Lenovo ThinkPad P72 Intel Core i7-8750H 8GB 256GB SSD 17.3" Windows 10 Professional 64-bit
Quicklinx: FGZPWS00 Mfr#: 20MB0007UK
  • Core i7
  • IEEE 802.11n
With powerful processors, plus amazing graphics on a brilliant display, the ThinkPad P72 sets higher standards in mobile workstations.
  • See the difference
    With 4x the resolution of FHD and 400 nits brightness, the ThinkPad P72's 4K UHD display option delivers pin-sharp visuals and wide-angle viewing. With a 100% Adobe color gamut and a 10-bit color depth, it supports over 1 billion colors. Perfect for everyone from researchers and scientists to digital artists and entertainment buffs.
  • Get more done, more quickly
    The ThinkPad P72 comes with Intel Thunderbolt 3 technology, enabling you to enjoy more speed, pixels, and power than any other USB-C port. And with dual Thunderbolt 3 ports, you can simultaneously use a 4K display and high-performance storage device-and tap blazingly-fast speeds at up to 40 Gbps.
  • See visual computing in a new light
    For the ultimate in on-the-go productivity, there's NVIDIA Quadro graphics. So why not opt for the highest card that a workstation can handle, with the P5200? It's designed to take your visual computing to new heights-from complex simulations and deep learning to the new worlds of virtual reality.
  • What are you waiting for?
    With the optional Intel Optane memory, a faster, smoother, and amazingly more responsive PC experience awaits. Working in tandem with your hard disk drive, it can recognize the way you work and create. As a result, everything's accelerated from everyday computing and opening media-rich files to loading high-performance datasets and professional ISV applications.
  • Windows 10 Pro, built for business
    With Windows 10 Pro and ThinkPad P72, you can empower yourself and your business to do great things securely across your other devices anywhere-with anyone, any time. Easy to use, it helps you can get more done right from the start.
  • More bang for your buck
    The ThinkPad P72 has a host of features as standard, such as Flex Performance Cooling, dual-fan technology that lets you push the boundaries of productivity and creativity. There's also the legendary ThinkPad keyboard, award winning and spill resistant, it's optimized for a more comfortable typing experience.
  • Ready for today, tomorrow,& beyond
    With proven performance and software stability, the ThinkPad P72 has been thoroughly tested by industry-leading independent software vendors (ISVs). It has also been certified VR-ready, so you can tap the world of professional AR/VR without sacrificing mobility.
  • Advanced security from the get-go
    With Windows Hello and the optional advanced infrared camera, you can log in to your ThinkPad P72 with just a smile. There's also a match-on-chip fingerprint reader, providing you with the most secure fingerprint technology on a PC. And the dTPM 2.0 chip encrypts all your personal data automatically.
Lenovo ThinkPad P72 - 17.3" - Intel Core i7 8750H - 8 GB RAM - 256 GB SSD - UK
Mobile workstation
Operating System
Win 10 Pro 64-bit
Intel Core i7 (8th Gen) 8750H / 2.2 GHz (4.1 GHz) / 9 MB Cache
8 GB DDR4 (1 x 8 GB)
Storage
256 GB SSD - TCG Opal Encryption 2, NVMe
Display
17.3" LED backlight 1920 x 1080 / Full HD
Graphics
NVIDIA Quadro P2000 / Intel UHD Graphics 630
Video Memory
4 GB GDDR5 SDRAM
Input Device
Keyboard, TrackPoint, UltraNav
Keyboard
Keyboard Backlight
Numeric Keypad
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 5.0, Gigabit Ethernet
Up to 16 hours
Security
Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader, smart card reader
41.6 cm x 28.1 cm x 2.94 cm
3.4 kg
Manufacturer Selling Program
TopSeller
Environmental Standards
ENERGY STAR Qualified
Limited warranty - 3 years - on-site , Limited warranty - battery - 1 year
Mobile workstation
Operating System
Windows 10 Pro 64-bit Edition
Processor / Chipset
CPU
Max Turbo Speed
4.1 GHz
Number of Cores
6-core
Cache
9 MB
64-bit Computing
Chipset
Mobile Intel CM246
Integrated memory controller
RAM
8 GB (1 x 8 GB)
Max RAM Supported
128 GB
DDR4 SDRAM - non-ECC
Speed
2400 MHz
SO-DIMM 260-pin
Slots Qty
4
Empty Slots
3
Storage
Main Storage
256 GB SSD M.2 PCIe - TCG Opal Encryption 2, NVM Express (NVMe)
Display
17.3" - IPS
LCD Backlight Technology
LED backlight
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Aspect Ratio
16:9
Image Brightness
300 cd/m²
Colour Gamut
72%
Anti-glare
Audio & Video
Multi-GPU Configuration
1 single GPU card / integrated GPU
Graphics Processor
Video Memory
4 GB GDDR5 SDRAM
Camera
Yes - 720p
Camera Features
IR camera
Sound
Stereo speakers, dual array microphone
Codec
Realtek ALC3286
High Definition Audio, Dolby Audio Premium, Dolby Atmos
Input
Keyboard Backlight
Keyboard Layout
Numeric Keypad
Spill-resistant, multi-touch touchpad
Communications
Wireless
Wireless Controller
Intel Wireless-AC 9560 - M.2 Card
Network Interface
Gigabit Ethernet
Ethernet Controller
Intel I219-LM
Lithium Ion
99 Wh
Run Time
Up to 16 hours
AC Adapter
Input
Output
230 Watt
Connections & Expansion
USB 3.1 Gen 1 (Always On) , 3 x USB 3.1 Gen 1 , 2 x USB-C (supports Thunderbolt 3) , Mini DisplayPort , HDMI , LAN , Headphone/microphone combo jack
Memory Card Reader
4 in 1 (SD Card, MultiMediaCard, SDHC Card, SDXC Card, SDXC UHS-II Card)
Case Material
Glass-fibre reinforced plastic, magnesium-aluminum alloy, polyphenylene sulfide
Security
Administrator password, hard drive password, power-on password, MIL-STD-810G tested
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Power adapter
RoHS
Localization
TopSeller
3.4 kg
Sustainability Information
ENERGY STAR Certified
Essential Accessories (2)
Get more from your purchase from one of our essential accessories
FGZP Lenovo MiniDisplayPort to HDMI Cable In Stock £17.02
FGZP Kensington Security Cable Lock In Stock £23.65
Other bundles (13)
FGZP Lenovo Mini Displayport to Displayport Cable In Stock £15.46
FGZP Lenovo ThinkPad USB 3.0 Secure HDD-500GB In Stock £143.11
FGZP Lenovo HDMI to VGA Monitor Adapter In Stock £23.20
FGZP Lenovo USB3.0 To VGA/HDMI Adapter In Stock £63.85
FGZP Lenovo 2m HDMI Cable In Stock £17.02
FGZP Lenovo Professional Wireless Keyboard In Stock £53.47
FGZP Lenovo ThinkPad USB3.0 to Ethernet Adapter In Stock £16.07
FGZP Lenovo Essential Wired Keyboard and Mouse Combo - UK English In Stock £25.39
FGZP Lenovo ThinkVision M14 14" 1920x1080 6ms USB-C IPS LED Monitor In Stock £258.14
FGZP Lenovo ThinkVision T24d 24" 1920x1080 VGA HDMI DisplayPort IPS LED Monitor In Stock £202.02
FGZP Lenovo ThinkVision T27p-10 27" 3840x2160 HDMI DisplayPort USB-C IPS LED Monitor In Stock £454.54
FGZP Lenovo ThinkVision P27h-20 27" 2560x1440 6ms HDMI DisplayPort IPS LED Monitor In Stock £336.70
FGZP Lenovo ThinkVision T27q-20 27" 2560x1440 4ms HDMI DisplayPort IPS LED Monitor In Stock £321.24
