The Lenovo ThinkPad USB charging adapter is ideal for travellers who are short on USB ports but still need to charge their devices. It provides up to 11 watts of power, working with a ThinkPad power adapter (slim tip). The small, lightweight charger saves space and lightens your load, while the adapter's USB port provides a 2.1 A current, charging your devices faster than the port on your laptop. The rectangle port supports all ThinkPad power adapters and allows ThinkPad laptops and mobile devices to be charged simultaneously.
- Lenovo ThinkPad USB Charging Adapter - power adapter - 11 Watt
- Power adapter - external
- 29 g
- Input Voltage
- 20 V
- Output Voltage
- 5 / 20 V
- Power Capacity
- 11 Watt
- 3.1 cm x 16.5 cm x 1.2 cm
- Designed For
- ThinkPad 11e (2nd Gen); 11e (3rd Gen); 11e Chromebook (3rd Gen); Thinkpad 13 (1st Gen); ThinkPad E45X; E46X; E470; E56X; L460; L560; P40 Yoga; P50; T450; T460; T560; W541; W550; X1 Carbon (4th Gen); X1 Yoga (1st Gen); X250; X260; ThinkPad Yoga 11e (3rd Gen); 11e Chromebook (3rd Gen); 14; 260; 460
- Input Voltage
- 20 V
- Output Voltage
- 5 / 20 V
- Max Electric Current
- 2.1 A
- Power Capacity
- 11 Watt
- 5 °C
- 40 °C
- 8 - 80%
- 3.1 cm
- 16.5 cm
- 1.2 cm
- 29 g
- Designed For
- Lenovo ThinkPad 135W AC Adapter (Slim Tip), 170W AC Adapter (Slim Tip), 45W AC Adapter (Slim Tip), 65W AC Adapter (Slim Tip) , Lenovo ThinkPad 11e (1st Gen) 20D9, 20DA , Lenovo ThinkPad 11e (2nd Gen) 20E6, 20E8, 20ED, 20EE , Lenovo ThinkPad 11e (3rd Gen) 20G9 , Lenovo ThinkPad 11e Chromebook (1st Gen) 20DB, 20DU , Lenovo ThinkPad 11e Chromebook (3rd Gen) 20GD, 20GF , Lenovo Thinkpad 13 (1st Gen) 20GJ, 20GK , Lenovo ThinkPad E450 20DC, 20DD , Lenovo ThinkPad E455 20DE , Lenovo ThinkPad E460 20ET , Lenovo ThinkPad E465 20EX , Lenovo ThinkPad E470 20H1 , Lenovo ThinkPad E540 20C6 , Lenovo ThinkPad E560 20EV, 20EW , Lenovo ThinkPad E565 20EY , Lenovo ThinkPad Edge E550 20DF, 20DG , Lenovo ThinkPad Edge E555 20DH , Lenovo ThinkPad L450 20DS, 20DT , Lenovo ThinkPad L460 20FU, 20FV , Lenovo ThinkPad L560 20F1, 20F2 , Lenovo ThinkPad P40 Yoga 20GQ, 20GR , Lenovo ThinkPad P50 20EN, 20EQ , Lenovo ThinkPad P50s 20FK, 20FL , Lenovo ThinkPad S540 20B3 , Lenovo ThinkPad S540 Touch 20B3 , Lenovo ThinkPad T440s 20AQ, 20AR , Lenovo ThinkPad T450 20BU, 20BV , Lenovo ThinkPad T450s 20BW , Lenovo ThinkPad T460 20FM , Lenovo ThinkPad T460p 20FW, 20FX , Lenovo ThinkPad T460s 20F9, 20FA , Lenovo ThinkPad T550 20CJ, 20CK , Lenovo ThinkPad T560 20FH, 20FJ , Lenovo ThinkPad W541 20EF, 20EG , Lenovo ThinkPad W550s 20E1, 20E2 , Lenovo ThinkPad X1 Carbon (2nd Gen) 20A7, 20A8 , Lenovo ThinkPad X1 Carbon (3rd Gen) 20BS, 20BT , Lenovo ThinkPad X1 Carbon (4th Gen) 20FB, 20FC , Lenovo ThinkPad X1 Yoga (1st Gen) 20FQ, 20FR , Lenovo ThinkPad X240s 20AJ, 20AK , Lenovo ThinkPad X250 20CL, 20CM , Lenovo ThinkPad X260 20F5, 20F6 , Lenovo ThinkPad Yoga 20C0 , Lenovo ThinkPad Yoga 11e (3rd Gen) 20GA , Lenovo ThinkPad Yoga 11e Chromebook (3rd Gen) 20GC, 20GE , Lenovo ThinkPad Yoga 12 20DK, 20DL , Lenovo ThinkPad Yoga 14 20DM, 20DN, 20FY , Lenovo ThinkPad Yoga 15 20DQ , Lenovo ThinkPad Yoga 260 20FD, 20FE, 20GS, 20GT , Lenovo ThinkPad Yoga 460 20EL, 20EM
