Raise the bar with the ThinkPad T480. Boasting the power-packed processors and an all-day battery, this 14" laptop is robust yet light enough to accompany you anywhere. Practical touches include a backlit keyboard and an array of ports, while the enhanced security features help safeguard your work wherever the job takes you.
An IT manager's dream
The ThinkPad T480 has a match-on-chip fingerprint reader, anti-spoofing technology that authenticates log-in credentials and helps safeguards your data, and ThinkShutter, a webcam cover that you can open and close. It also has an integrated global LTE-A feature that keeps you connected around the world, Wi-Fi or not. Furthermore, to help save time setting up and deploying each T480, there's Microsoft AutoPilot. This cloud-based solution lets you preconfigure every laptop so that they are ready to use right out of the box. -
Where form meets function
Inspired by our ThinkPad customers, this latest T-Series business machine has a USB-C docking connector on the side rather than underneath, enabling the T480 to be thin. It also has a range of convenient ports, including the lightning-quick Intel Thunderbolt 3. In addition, should you need to work on the go or in low-light conditions, the renowned ThinkPad ergonomic keyboard has a convenient backlight. -
Power up without powering down
The T480 comes with built-in Power Bridge technology as standard. This innovation is the answer to 'low battery' warnings, especially if you are on the road or without a nearby power outlet. It allows you to swap out a battery and replace it with a fully charged one - without having to turn your machine off. -
Stronger online security, made easy
Signing into websites or making online payments usually involves trying to remember all kinds of passwords. Not so with the FIDO - Fast Identity Online - authentication capabilities that are built into the ThinkPad laptops. By wrapping your user info and credentials into three secure layers, FIDO makes it safer and easier when you are online. This global solution also creates better security of web-based services and reduces cost for organizations. A win-win for everyone.
- Lenovo ThinkPad T480 - 14" - Intel Core i5 - 8250U - 8 GB RAM - 256 GB SSD - UK
- Product Type
- Notebook
- Operating System
- Win 10 Pro 64-bit
- Processor
- Intel Core i5 (8th Gen) - 8250U / 1.6 GHz, up to 3.4 GHz / 6 MB Cache
- Memory
- 8 GB DDR4 (1 x 8 GB)
- Storage
- 256 GB SSD - TCG Opal Encryption 2, NVMe
- Display
- 14" LED backlight 1920 x 1080 / Full HD
- Graphics
- Intel UHD Graphics 620
- Input Device
- TrackPoint, UltraNav
- Keyboard
- UK
- Keyboard Backlight
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac, Bluetooth 4.1, Gigabit Ethernet
- Battery
- Up to 14.4 hours
- Dockable
- Security
- Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader, smart card reader
- Black
- 33.66 cm x 23.25 cm x 1.995 cm
- 1.65 kg
- Localisation
- Manufacturer Selling Program
- TopSeller
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - 3 years - pick-up and return , Limited warranty - battery - 1 year
- Product Type
- Notebook
- Operating System
- Windows 10 Pro 64-bit Edition
Processor / Chipset
- CPU
- Intel Core i5 (8th Gen) 8250U / 1.6 GHz
- Max Turbo Speed
- 3.4 GHz
- Number of Cores
- Quad-Core
- Cache
- 6 MB
- 64-bit Computing
- Hyper-Threading Technology, integrated memory controller, Intel Turbo Boost Technology 2.0, Intel Smart Cache
- RAM
- 8 GB (1 x 8 GB)
- Max RAM Supported
- 32 GB
- Technology
- DDR4 SDRAM
- Speed
- 2400 MHz
- Rated Speed
- 2400 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots Qty
- 2
- Empty Slots
- 1
Storage
- Main Storage
- 256 GB SSD M.2 PCIe - TCG Opal Encryption 2, NVM Express (NVMe)
Display
- 14" - IPS
- LCD Backlight Technology
- LED backlight
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Image Brightness
- 250 cd/m²
- Anti-glare, 170° viewing angle
Audio & Video
- Graphics Processor
- Camera
- Yes - 720p
- Sound
- Stereo speakers, dual array microphone
- Codec
- Realtek ALC3287
- High Definition Audio, Dolby Audio Premium
Input
- Keyboard, TrackPoint, UltraNav
- Keyboard Layout
- UK
- Spill-resistant, multi-touch touchpad, buttonless touchpad
Communications
- Wireless
- Wireless Controller
- Intel Dual Band Wireless-AC 8265 - M.2 Card
- Network Interface
- Gigabit Ethernet
- Ethernet Controller
- Intel I219-V
- Technology
- Lithium Ion
- Installed Qty
- 2
- Capacity
- 24 Wh
- Run Time
- Up to 14.4 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 65 Watt
Connections & Expansion
- Interfaces Details
- USB 3.1 Gen 1 , USB 3.1 Gen 1 (Always On) , USB-C 3.1 Gen 1 , USB-C 3.1 Gen 2 (supports Thunderbolt 3) , HDMI , Dock , Headphone/microphone combo jack , LAN
- Memory Card Reader
- 4 in 1 (SD Card, MultiMediaCard, SDHC Card, SDXC Card)
- Black
- Case Material
- Glass-fibre reinforced plastic, polyphenylene sulfide
- Dockable
- Security
- Administrator password, hard drive password, power-on password, MIL-STD-810G tested
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- Included Accessories
- USB-C power adapter
- RoHS
- Localization
- TopSeller
- 1.65 kg
Sustainability Information
- TCO Certified
- ENERGY STAR Certified
Essential Accessories (6)
Get more from your purchase from one of our essential accessories
Lenovo 3M 14.0W Privacy Filter | In Stock | £37.84 |
Lenovo 45W Standard AC Adapter (USB Type-C) Power Adapter | In Stock | £26.01 |
Lenovo 65W Standard AC Adapter USB-C | In Stock | £29.56 |
Lenovo USB-C 65W AC Adapter AC 100-240 V 65Watt for ThinkPad A275 | In Stock | £29.56 |
Lenovo ThinkPad Hybrid USB-C with USB-A Dock - Do | In Stock | £199.18 |
Kensington Security Cable Lock | In Stock | £23.65 |
Other bundles (8)
Lenovo ThinkPad USB 3.0 Secure HDD-500GB | In Stock | £143.11 |
Lenovo HDMI to VGA Monitor Adapter | In Stock | £23.20 |
Lenovo USB3.0 To VGA/HDMI Adapter | In Stock | £63.85 |
Lenovo 2m HDMI Cable | In Stock | £17.02 |
Lenovo Essential Wireless Keyboard and Mouse Combo - UK English 166 | In Stock | £41.29 |
Lenovo Professional Wireless Keyboard | In Stock | £53.21 |
Lenovo ThinkPad USB3.0 to Ethernet Adapter | In Stock | £16.07 |
Lenovo Essential Wired Keyboard and Mouse Combo - UK English | In Stock | £25.39 |
