Lenovo ThinkPad T480 Core i5-8250U 8GB 256GB 14" Win 10 Pro
Quicklinx: DJS5WS00 Mfr#: 20L50000UK
Display Size: 14in
Processor Model: I5-8250U
Operating System: Windows 10 Pro 64-bit Edition
Installed Memory: 8GB, 8GB
Hard Drive Capacity: 256GB
  • Core i5
  • IEEE 802.11n
14 in stock
£951.56 ex VAT
£1,141.87 inc VAT
Raise the bar with the ThinkPad T480. Boasting the power-packed processors and an all-day battery, this 14" laptop is robust yet light enough to accompany you anywhere. Practical touches include a backlit keyboard and an array of ports, while the enhanced security features help safeguard your work wherever the job takes you.
  • An IT manager's dream
    The ThinkPad T480 has a match-on-chip fingerprint reader, anti-spoofing technology that authenticates log-in credentials and helps safeguards your data, and ThinkShutter, a webcam cover that you can open and close. It also has an integrated global LTE-A feature that keeps you connected around the world, Wi-Fi or not. Furthermore, to help save time setting up and deploying each T480, there's Microsoft AutoPilot. This cloud-based solution lets you preconfigure every laptop so that they are ready to use right out of the box.
  • Where form meets function
    Inspired by our ThinkPad customers, this latest T-Series business machine has a USB-C docking connector on the side rather than underneath, enabling the T480 to be thin. It also has a range of convenient ports, including the lightning-quick Intel Thunderbolt 3. In addition, should you need to work on the go or in low-light conditions, the renowned ThinkPad ergonomic keyboard has a convenient backlight.
  • Power up without powering down
    The T480 comes with built-in Power Bridge technology as standard. This innovation is the answer to 'low battery' warnings, especially if you are on the road or without a nearby power outlet. It allows you to swap out a battery and replace it with a fully charged one - without having to turn your machine off.
  • Stronger online security, made easy
    Signing into websites or making online payments usually involves trying to remember all kinds of passwords. Not so with the FIDO - Fast Identity Online - authentication capabilities that are built into the ThinkPad laptops. By wrapping your user info and credentials into three secure layers, FIDO makes it safer and easier when you are online. This global solution also creates better security of web-based services and reduces cost for organizations. A win-win for everyone.
Lenovo ThinkPad T480 - 14" - Core i5 8250U - 8 GB RAM - 256 GB SSD
Notebook
Operating System
Win 10 Pro 64-bit
Intel Core i5 (8th Gen) 8250U / 1.6 GHz (3.4 GHz) / 6 MB Cache
8 GB DDR4 (1 x 8 GB)
Storage
256 GB - M.2 SSD TCG Opal Encryption 2, NVMe
Optical Drive
No optical drive
Display
14" LED backlight 1920 x 1080 / Full HD
Graphics
Intel UHD Graphics 620
Input Device
TrackPoint, UltraNav
Keyboard Backlight
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.1, Gigabit Ethernet
Up to 14.4 hours
Dockable
Security
Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader, SmartCard reader
33.66 cm x 23.25 cm x 1.995 cm
1.65 kg
Manufacturer Selling Program
TopSeller
Environmental Standards
ENERGY STAR Qualified
Limited warranty - 3 years - pick-up and return , Limited warranty - battery - 1 year
Notebook
Operating System
Processor / Chipset
CPU
Max Turbo Speed
3.4 GHz
Number of Cores
Quad-Core
Cache
6 MB
64-bit Computing
Integrated memory controller
RAM
8 GB (1 x 8 GB)
Max RAM Supported
32 GB
DDR4 SDRAM
Speed
2400 MHz - 2400 MHz
SO-DIMM 260-pin
Slots Qty
2
Empty Slots
1
Storage
Main Storage
256 GB SSD - (M.2) PCIe - TCG Opal Encryption 2, NVM Express (NVMe)
Display
14" - IPS
LCD Backlight Technology
LED backlight
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Aspect Ratio
16:9
Image Brightness
250 cd/m²
Anti-glare
Audio & Video
Graphics Processor
Camera
Yes - 720p
Sound
Stereo speakers, dual array microphone
Codec
Realtek ALC3287
High Definition Audio, Dolby Audio Premium
Input
Keyboard, TrackPoint, UltraNav
Keyboard Backlight
Spill-resistant, multi-touch touchpad, buttonless touchpad
Communications
Wireless
Wireless Controller
Intel Dual Band Wireless-AC 8265 - M.2 Card
Network Interface
Gigabit Ethernet
Ethernet Controller
Intel I219-V
Lithium Ion
Installed Qty
2
24 Wh
Run Time
Up to 14.4 hours
AC Adapter
Input
Output
65 Watt
Connections & Expansion
USB 3.1 Gen 1 , USB 3.1 Gen 1 (Always On) , USB-C 3.1 Gen 1 , USB-C 3.1 Gen 2/Thunderbolt 3 , HDMI , Dock , Headphone/microphone combo jack , LAN
Memory Card Reader
4 in 1 (SD Card, MultiMediaCard, SDHC Card, SDXC Card)
Case Material
Glass-fibre reinforced plastic, polyphenylene sul?de
Dockable
Security
Administrator password, hard drive password, power-on password, MIL-STD-810G tested
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
USB-C power adapter
RoHS
Localization
TopSeller
1.65 kg
ENERGY STAR Certified
Software applications
Lenovo ThinkPad T480 Core i5-8250U 8GB 256GB 14 Bundle deal on Lenovo ThinkPad T480 Core i5-8250U 8GB 256GB 14" Win 10 Pro
£1,134.07
saving £8.33
£1,044.59
Essential Accessories (1)
Get more from your purchase from one of our essential accessories
DJS5 Lenovo Microsaver Security Cable Lock In Stock £23.87
Other bundles (1)
DJS5 Lenovo Optical 3-button W/Mouse USB In Stock £13.60
Display Size: 14in
Optical Storage: None
Graphics: Intel UHD Graphics 620
Hard Drive Type: SSD
Brand: Lenovo
Price Range Ex VAT: 750 - 1000
