Lenovo ThinkPad T480 Core i7-8550U 8GB 256GB 14" Win 10 Pro
Quicklinx: DJSBWS00 Mfr#: 20L7001PUK
  • Core i7
  • IEEE 802.11n
Light, thin, and built to perform anywhere, the ThinkPad T480s delivers what you need, when you need it. Powerful processing and superb graphics take functional efficiency to different heights. In addition, the enhanced security features maintain maximum protection and peace of mind wherever you roam.
  • An IT manager's dream
    The ThinkPad T480s has a match-on-chip fingerprint reader, anti-spoofing technology that authenticates log-in credentials and helps safeguards your data, and a webcam cover that you can open and close.
  • Raises performance levels - and eyebrows
    Delivering higher performance, the processor is designed to take your productivity to different heights. Backed by the increased efficiency and speed of DDR4 memory, the T480s gives you the power of a desktop PC and the freedom of a portable laptop.
  • Where form meets function
    Inspired by ThinkPad customers, this ThinkPad has a USB-C docking connector on the side rather than underneath, enabling the T480s to be lighter. It also has a range of convenient ports, including the lightning-quick Thunderbolt 3.
  • Brilliant, eye-catching display
    With its vast array of vivid colours and wide-angle views, the display brings all your visuals, entertainment, and other multimedia to life.
Lenovo ThinkPad T480s - 14" - Intel Core i7 - 8550U - 8 GB RAM - 256 GB SSD - UK
Notebook
Operating System
Win 10 Pro 64-bit
Intel Core i7 (8th Gen) - 8550U / 1.8 GHz, up to 4 GHz / 8 MB Cache
8 GB DDR4 (provided memory is soldered)
Storage
256 GB SSD - TCG Opal Encryption 2, NVMe
Display
14" LED backlight 1920 x 1080 / Full HD
Graphics
Intel UHD Graphics 620
Input Device
TrackPoint, UltraNav
Keyboard
Keyboard Backlight
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.1, Gigabit Ethernet
Up to 15.6 hours
Dockable
Security
Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader, smart card reader
33.1 cm x 22.68 cm x 1.845 cm
1.32 kg
Manufacturer Selling Program
TopSeller
Environmental Standards
ENERGY STAR Qualified EPEAT Silver
Limited warranty - 3 years - pick-up and return , Limited warranty - battery - 1 year
Notebook
Operating System
Windows 10 Pro 64-bit Edition
Processor / Chipset
CPU
Intel Core i7 (8th Gen) 8550U / 1.8 GHz
Max Turbo Speed
4 GHz
Number of Cores
Quad-Core
Cache
8 MB
64-bit Computing
Hyper-Threading Technology, integrated memory controller, Intel Turbo Boost Technology 2.0, Intel Smart Cache
RAM
8 GB (provided memory is soldered)
Max RAM Supported
24 GB
DDR4 SDRAM
Speed
2400 MHz
Rated Speed
2400 MHz
SO-DIMM 260-pin
Slots Qty
1
Empty Slots
1
Storage
Main Storage
256 GB SSD M.2 PCIe - TCG Opal Encryption 2, NVM Express (NVMe)
Display
14" - IPS
LCD Backlight Technology
LED backlight
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Aspect Ratio
16:9
Image Brightness
250 cd/m²
Anti-glare
Audio & Video
Graphics Processor
Camera
Yes - 720p
Sound
Stereo speakers, dual array microphone
Codec
Realtek ALC3287
High Definition Audio, Dolby Audio Premium
Input
Keyboard, TrackPoint, UltraNav
Keyboard Backlight
Keyboard Layout
Spill-resistant, multi-touch touchpad, buttonless touchpad
Communications
Wireless
Wireless Controller
Intel Dual Band Wireless-AC 8265 - M.2 Card
Network Interface
Gigabit Ethernet
Ethernet Controller
Intel I219-V
Wireless Broadband (WWAN)
Generation
WWAN upgradable
Lithium Ion
57 Wh
Run Time
Up to 15.6 hours
AC Adapter
Input
Output
65 Watt
Connections & Expansion
Interfaces Details
USB 3.1 Gen 1 , USB 3.1 Gen 1 (Always On) , USB-C 3.1 Gen 1 , USB-C 3.1 Gen 2 (supports Thunderbolt 3) , HDMI , LAN , Dock , Headphone/microphone combo jack
Memory Card Reader
4 in 1 (SD Card, MultiMediaCard, SDHC Card, SDXC Card)
Case Material
Magnesium alloy, carbon fibre reinforced plastic
Dockable
Security
Administrator password, hard drive password, power-on password, RapidCharge, MIL-STD-810G tested
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
USB-C power adapter
RoHS
Localization
TopSeller
1.32 kg
Sustainability Information
TCO Certified
EPEAT Compliant
EPEAT Silver
ENERGY STAR Certified
Essential Accessories (6)
Get more from your purchase from one of our essential accessories
DJSB Lenovo 3M 14.0W Privacy Filter In Stock £37.84
DJSB Lenovo 45W Standard AC Adapter (USB Type-C) Power Adapter In Stock £26.01
DJSB Lenovo 65W Standard AC Adapter USB-C In Stock £29.56
DJSB Lenovo USB-C 65W AC Adapter AC 100-240 V 65Watt for ThinkPad A275 In Stock £29.56
DJSB Lenovo ThinkPad Hybrid USB-C with USB-A Dock - Do In Stock £194.89
DJSB Kensington Security Cable Lock In Stock £23.65
Other bundles (11)
DJSB Lenovo ThinkPad USB 3.0 Secure HDD-500GB In Stock £143.11
DJSB Lenovo HDMI to VGA Monitor Adapter In Stock £23.20
DJSB Lenovo USB3.0 To VGA/HDMI Adapter In Stock £63.85
DJSB Lenovo 2m HDMI Cable In Stock £17.02
DJSB Lenovo Professional Wireless Keyboard In Stock £53.47
DJSB Lenovo ThinkPad USB3.0 to Ethernet Adapter In Stock £16.07
DJSB Lenovo Essential Wired Keyboard and Mouse Combo - UK English In Stock £25.39
DJSB Lenovo ThinkVision T24d 24" 1920x1080 VGA HDMI DisplayPort IPS LED Monitor In Stock £202.02
DJSB Lenovo ThinkVision T27p-10 27" 3840x2160 HDMI DisplayPort USB-C IPS LED Monitor In Stock £454.54
DJSB Lenovo ThinkVision P27h-20 27" 2560x1440 6ms HDMI DisplayPort IPS LED Monitor In Stock £336.70
DJSB Lenovo ThinkVision T27q-20 27" 2560x1440 4ms HDMI DisplayPort IPS LED Monitor In Stock £321.24
