Lenovo ThinkPad T495s Ryzen 7 PRO 3700U 16GB 256GB SSD 14" Windows 10 Professional 64-bit
Quicklinx: FPRPWS00 Mfr#: 20QJ000DUK
  • IEEE 802.11n
The ThinkPad T495s laptop makes it easy to take your work with you, featuring lightweight portability and heavyweight performance. It means you can work longer, faster, and more efficiently. This laptop also has all-day battery life, a bottom-load, and a backlit keyboard. This ThinkPad T495s means business.
  • Premium performance
    The ThinkPad T495s combines the advanced processor with fast graphics, for high CPU frequency and great GPU performance. Experience maximum efficiency and premium audio and video that won't drain your battery.
  • Choose how you see it
    ThinkPad T495s display features a Full HD IPS low-power screen for enhanced battery life, and a touchscreen. Its super-slim bezel design will keep your eyes where they belong - on the screen.
  • This laptop listens
    With Cortana Premium, you can command your ThinkPad T495s from across the room. The integrated dual 360-degree far-field microphones ensure your voice carries its weight. Wake your device with a simple phrase. Quickly find files and calendar events. Even put your system into standby mode to improve battery performance with a single command.
  • Plenty of life between charges
    The ThinkPad T495s delivers a long-lasting battery life. If you're running low, rapid-charging technology provides 80% capacity in extremely short time.
  • Keep others out of your business
    Protect your ThinkPad T495s laptop's data with a multi-prong defense. Discrete Trusted Platform Module (dTPM 2.0) encrypts your data and passwords. The touch fingerprint reader work with Windows Hello for a more secure, biometric login. Avoid spying eyes with PrivacyGuard - an exclusive electronic-shield technology that blocks screen from all angles other than head-on. ThinkShutter, a physical cover that ensures your camera sees you only when you want it to.
Lenovo ThinkPad T495s - 14" - AMD Ryzen 7 Pro 3700U - 16 GB RAM - 256 GB SSD - UK
Notebook
Operating System
Win 10 Pro 64-bit - English
AMD Ryzen 7 Pro 3700U / 2.3 GHz (4 GHz) / 4 MB Cache
16 GB DDR4 (provided memory is soldered)
Storage
256 GB SSD - TCG Opal Encryption 2, NVMe
Display
14" LED backlight 1920 x 1080 / Full HD
Graphics
AMD Radeon Vega 10
Input Device
TrackPoint, UltraNav
Keyboard
Keyboard Backlight
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 5.0
Up to 16.4 hours
Dockable
Security
Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader, smart card reader
32.9 cm x 22.615 cm x 1.67 cm
1.33 kg
Manufacturer Selling Program
TopSeller
Environmental Standards
ENERGY STAR Qualified
Limited warranty - 3 years - pick-up and return , Limited warranty - battery - 1 year
Notebook
Operating System
Windows 10 Pro 64-bit Edition - English
Processor / Chipset
CPU
Max Turbo Speed
4 GHz
Number of Cores
Quad-Core
Cache
L3 - 4 MB
64-bit Computing
Integrated memory controller
RAM
16 GB (provided memory is soldered)
DDR4 SDRAM
Speed
2400 MHz
Rated Speed
2666 MHz
Storage
Main Storage
256 GB SSD M.2 2280 PCIe - TCG Opal Encryption 2, NVM Express (NVMe)
Display
14" - IPS
LCD Backlight Technology
LED backlight
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Aspect Ratio
16:9
Image Brightness
400 cd/m²
Colour Gamut
72%
Anti-glare, Low Power
Audio & Video
Graphics Processor
AMD Radeon Vega 10
Camera
Yes - 720p
Camera Features
IR camera, ThinkShutter camera privacy
Sound
Stereo speakers, dual array microphone
Codec
Realtek ALC3287
High Definition Audio, Dolby Audio Premium
Input
Keyboard, TrackPoint, UltraNav
Keyboard Backlight
Keyboard Layout
Spill-resistant, multi-touch touchpad, buttonless touchpad
Communications
Wireless
Wireless Controller
Intel Dual Band Wireless-AC 9260
Gigabit Ethernet via optional Ethernet (RJ-45) adapter
DASH
Wireless Broadband (WWAN)
Generation
WWAN upgradable
Lithium Ion
57 Wh
Run Time
Up to 16.4 hours
AC Adapter
Input
Output
65 Watt
Connections & Expansion
USB 3.1 Gen 2 , USB 3.1 Gen 1 (Always On) , 2 x USB-C 3.1 Gen 2 (supports DisplayPort Alt Mode) (Power Delivery) , HDMI , Lenovo Ethernet extension connector , Headphone/microphone combo jack , Dock
Memory Card Reader
Yes (microSD)
Case Material
Carbon fibre reinforced plastic, magnesium-aluminum alloy
Dockable
Security
Administrator password, hard drive password, power-on password, RapidCharge, MIL-STD-810G tested
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
USB-C power adapter
RoHS
Localization
TopSeller
1.33 kg
Sustainability Information
ENERGY STAR Certified
Essential Accessories (6)
Get more from your purchase from one of our essential accessories
FPRP Lenovo 3M 14.0W Privacy Filter In Stock £37.84
FPRP Lenovo 45W Standard AC Adapter (USB Type-C) Power Adapter In Stock £26.01
FPRP Lenovo 65W Standard AC Adapter USB-C In Stock £29.56
FPRP Lenovo USB-C 65W AC Adapter AC 100-240 V 65Watt for ThinkPad A275 In Stock £29.56
FPRP Lenovo ThinkPad Hybrid USB-C with USB-A Dock - Do In Stock £194.89
FPRP Kensington Security Cable Lock In Stock £23.65
Other bundles (15)
FPRP Lenovo HDMI to VGA Monitor Adapter In Stock £23.20
FPRP Lenovo USB3.0 To VGA/HDMI Adapter In Stock £63.85
FPRP Lenovo 2m HDMI Cable In Stock £17.02
FPRP Lenovo Professional Wireless Keyboard In Stock £53.47
FPRP Lenovo ThinkPad Ethernet Extension Adapter Gen 2 In Stock £25.51
FPRP Lenovo ThinkPad USB3.0 to Ethernet Adapter In Stock £16.07
FPRP Lenovo Essential Wired Keyboard and Mouse Combo - UK English In Stock £25.39
FPRP Lenovo ThinkVision M14 14" 1920x1080 6ms USB-C IPS LED Monitor In Stock £258.14
FPRP Lenovo ThinkVision T24d 24" 1920x1080 VGA HDMI DisplayPort IPS LED Monitor In Stock £202.02
FPRP Lenovo ThinkVision T27p-10 27" 3840x2160 HDMI DisplayPort USB-C IPS LED Monitor In Stock £454.54
FPRP Lenovo ThinkVision P27h-20 27" 2560x1440 6ms HDMI DisplayPort IPS LED Monitor In Stock £336.70
FPRP Lenovo ThinkVision T27q-20 27" 2560x1440 4ms HDMI DisplayPort IPS LED Monitor In Stock £321.24
FPRP Lenovo 100 Headset on ear wired - USB black for IdeaPad 3 ThinkCe In Stock £34.84
FPRP Lenovo ThinkPad Bluetooth Silent Mouse - Right and Left-handed In Stock £23.88
FPRP Lenovo Thinkvision MC50 Monitor Webcam In Stock £54.13
