The completely re-designed and supercharged ThinkPad Ultra 170W Dock with an included ThinkPad 170W AC Adapter grows your work capability with its endless connectivity options. The ultimate multi-port docking solution, the ThinkPad Ultra 170W Dock includes a range of video outputs, including HDMI 1.4, and support for multiple external monitors. The Ultra 170W Dock is driver-free, delivering outstanding video quality. It comes with 3x USB 2.0 ports, one of which supports always-on USB charging so you can charge your tablet or mobile using the dock without needing to connect your ThinkPad notebook. The dock is equipped with 3x USB 3.0 ports – perfect for connecting memory keys, hard drives and other external storage devices. This ThinkPad docking station also support 10/1000 Gigabit Ethernet connection and comes with 2x Display 1.2 Ports, 1x DVI-D port, 1x HDMI 1.4 port, 1x Stereo/Mic Combo Audio Port and 1x VGA port. However, some of the video ports have exclusive use and are also dependent on the docked ThinkPad configuration. This dock comes with a 170W AC adapter which can power and charge your notebook.
- Lenovo ThinkPad Ultra Dock - port replicator - VGA, DVI, HDMI, 2 x DP
- Product Type
- Port replicator
- Video Interfaces
- 34.5 cm x 16.25 cm x 5.56 cm
- 920 g
- Localisation
- Saudi Arabia, Hong Kong, United Kingdom
- Power
- Power adapter AC 120/230 V (50/60 Hz) 170 Watt Power Provided
- 1-year warranty
- Product Type
- Port replicator
- 34.5 cm
- 16.25 cm
- 5.56 cm
- 920 g
- Localisation
- 3 x USB 2.0 - 4 pin USB Type A , 3 x SuperSpeed USB 3.0 - 9 pin USB Type A , 1 x network - 10Base-T/100Base-TX/1000Base-T - RJ-45 , 2 x audio / video - DisplayPort - 20 pin DisplayPort , 1 x display / video - DVI-Digital - 24+1 pin digital DVI , 1 x audio / video - HDMI - 19 pin HDMI Type A , 1 x display / video - VGA - 15 pin HD D-Sub (HD-15) , 1 x audio - headphones/microphone - mini-phone stereo 3.5 mm , 1 x docking / port replicator
- Included Accessories
- 2 x security keys
- Security lock slot (cable lock sold separately), 1 USB 2.0 (Always On)
- UL, VCCI, BSMI, GOST, NOM, CB, DOC, FCC, KCC, UkrSEPRO, AS/NZS
- Power Device
- Power adapter
- Voltage Required
- AC 120/230 V (50/60 Hz)
- Power Provided
- 170 Watt
- Limited warranty - replacement - 1 year
- 5 °C
- 43 °C
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
