenient angles for typing. Even with the keyboard attached, it's well under 3 pounds, and it's just over a quarter of an inch thin (8.9 mm). Factor in the more-than-all-day 9.5-hour battery life, and you've got a device that's extremely convenient for traveling and working on the go. And just like with your phone, the LTE-A connectivity ensures you stay up and running, WiFi or not. -
Unleash your creativity
The X1 Tablet is compatible with the Lenovo Active Pen. Sketch. Sign documents. Take notes. And never worry about running out of ink. Go ahead and create-there are no limits to where your imagination can take you. -
Just keeps getting better
Our 3rd generation X1 Tablet features design and engineering improvements that facilitate seamless productivity. Maximize battery life with Modern Standby, which lets you manage and configure a low power state. Then wake the system even faster with your voice or your fingerprint. Always stay connected as you effortlessly switch between WiFi and mobile broadband when you opt for LTE-A. Plus, the device stays cooler with Intelligent Cooling, which lets you monitor and manage processor state and system temperature to optimize battery life and cooling. -
Go ahead-forget your password!
ThinkPad X1 Tablet includes robust security features so you need not worry about protecting your information. Quickly log in with ease-just the touch of your finger or the view of your face if you opt for the IR Camera and use Windows Hello. What's more, further security enhancements keep your device and your data protected. The discrete Trusted Platform Module (dTPM) encrypts your information. -
Put some teeth into your security
Plus, ThinkPad is now enabled with FIDO authentication capabilities. Fast Identity Online-or FIDO-enables hardened authentication that wraps your access info in three layers of security. FIDO authentication pertains to your online credentials, when you sign in to websites like Facebook or Google, or make payments via PayPal, Visa, etc. This global solution creates better security for online services, reduces costs for organizations, and is simpler and safer for users. -
Prepare to be thunderstruck
The X1 Tablet includes Intel Thunderbolt 3-the technology that brings lightning-fast Thunderbolt to USB-C at speeds up to 40 Gbps. Connect a cable from your USB-C port to a Thunderbolt 3-enabled device, and get four times the data and twice the video bandwidth of any other port type, while also supplying power. So you get Thunderbolt, USB-C, and DisplayPort all rolled into one.
- Lenovo ThinkPad X1 Tablet (3rd Gen) - 13" - Intel Core i7 - 8550U - 16 GB RAM - 512 GB SSD - 4G LTE-A - UK
- Product Type
- Tablet - with detachable keyboard
- Operating System
- Win 10 Pro 64-bit
- Processor
- Intel Core i7 (8th Gen) - 8550U / 1.8 GHz (4 GHz) / 8 MB Cache
- Memory
- 16 GB LPDDR3 (provided memory is soldered)
- Storage
- 512 GB SSD - TCG Opal Encryption 2, NVMe
- Display
- 13" LED backlight touchscreen 3000 x 2000 / QHD+
- Graphics
- Intel UHD Graphics 620
- Input Device
- Keyboard, digitizer, TrackPoint, digital pen, UltraNav
- Keyboard
- UK
- Keyboard Backlight
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac, Bluetooth 4.1
- Wireless Broadband (WWAN)
- 4G LTE Advanced
- Service Provider
- Service not included
- Battery
- Up to 9.5 hours
- Ambient light sensor, 3-axis gyro sensor, digital compass, 3-axis accelerometer
- Dockable
- Security
- Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader
- Black
- Dimensions (WxDxH) - tablet
- 30.41 cm x 22.6 cm x 0.89 cm
- 890 g
- Localisation
- Manufacturer Selling Program
- TopSeller
- SAR
- 1.51 W/kg (body), 1.51 W/kg (limb)
- Limited warranty - 3 years - pick-up and return , Limited warranty - battery - 1 year
- Product Type
- Operating System
- Windows 10 Pro 64-bit Edition
Processor / Chipset
- CPU
- Intel Core i7 (8th Gen) 8550U / 1.8 GHz
- Max Turbo Speed
- 4 GHz
- Number of Cores
- Quad-Core
- Cache
- 8 MB
- 64-bit Computing
- Integrated memory controller
- RAM
- 16 GB (provided memory is soldered)
- Technology
- LPDDR3 SDRAM
- Speed
- 1866 MHz
- Rated Speed
- 2133 MHz
Storage
- Main Storage
- 512 GB SSD M.2 PCIe - TCG Opal Encryption 2, NVM Express (NVMe)
Display
- 13" - IPS
- LCD Backlight Technology
- LED backlight
- Touchscreen
- Yes (10-point multi-touch)
- Resolution
- 3000 x 2000 (QHD+)
- Widescreen
- Image Aspect Ratio
- 3:2
- Image Brightness
- 400 cd/m²
- Glossy, Corning Gorilla glass, WideView, anti-fingerprint
Audio & Video
- Graphics Processor
- Camera
- Resolution
- 8 Megapixel (rear), 2 Megapixel (front)
- Camera Features
- IR camera, rear camera with auto focus, rear camera with flash
- Sound
- Stereo speakers, two microphones
- Codec
- Realtek ALC3278
Input
- Keyboard Layout
- UK
- Volume control, multi-touch touchpad, buttonless touchpad
Communications
- Wireless
- Wireless Controller
- Intel Dual Band Wireless-AC 8265 - M.2 Card
- Generation
- 4G
- Technology
- UMTS, HSPA, HSPA+, DC-HSPA+, LTE Advanced
- Controller
- Sierra Wireless EM7455
- Service Provider
Navigation
- Receiver
- GPS
- Technology
- Lithium Ion
- Capacity
- 42 Wh
- Run Time
- Up to 9.5 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 65 Watt
Connections & Expansion
- Slots
- 1 x Nano-SIM card (1 free)
- 2 x USB-C 3.1 Gen 1 (Power Delivery 3.0) , Headphone/microphone combo jack , Pogo keyboard connector
- Memory Card Reader
- Yes (microSD, microSDHC, microSDXC UHS)
- Black
- Case Material
- Magnesium-aluminum alloy
- Integrated Options
- Dockable
- Security
- Reset switch, MIL-STD-810G tested, built-in easel kickstand
- Theft/Intrusion Protection
- Security Slot Type
- Kensington mini security slot
- Included Accessories
- Keyboard, ThinkPad Pen Pro, USB-C power adapter
- RoHS, GREENGUARD, low halogen
- SAR Value
- Localization
- TopSeller
- 890 g
- Dimensions (WxDxH) / Weight Details
- 30.41 cm x 22.6 cm x 0.89 cm / 890 g - tablet , 30.41 cm x 22.6 cm x 1.51 cm / 1.27 kg - tablet with keyboard
Essential Accessories (4)
Get more from your purchase from one of our essential accessories
Lenovo 45W Standard AC Adapter (USB Type-C) Power Adapter | In Stock | £26.01 |
Lenovo 65W Standard AC Adapter USB-C | In Stock | £29.56 |
Lenovo USB-C 65W AC Adapter AC 100-240 V 65Watt for ThinkPad A275 | In Stock | £29.56 |
Lenovo ThinkPad Hybrid USB-C with USB-A Dock - Do | In Stock | £199.18 |
