ThinkPad UltraSlim USB DVD Burner – a small form factor external portable DVD and CD recordable drive that can be attached to Notebooks with USB2.0 port or USB3.0 port. The 9.5 mm UltraSlim engine (20% slimmer than previous the DVD Burner) with premium outlook means that the ThinkPad UltraSlim USB DVD Burner brings you the best user experience.
- Lenovo ThinkPad UltraSlim USB DVD Burner - DVD±RW (±R DL) / DVD-RAM drive - SuperSpeed USB 3.0 - external
- DVD±RW (±R DL) / DVD-RAM drive - external
- Interface
- 13.6 cm x 15.4 cm x 1.32 cm
- 235 g
- Optical Storage
- Pricing Type
- Customer-replaceable Unit (CRU)
- 1-year warranty
- Designed For
- IdeaPad 1 14; S340-14; K14 Gen 1; ThinkCentre M70s Gen 3; M70t Gen 3; M80s Gen 3; M80t Gen 3; M90a Gen 3; M90s Gen 3; M90t Gen 3; ThinkPad E14 Gen 3; L13 Yoga Gen 3; L15 Gen 3; P15v Gen 3; T14 Gen 3; T14s Gen 3; X1 Extreme Gen 5; X13 Gen 3; X13 Yoga Gen 3; V15 IML; Yoga Slim 7 Pro 14
- Interface
- 13.6 cm
- 15.4 cm
- 1.32 cm
- 235 g
Optical Storage
- Supported Media Formats
- CD Text, CD Extra, CD-ROM XA, Photo CD, Video CD, CD-ROM
- Supported Media Types
- CD-ROM, CD-R, CD-RW, DVD-ROM, DVD-R, DVD-RAM, DVD-RW, DVD+RW, DVD+R, DVD+R DL, DVD-R DL
- Access Time
- 160 ms (DVD), 140 ms (CD)
- Buffer Size
- 0.75 MB
- 1 x USB 3.0 - 4 pin USB Type A
- Cables Included
- 1 x USB cable
- UL, TUV, VCCI, C-Tick, BSMI, FCC, KC
- Pricing Type
- OS Required
- Microsoft Windows 7 / Windows 8
- Limited warranty - replacement - 1 year
- 0 °C
- 40 °C
- 5 - 85% (non-condensing)
- Designed For
- Lenovo IdeaPad 1 14ALC7 82R3 , Lenovo IdeaPad 1 14IGL7 82V6 , Lenovo IdeaPad Flex 3 Chrome 15IJL7 82T3 , Lenovo IdeaPad Gaming 3 15ARH7 82SB , Lenovo IdeaPad S340-14IILD 81WJ , Lenovo K14 Gen 1 21CU, 21CV , Lenovo Legion 5 15ACH6H 82QJ , Lenovo ThinkBook 14 G4 IAP 21DH , Lenovo ThinkBook 14 G4+ IAP 21CX , Lenovo ThinkCentre M70q Gen 2 11N3 , Lenovo ThinkCentre M70s Gen 3 11TB, 11XG , Lenovo ThinkCentre M70t Gen 3 11T5, 11T9, 11TA , Lenovo ThinkCentre M75q Gen 2 11JS , Lenovo ThinkCentre M75s Gen 2 11W2 , Lenovo ThinkCentre M80q Gen 3 11U1 , Lenovo ThinkCentre M80s Gen 3 11TG, 11TL , Lenovo ThinkCentre M80t Gen 3 11TE, 11TJ , Lenovo ThinkCentre M90a Gen 3 11VF, 11VH , Lenovo ThinkCentre M90q Gen 3 11U5, 11U8 , Lenovo ThinkCentre M90s Gen 3 11TT, 11TX , Lenovo ThinkCentre M90t Gen 3 11TM, 11TN, 11TV , Lenovo ThinkCentre neo 30a 22 12B1 , Lenovo ThinkCentre neo 30a 24 12B0 , Lenovo ThinkCentre neo 50t 11SF , Lenovo ThinkEdge SE70 12A6 , Lenovo ThinkPad E14 Gen 3 20YE , Lenovo ThinkPad E14 Gen 4 21E3 , Lenovo ThinkPad E15 Gen 4 21E6 , Lenovo ThinkPad L13 Gen 3 21B9 , Lenovo ThinkPad L13 Yoga Gen 3 21B5, 21B6, 21BB , Lenovo ThinkPad L15 Gen 3 21C3, 21C4 , Lenovo ThinkPad P1 Gen 5 21DC , Lenovo ThinkPad P15v Gen 3 21D8, 21D9, 21EN , Lenovo ThinkPad T14 Gen 3 21AH, 21CF, 21CG , Lenovo ThinkPad T14s Gen 3 21BR, 21BS, 21CR , Lenovo ThinkPad T15p Gen 3 21DA , Lenovo ThinkPad T16 Gen 1 21BV, 21CH , Lenovo ThinkPad X1 Carbon Gen 10 21CB, 21CC , Lenovo ThinkPad X1 Extreme Gen 5 21DE , Lenovo ThinkPad X1 Yoga Gen 7 21CE , Lenovo ThinkPad X13 Gen 3 21BN, 21BQ, 21CN , Lenovo ThinkPad X13 Yoga Gen 3 21AW, 21AX , Lenovo V15 G2 ITL 82ME , Lenovo V15 G3 IAP 82TT , Lenovo V15 IML 82NQ , Lenovo V15-IGL 82NN , Lenovo V17 G3 IAP 82U1 , Lenovo V50t Gen 2-13IOB 11QB , Lenovo Yoga Slim 7 Pro 14ARH7 82UU , Lenovo Yoga Slim 7 Pro 14IAH7 82UT , Lenovo Yoga Slim 7 Pro 14IAP7 82SV , Lenovo Yoga Slim 7 ProX 14ARH7 82TL
