With powerful processors, plus amazing graphics on a brilliant display, the ThinkPad P72 sets higher standards in mobile workstations.
See the difference
With 4x the resolution of FHD and 400 nits brightness, the ThinkPad P72's 4K UHD display option delivers pin-sharp visuals and wide-angle viewing. With a 100% Adobe color gamut and a 10-bit color depth, it supports over 1 billion colors. Perfect for everyone from researchers and scientists to digital artists and entertainment buffs. -
Get more done, more quickly
The ThinkPad P72 comes with Intel Thunderbolt 3 technology, enabling you to enjoy more speed, pixels, and power than any other USB-C port. And with dual Thunderbolt 3 ports, you can simultaneously use a 4K display and high-performance storage device-and tap blazingly-fast speeds at up to 40 Gbps. -
See visual computing in a new light
For the ultimate in on-the-go productivity, there's NVIDIA Quadro graphics. So why not opt for the highest card that a workstation can handle, with the P5200? It's designed to take your visual computing to new heights-from complex simulations and deep learning to the new worlds of virtual reality. -
What are you waiting for?
With the optional Intel Optane memory, a faster, smoother, and amazingly more responsive PC experience awaits. Working in tandem with your hard disk drive, it can recognize the way you work and create. As a result, everything's accelerated from everyday computing and opening media-rich files to loading high-performance datasets and professional ISV applications. -
Windows 10 Pro, built for business
With Windows 10 Pro and ThinkPad P72, you can empower yourself and your business to do great things securely across your other devices anywhere-with anyone, any time. Easy to use, it helps you can get more done right from the start. -
More bang for your buck
The ThinkPad P72 has a host of features as standard, such as Flex Performance Cooling, dual-fan technology that lets you push the boundaries of productivity and creativity. There's also the legendary ThinkPad keyboard, award winning and spill resistant, it's optimized for a more comfortable typing experience. -
Ready for today, tomorrow,& beyond
With proven performance and software stability, the ThinkPad P72 has been thoroughly tested by industry-leading independent software vendors (ISVs). It has also been certified VR-ready, so you can tap the world of professional AR/VR without sacrificing mobility. -
Advanced security from the get-go
With Windows Hello and the optional advanced infrared camera, you can log in to your ThinkPad P72 with just a smile. There's also a match-on-chip fingerprint reader, providing you with the most secure fingerprint technology on a PC. And the dTPM 2.0 chip encrypts all your personal data automatically.
- Lenovo ThinkPad P72 - 17.3" - Intel Core i7 8750H - 8 GB RAM - 256 GB SSD - UK
- Product Type
- Mobile workstation
- Operating System
- Win 10 Pro 64-bit
- Processor
- Intel Core i7 (8th Gen) 8750H / 2.2 GHz (4.1 GHz) / 9 MB Cache
- Memory
- 8 GB DDR4 (1 x 8 GB)
- Storage
- 256 GB SSD - TCG Opal Encryption 2, NVMe
- Display
- 17.3" LED backlight 1920 x 1080 / Full HD
- Graphics
- NVIDIA Quadro P2000 / Intel UHD Graphics 630
- Video Memory
- 4 GB GDDR5 SDRAM
- Input Device
- Keyboard, TrackPoint, UltraNav
- Keyboard
- UK
- Keyboard Backlight
- Numeric Keypad
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac, Bluetooth 5.0, Gigabit Ethernet
- Battery
- Up to 16 hours
- Security
- Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader, smart card reader
- Black
- 41.6 cm x 28.1 cm x 2.94 cm
- 3.4 kg
- Localisation
- Manufacturer Selling Program
- TopSeller
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - 3 years - on-site , Limited warranty - battery - 1 year
- Product Type
- Operating System
- Windows 10 Pro 64-bit Edition
Processor / Chipset
- CPU
- Max Turbo Speed
- 4.1 GHz
- Number of Cores
- 6-core
- Cache
- 9 MB
- 64-bit Computing
- Chipset
- Mobile Intel CM246
- Integrated memory controller
- RAM
- 8 GB (1 x 8 GB)
- Max RAM Supported
- 128 GB
- Technology
- DDR4 SDRAM - non-ECC
- Speed
- 2400 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots Qty
- 4
- Empty Slots
- 3
Storage
- Main Storage
- 256 GB SSD M.2 PCIe - TCG Opal Encryption 2, NVM Express (NVMe)
Display
- 17.3" - IPS
- LCD Backlight Technology
- LED backlight
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Image Brightness
- 300 cd/m²
- Colour Gamut
- 72%
- Anti-glare
Audio & Video
- Multi-GPU Configuration
- 1 single GPU card / integrated GPU
- Graphics Processor
- Video Memory
- 4 GB GDDR5 SDRAM
- Camera
- Yes - 720p
- Camera Features
- IR camera
- Sound
- Stereo speakers, dual array microphone
- Codec
- Realtek ALC3286
- High Definition Audio, Dolby Audio Premium, Dolby Atmos
Input
- Keyboard Layout
- UK
- Numeric Keypad
- Spill-resistant, multi-touch touchpad
Communications
- Wireless
- Wireless Controller
- Intel Wireless-AC 9560 - M.2 Card
- Network Interface
- Gigabit Ethernet
- Ethernet Controller
- Intel I219-LM
- Technology
- Lithium Ion
- Capacity
- 99 Wh
- Run Time
- Up to 16 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 230 Watt
Connections & Expansion
- USB 3.1 Gen 1 (Always On) , 3 x USB 3.1 Gen 1 , 2 x USB-C (supports Thunderbolt 3) , Mini DisplayPort , HDMI , LAN , Headphone/microphone combo jack
- Memory Card Reader
- 4 in 1 (SD Card, MultiMediaCard, SDHC Card, SDXC Card, SDXC UHS-II Card)
- Black
- Case Material
- Glass-fibre reinforced plastic, magnesium-aluminum alloy, polyphenylene sulfide
- Security
- Administrator password, hard drive password, power-on password, MIL-STD-810G tested
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- Included Accessories
- Power adapter
- RoHS
- Localization
- TopSeller
- 3.4 kg
Sustainability Information
- ENERGY STAR Certified
Essential Accessories (2)
Get more from your purchase from one of our essential accessories
Lenovo MiniDisplayPort to HDMI Cable | In Stock | £17.02 |
Kensington Security Cable Lock | In Stock | £23.65 |
Other bundles (12)
Lenovo Mini Displayport to Displayport Cable | In Stock | £15.46 |
Lenovo ThinkPad USB 3.0 Secure HDD-500GB | In Stock | £143.11 |
Lenovo HDMI to VGA Monitor Adapter | In Stock | £23.20 |
Lenovo USB3.0 To VGA/HDMI Adapter | In Stock | £63.85 |
Lenovo 2m HDMI Cable | In Stock | £17.02 |
Lenovo ThinkPad USB3.0 to Ethernet Adapter | In Stock | £16.07 |
Lenovo Essential Wired Keyboard and Mouse Combo - UK English | In Stock | £25.39 |
Lenovo ThinkVision M14 14" 1920x1080 6ms USB-C IPS LED Monitor | In Stock | £258.14 |
Lenovo ThinkVision T24d 24" 1920x1080 VGA HDMI DisplayPort IPS LED Monitor | In Stock | £202.02 |
Lenovo ThinkVision T27p-10 27" 3840x2160 HDMI DisplayPort USB-C IPS LED Monitor | In Stock | £454.54 |
Lenovo ThinkVision P27h-20 27" 2560x1440 6ms HDMI DisplayPort IPS LED Monitor | In Stock | £336.70 |
Lenovo ThinkVision T27q-20 27" 2560x1440 4ms HDMI DisplayPort IPS LED Monitor | In Stock | £321.24 |
