Light, thin, and built to perform anywhere, the ThinkPad T480s delivers what you need, when you need it. Powerful processing and superb graphics take functional efficiency to different heights. In addition, the enhanced security features maintain maximum protection and peace of mind wherever you roam.
An IT manager's dream
The ThinkPad T480s has a match-on-chip fingerprint reader, anti-spoofing technology that authenticates log-in credentials and helps safeguards your data, and a webcam cover that you can open and close. -
Raises performance levels - and eyebrows
Delivering higher performance, the processor is designed to take your productivity to different heights. Backed by the increased efficiency and speed of DDR4 memory, the T480s gives you the power of a desktop PC and the freedom of a portable laptop. -
Where form meets function
Inspired by ThinkPad customers, this ThinkPad has a USB-C docking connector on the side rather than underneath, enabling the T480s to be lighter. It also has a range of convenient ports, including the lightning-quick Thunderbolt 3. -
Brilliant, eye-catching display
With its vast array of vivid colours and wide-angle views, the display brings all your visuals, entertainment, and other multimedia to life.
- Lenovo ThinkPad T480s - 14" - Intel Core i7 - 8550U - 16 GB RAM - 512 GB SSD - 4G LTE - UK
- Product Type
- Notebook
- Operating System
- Win 10 Pro 64-bit
- Processor
- Intel Core i7 (8th Gen) - 8550U / 1.8 GHz, up to 4 GHz / 8 MB Cache
- Memory
- 16 GB DDR4 (1 x 8 GB + 8 GB (soldered))
- Storage
- 512 GB SSD - TCG Opal Encryption 2, NVMe
- Display
- 14" LED backlight 1920 x 1080 / Full HD
- Graphics
- Intel UHD Graphics 620
- Input Device
- TrackPoint, UltraNav
- Keyboard
- UK
- Keyboard Backlight
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac, Bluetooth 4.1, Gigabit Ethernet
- Wireless Broadband (WWAN)
- 4G LTE
- Battery
- Up to 15.6 hours
- Dockable
- Security
- Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader, smart card reader
- Black
- 33.1 cm x 22.68 cm x 1.845 cm
- 1.32 kg
- Localisation
- Manufacturer Selling Program
- TopSeller
- Environmental Standards
- ENERGY STAR Qualified EPEAT Silver
- Limited warranty - 3 years - pick-up and return , Limited warranty - battery - 1 year
- Product Type
- Notebook
- Operating System
- Windows 10 Pro 64-bit Edition
Processor / Chipset
- CPU
- Intel Core i7 (8th Gen) 8550U / 1.8 GHz
- Max Turbo Speed
- 4 GHz
- Number of Cores
- Quad-Core
- Cache
- 8 MB
- 64-bit Computing
- Hyper-Threading Technology, integrated memory controller, Intel Turbo Boost Technology 2.0, Intel Smart Cache
- RAM
- 16 GB (1 x 8 GB + 8 GB (soldered))
- Max RAM Supported
- 24 GB
- Technology
- DDR4 SDRAM
- Speed
- 2400 MHz
- Rated Speed
- 2400 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots Qty
- 1
- Empty Slots
- 0
Storage
- Main Storage
- 512 GB SSD M.2 PCIe - TCG Opal Encryption 2, NVM Express (NVMe)
Display
- 14" - IPS
- LCD Backlight Technology
- LED backlight
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Image Brightness
- 250 cd/m²
- Anti-glare
Audio & Video
- Graphics Processor
- Camera
- Yes - 720p
- Sound
- Stereo speakers, dual array microphone
- Codec
- Realtek ALC3287
- High Definition Audio, Dolby Audio Premium
Input
- Keyboard, TrackPoint, UltraNav
- Keyboard Layout
- UK
- Spill-resistant, multi-touch touchpad, buttonless touchpad
Communications
- Wireless
- Wireless Controller
- Intel Dual Band Wireless-AC 8265 - M.2 Card
- Network Interface
- Gigabit Ethernet
- Ethernet Controller
- Intel I219-V
- Generation
- 4G
- Technology
- LTE
- Controller
- FIBOCOM L830-EB - M.2 Card
- Technology
- Lithium Ion
- Capacity
- 57 Wh
- Run Time
- Up to 15.6 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 65 Watt
Connections & Expansion
- Slots
- 1 x Nano-SIM card (1 free)
- USB 3.1 Gen 1 , USB 3.1 Gen 1 (Always On) , USB-C 3.1 Gen 1 , USB-C 3.1 Gen 2 (supports Thunderbolt 3) , HDMI , LAN , Dock , Headphone/microphone combo jack
- Memory Card Reader
- 4 in 1 (SD Card, MultiMediaCard, SDHC Card, SDXC Card)
- Black
- Case Material
- Magnesium alloy, carbon fibre reinforced plastic
- Dockable
- Security
- Administrator password, hard drive password, power-on password, RapidCharge, MIL-STD-810G tested
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- Included Accessories
- USB-C power adapter
- RoHS
- Localization
- TopSeller
- 1.32 kg
Sustainability Information
- EPEAT Compliant
- EPEAT Silver
- ENERGY STAR Certified
