Lenovo ThinkPad T470 20HF Core i7-7500U 8GB 256GB 14" Win 10 Pro
Quicklinx: CXRZWS00 Mfr#: 20HD000EUK
  • Core i7
  • IEEE 802.11n
With powerful processing and long battery life, the ThinkPad T470 is designed to enhance your productivity, anywhere. Easy to use, deploy, and service, this robust laptop has a host of cutting-edge technology, including fast storage, and secure fingerprint reading.
  • Performance you can count on
    With the responsiveness and efficiency of a powerful processor, the Lenovo ThinkPad T470 lets you switch effortlessly between your favorite apps - increasing your productivity, creativity, or entertainment levels along the way.
  • User-friendly, business-friendly
    Easy to set up and roll out, the T470 is also quick to service, upgrade, and secure. From an everyday user to an IT technician, this business laptop is designed to make life (and work) easier for everyone.
  • Make light work of long days
    The T470 gives you greater flexibility and hours of power on a single charge. That's more than enough juice to help you burn the midnight oil or binge-watch your favorite show.
  • For on-the-go productivity and entertainment
    The T470 gives you portability, without sacrificing performance. Its stunning display delivers sharp, vibrant visuals - perfect for working on the go or kicking back to enjoy a movie.
  • Stay connected, even when you're not
    With super-fast connectivity, the T470 gives you prompt access to all your cloud data and apps - even if you are out of Wi-Fi range.
  • Look sharp, sound sharper
    The T470 has an HD web camera and dual-array microphones (with background noise reduction) as standard - ideal for whether you're on a call in a busy open-plan office or a bustling coffee shop.
Lenovo ThinkPad T470 - 14" - Intel Core i7 - 7500U - 8 GB RAM - 256 GB SSD - UK
Notebook
Operating System
Win 10 Pro 64-bit
Intel Core i7 (7th Gen) - 7500U / 2.7 GHz, up to 3.5 GHz / 4 MB Cache
8 GB DDR4
Storage
256 GB SSD - TCG Opal Encryption 2, NVMe
Display
14" LED backlight 1920 x 1080 / Full HD
Graphics
Intel HD Graphics 620
Input Device
TrackPoint, UltraNav
Keyboard
Keyboard Backlight
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.1, Gigabit Ethernet
3-cell - up to 6.9 hours
Dockable
Security
Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader, smart card reader
33.66 cm x 23.25 cm x 1.995 cm
1.58 kg
Manufacturer Selling Program
TopSeller
Environmental Standards
- ENERGY STAR Qualified EPEAT Climate+
Limited warranty - 3 years - on-site
Notebook
Operating System
Windows 10 Pro 64-bit Edition
Processor / Chipset
CPU
Intel Core i7 (7th Gen) 7500U / 2.7 GHz
Max Turbo Speed
3.5 GHz
Number of Cores
Dual-Core
Cache
4 MB
64-bit Computing
Hyper-Threading Technology, integrated memory controller, Intel Turbo Boost Technology 2.0
RAM
8 GB
Max RAM Supported
32 GB
DDR4 SDRAM
Speed
2133 MHz / PC4-17000
Rated Speed
2133 MHz
SO-DIMM 260-pin
Slots Qty
2
Storage
Main Storage
256 GB SSD M.2 PCIe - TCG Opal Encryption 2, NVM Express (NVMe)
Display
14" - IPS
LCD Backlight Technology
LED backlight
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Aspect Ratio
16:9
Image Brightness
250 cd/m²
Anti-glare
Audio & Video
Graphics Processor
Camera
Yes - 720p
Sound
Stereo speakers, dual array microphone
Codec
Realtek ALC3268
High Definition Audio
Input
Keyboard, TrackPoint, UltraNav
Keyboard Backlight
Keyboard Layout
Spill-resistant, multi-touch touchpad, buttonless touchpad
Communications
Wireless
Wireless Controller
Intel Dual Band Wireless-AC 8265 - M.2 Card
Network Interface
Gigabit Ethernet
3-cell Lithium Ion
Installed Qty
2
Max Supported Qty
2
24 Wh
Run Time
Up to 6.9 hours
AC Adapter
Input
Output
45 Watt, 20 V
Connections & Expansion
Interfaces Details
USB 3.1 Gen 1/USB 3.0 (Always On) , 2 x USB 3.1 Gen 1/USB 3.0 , USB-C 3.1 Gen 2 (supports Thunderbolt 3, DisplayPort Alt Mode) (Power Delivery 2.0) , HDMI , LAN , Dock , Headphone/microphone combo jack
Memory Card Reader
Yes (SD Card, SDXC UHS Card)
Case Material
Glass-fibre reinforced plastic
Dockable
Security
Administrator password, hard drive password, power-on password, MIL-STD-810G tested
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Power adapter
RoHS
Localization
TopSeller
1.58 kg
Sustainability Information
TCO Certified
EPEAT Compliant
EPEAT Climate+
ENERGY STAR Certified
