Lenovo ThinkPad T550 Intel Core i5-5200U 4GB 500GB 15.6" Windows 7 Professional 64-bit
Quicklinx: BV48WS00 Mfr#: 20CK003KUK
  • Core i5
  • Microsoft Windows 7 Professional 64-bit Edition
  • Bluetooth 4.0
  • IEEE 802.11n
The ThinkPad T550 is a 15-inch Ultrabook redefining the business standard laptop. Thin, light and well connected, the T550 is a truly mobile Ultrabook providing no-fuss, high speed computing in a sleek form factor for today's on-the-go business professional. In addition to the already superior battery life packed inside, the T550 can be paired with power bridge technology, a separate battery pack that easily locks into the laptop and continues to power up without closing out files and shutting down to keep users working efficiently.
  • 4th generation Intel Core processor
    4th generation Intel Core processor deliver the performance to increase productivity for your business. Devices turn on in an instant and are always up-to-date. You can multitask quickly and move effortlessly between applications, collaborate wirelessly in a high quality videoconference - all with the convenience of longer battery life. Plus, you can guard against identity theft and ensure safe access to your network with built-in security features. In fact, the only thing more amazing than an Intel Core processor-based PC is what your users will do with it.
  • Precision keyboard enhanced
    Full-sized and spill-resistant, the ergonomic ThinkPad keyboard is renowned for its array of keys, excellent feel and TrackPoint pointing. With convenient multimedia buttons and immediate access to view apps, it has LED status indicators and function-lock capability. With a larger, smooth trackpad and 5-point click integration - indicated by subtle bumps and stripes, the keyboard can be configured multiple ways, while the backlight makes working in the dark effortless.
  • 15.6" HD, FHD or IPS 3K display
    The powerful HD, FHD and IPS 3K display options deliver bright, crisp visuals and a wide viewing range. Anti-glare technology makes the screen comfortable to look at even over the long haul.
  • 4G/3G connectivity
    Connecting to 4G and 3G wireless networks is simple with a pre-installed SIM card and the easy-to-use lenovo access connection tool.
  • Ultradurable and MIL-SPEC tested
    The T540p meets eight US military-spec tests for ruggedness, durability, and quality: high pressure, humidity, vibration, high temperature, temperature shock, low pressure (15,000 ft), low temperature, and dust. In addition, innovative roll-cage technology and glass-fiber reinforced plastic add extra strength and rigidity.
  • Dolby advanced audio v2
    A suite of audio technology from Dolby delivers a crisp, clear cinematic surround sound for music, movies, games, and more. Hear every detail clearly and experience the full impact of your entertainment anywhere.
  • VGA port
    A VGA port for projector connections in conference rooms is still a business must-have, and a native VGA means no dongles to buy/lose/replace.
Lenovo ThinkPad T550 - 15.6" - Intel Core i5 - 5200U - 4 GB RAM - 500 GB Hybrid Drive - UK
Ultrabook
Operating System
Win 7 Pro 64-bit (downgrade from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence
Intel Core i5 (5th Gen) - 5200U / 2.2 GHz, up to 2.7 GHz / 3 MB Cache
4 GB DDR3L (1 x 4 GB)
Storage
500 GB Hybrid Drive (8 GB flash) / 5400 rpm
Display
15.6" LED backlight 1920 x 1080 / Full HD
Graphics
Intel HD Graphics 5500
Input Device
TrackPoint, UltraNav
Keyboard
Keyboard Backlight
Numeric Keypad
Integrated Webcam
Bluetooth 4.0, 802.11a/b/g/n/ac, Gigabit Ethernet
3-cell
Dockable
Security
Trusted Platform Module (TPM 1.2) Security Chip, fingerprint reader, smart card reader
38.06 cm x 25.82 cm x 2.245 cm
2.13 kg
Manufacturer Selling Program
TopSeller
Environmental Standards
ENERGY STAR Qualified
Limited warranty - 3 years - on-site , Limited warranty - battery - 1 year
Ultrabook
Operating System
Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence
Processor / Chipset
CPU
Intel Core i5 (5th Gen) 5200U / 2.2 GHz
Max Turbo Speed
2.7 GHz
Number of Cores
Dual-Core
Cache
3 MB
64-bit Computing
Hyper-Threading Technology, integrated memory controller, Intel Turbo Boost Technology 2.0
RAM
4 GB (1 x 4 GB)
Max RAM Supported
16 GB
DDR3L SDRAM
Speed
1600 MHz / PC3L-12800
Rated Speed
1600 MHz
SO-DIMM 204-pin
Slots Qty
2
Empty Slots
1
Storage
Main Storage
500 GB Hybrid Drive SATA 6Gb/s (8 GB flash) / 5400 rpm
SSD Cache
Optional (M.2)
Display
15.6"
LCD Backlight Technology
LED backlight
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Aspect Ratio
16:9
Image Brightness
300 cd/m²
Anti-glare
Audio & Video
Graphics Processor
Camera
Yes - 720p
Sound
Stereo speakers, two microphones
Codec
Realtek ALC3232
High Definition Audio
Input
Keyboard, TrackPoint, UltraNav
Keyboard Backlight
Keyboard Layout
Numeric Keypad
Spill-resistant, multi-touch touchpad, buttonless touchpad
Communications
Wireless
Wireless Controller
Intel Dual Band Wireless-AC 7265 - M.2 Card
Network Interface
Gigabit Ethernet
Ethernet Controller
Intel I218-V
Wireless Broadband (WWAN)
Generation
WWAN upgradable
3-cell lithium polymer
Installed Qty
1
Max Supported Qty
2
44 Wh
Run Time With Included Additional Battery
Up to 14.8 hours
AC Adapter
Input
Output
45 Watt
Connections & Expansion
3 x USB 3.0 , VGA , Mini DisplayPort , LAN , Headphone/microphone combo jack , Dock
Memory Card Reader
4 in 1 (SD Card, MultiMediaCard, SDHC Card, SDXC Card)
Software
Software Included
ThinkVantage Rescue and Recovery, Adobe Reader, ThinkVantage System Update, Norton Internet Security (30 days subscription), ThinkVantage Product Recovery, Lenovo Solution Center, PC Device Stage, SHAREit
Case Material
Glass-fibre reinforced plastic
Dockable
Security
Security lock slot (cable lock sold separately), administrator password, hard drive password, power-on password, ThinkVantage Active Protection System, 1 USB 3.0 (Always On), ThinkEngine, MIL-STD-810G tested
Power adapter, 3-cell Li-Ion 23Wh battery
RoHS, GREENGUARD
Localization
TopSeller
2.13 kg
Sustainability Information
ENERGY STAR Certified
BV48 C2G 20cm Mini DisplayPort Male to HDMI Female Adapter Black In Stock £16.62
BV48 C2G 20cm Mini DisplayPort Male to VGA Female Adapter Black In Stock £17.63
