The ThinkPad T495s laptop makes it easy to take your work with you, featuring lightweight portability and heavyweight performance. It means you can work longer, faster, and more efficiently. This laptop also has all-day battery life, a bottom-load, and a backlit keyboard. This ThinkPad T495s means business.
Premium performance
The ThinkPad T495s combines the advanced processor with fast graphics, for high CPU frequency and great GPU performance. Experience maximum efficiency and premium audio and video that won't drain your battery. -
Choose how you see it
ThinkPad T495s display features a Full HD IPS low-power screen for enhanced battery life, and a touchscreen. Its super-slim bezel design will keep your eyes where they belong - on the screen. -
This laptop listens
With Cortana Premium, you can command your ThinkPad T495s from across the room. The integrated dual 360-degree far-field microphones ensure your voice carries its weight. Wake your device with a simple phrase. Quickly find files and calendar events. Even put your system into standby mode to improve battery performance with a single command. -
Plenty of life between charges
The ThinkPad T495s delivers a long-lasting battery life. If you're running low, rapid-charging technology provides 80% capacity in extremely short time. -
Keep others out of your business
Protect your ThinkPad T495s laptop's data with a multi-prong defense. Discrete Trusted Platform Module (dTPM 2.0) encrypts your data and passwords. The touch fingerprint reader work with Windows Hello for a more secure, biometric login. Avoid spying eyes with PrivacyGuard - an exclusive electronic-shield technology that blocks screen from all angles other than head-on. ThinkShutter, a physical cover that ensures your camera sees you only when you want it to.
- Lenovo ThinkPad T495s - 14" - AMD Ryzen 5 Pro 3500U - 16 GB RAM - 256 GB SSD - UK
- Product Type
- Notebook
- Operating System
- Win 10 Pro 64-bit - English
- Processor
- AMD Ryzen 5 Pro 3500U / 2.1 GHz (3.7 GHz) / 4 MB Cache
- Memory
- 16 GB DDR4 (provided memory is soldered)
- Storage
- 256 GB SSD - TCG Opal Encryption 2, NVMe
- Display
- 14" LED backlight 1920 x 1080 / Full HD
- Graphics
- AMD Radeon Vega 8
- Input Device
- TrackPoint, UltraNav
- Keyboard
- UK
- Keyboard Backlight
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac, Bluetooth 5.0
- Battery
- Up to 16.4 hours
- Dockable
- Security
- Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader, smart card reader
- Black
- 32.9 cm x 22.615 cm x 1.67 cm
- 1.33 kg
- Localisation
- Manufacturer Selling Program
- TopSeller
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - 3 years - pick-up and return , Limited warranty - battery - 1 year
- Product Type
- Notebook
- Operating System
- Windows 10 Pro 64-bit Edition - English
Processor / Chipset
- CPU
- Max Turbo Speed
- 3.7 GHz
- Number of Cores
- Quad-Core
- Cache
- L3 - 4 MB
- 64-bit Computing
- Integrated memory controller
- RAM
- 16 GB (provided memory is soldered)
- Technology
- DDR4 SDRAM
- Speed
- 2400 MHz
- Rated Speed
- 2666 MHz
Storage
- Main Storage
- 256 GB SSD M.2 2280 PCIe - TCG Opal Encryption 2, NVM Express (NVMe)
Display
- 14" - IPS
- LCD Backlight Technology
- LED backlight
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Image Brightness
- 400 cd/m²
- Colour Gamut
- 72%
- Anti-glare, Low Power
Audio & Video
- Graphics Processor
- AMD Radeon Vega 8
- Camera
- Yes - 720p
- Camera Features
- IR camera, ThinkShutter camera privacy
- Sound
- Stereo speakers, dual array microphone
- Codec
- Realtek ALC3287
- High Definition Audio, Dolby Audio Premium
Input
- Keyboard, TrackPoint, UltraNav
- Keyboard Layout
- UK
- Spill-resistant, multi-touch touchpad, buttonless touchpad
Communications
- Wireless
- Wireless Controller
- Intel Dual Band Wireless-AC 9260
- Gigabit Ethernet via optional Ethernet (RJ-45) adapter
- DASH
Wireless Broadband (WWAN)
- Generation
- WWAN upgradable
- Technology
- Lithium Ion
- Capacity
- 57 Wh
- Run Time
- Up to 16.4 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 65 Watt
Connections & Expansion
- USB 3.1 Gen 2 , USB 3.1 Gen 1 (Always On) , 2 x USB-C 3.1 Gen 2 (supports DisplayPort Alt Mode) (Power Delivery) , HDMI , Lenovo Ethernet extension connector , Headphone/microphone combo jack , Dock
- Memory Card Reader
- Yes (microSD)
- Black
- Case Material
- Carbon fibre reinforced plastic, magnesium-aluminum alloy
- Dockable
- Security
- Administrator password, hard drive password, power-on password, RapidCharge, MIL-STD-810G tested
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- Included Accessories
- USB-C power adapter
- RoHS
- Localization
- TopSeller
- 1.33 kg
Sustainability Information
- ENERGY STAR Certified
