The ThinkPad P71 redefines the concept of power with an Intel Xeon processor and NVIDIA Quadro graphics. Feature-packed with optional X-Rite PANTONE color calibration, Mil-Spec durability, blazing-fast connection speeds, and the highest capacity of storage and memory make this workstation your go-to PC for getting the job done.
Dazzling display
Choose a 4K UHD display With IPS technology, and get vivid colors and nearly 180-degree viewing angles. X-Rite PANTONE color calibration yields greater image accuracy, more precise color matching, and a consistently true display. Dual Intel Thunderbolt 3 ports revolutionizes connection technology - simultaneously supporting high-resolution displays and high-performance data devices through a single, compact port. Your choice of 4 different NVIDIA Quadro graphics cards ensures there is a graphic solution to fit your need. -
Impressive extras built in
The ThinkPad P71 features Lenovo's award-winning keyboard, which is made better with a redesigned Touchpad. Full-sized and spill-resistant, the legendary ThinkPad ergonomic keyboard is renowned for its full array of keys, excellent feel, and TrackPoint pointing device. Flex performance cools with dual quiet fans for better performance and reliability. Because you demand proven performance and software stability, Lenovo ensures that more than 100 applications are ISV certified. For true mobility, configure your laptop with WWAN connectivity, so you can access 3G or 4G networks provided by a third-party cellular phone service company (subscription required). -
Powerful performance
PC performance has never been faster. Intel Core and Xeon processors with built-in security are designed to take your productivity, creativity, and 3D gaming to the next level. Intel vPro Technology makes enterprise-level manageability even more convenient and efficient. And with the ThinkPad you can empower yourself and your business to do great things across many devices securely anywhere, with anyone, and at any time. Fitting a variety of budgets, it's also very easy to use. So you can get more done right from the start. -
Audio clarity from Dolby
Dolby Home Theater maximizes volume output of the built-in stereo speakers without distortion - enjoy a crisp, clear, immersive surround sound experience with all the power and nuance of the cinema, and all the immediacy of live performance.
- Lenovo ThinkPad P71 - 17.3" - Intel Xeon - E3-1505MV6 - vPro - 16 GB RAM - 512 GB SSD - UK
- Product Type
- Mobile workstation
- Operating System
- Win 10 Pro 64-bit
- Platform Technology
- Intel vPro Platform
- Processor
- Intel Xeon E3-1505MV6 / 3 GHz, up to 4 GHz / 8 MB Cache
- Memory
- 16 GB DDR4 (2 x 8 GB)
- Storage
- 512 GB SSD - TCG Opal Encryption 2, NVMe
- Optical Drive
- DVD-Writer
- Display
- 17.3" LED backlight 3840 x 2160 / Ultra HD 4K
- Graphics
- NVIDIA Quadro P4000 / Intel HD Graphics P630
- Video Memory
- 8 GB
- Input Device
- Keyboard, TrackPoint, UltraNav
- Keyboard
- UK
- Keyboard Backlight
- Numeric Keypad
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac, Bluetooth 4.1, Gigabit Ethernet
- Battery
- 8-cell - up to 14.25 hours
- X-Rite Pantone colour calibration sensor
- Dockable
- Security
- Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader, smart card reader
- Black
- 41.6 cm x 27.55 cm x 3.42 cm
- 3.3 kg
- Localisation
- Manufacturer Selling Program
- TopSeller
- Environmental Standards
- - ENERGY STAR Qualified EPEAT Climate+
- Limited warranty - 3 years - on-site , Limited warranty - battery - 1 year
- Product Type
- Operating System
- Windows 10 Pro 64-bit Edition
Processor / Chipset
- CPU
- Max Turbo Speed
- 4 GHz
- Number of Cores
- Quad-Core
- Cache
- 8 MB
- 64-bit Computing
- Chipset
- Mobile Intel CM238
- Integrated memory controller
- RAM
- 16 GB (2 x 8 GB)
- Max RAM Supported
- 64 GB
- Technology
- DDR4 SDRAM - ECC
- Speed
- 2400 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots Qty
- 4
- Empty Slots
- 2
Storage
- Main Storage
- 512 GB SSD M.2 PCIe - TCG Opal Encryption 2, NVM Express (NVMe)
- Optical Drive
- DVD-Writer - tray
Display
- 17.3" - IPS
- LCD Backlight Technology
- LED backlight
- Resolution
- 3840 x 2160 (Ultra HD 4K)
- Widescreen
- Image Aspect Ratio
- 16:9
- Image Brightness
- 300 cd/m²
- Colour Gamut
- 90%
- Anti-glare
Audio & Video
- Multi-GPU Configuration
- 1 single GPU card / integrated GPU
- Graphics Processor
- Video Memory
- 8 GB
- Camera
- Yes - 720p
- Sound
- Stereo speakers, dual array microphone
- Codec
- Realtek ALC3268
- High Definition Audio
Input
- Keyboard Layout
- UK
- Numeric Keypad
- Spill-resistant, multi-touch touchpad
Communications
- Wireless
- Wireless Controller
- Intel Dual Band Wireless-AC 8265 - M.2 Card
- Network Interface
- Gigabit Ethernet
- Ethernet Controller
- Intel I219-LM
Wireless Broadband (WWAN)
- Generation
- WWAN upgradable
- Technology
- 8-cell Lithium Ion
- Capacity
- 96 Wh
- Run Time
- Up to 14.25 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 230 Watt
Connections & Expansion
- Slots
- 1 x ExpressCard/34 (1 free)
- Interfaces Details
- 3 x USB 3.1 Gen 1/USB 3.0 , USB 3.1 Gen 1/USB 3.0 (Always On) , 2 x USB-C (supports Thunderbolt 3) , Mini DisplayPort , HDMI , LAN , Dock , Headphone/microphone combo jack
- Memory Card Reader
- 4 in 1 (SD Card, MultiMediaCard, SDHC Card, SDXC Card, SDXC UHS-II Card)
Software
- Software Included
- Lenovo Companion, Lenovo Settings
- Black
- Case Material
- Glass-fibre, magnesium-aluminum alloy, polyphenylene sulfide
- Integrated Options
- Dockable
- Security
- Administrator password, hard drive password, power-on password, Intel Active Management Technology (iAMT), MIL-STD-810G tested
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- Included Accessories
- Power adapter
- RoHS
- Localization
- TopSeller
- 3.3 kg
Sustainability Information
- TCO Certified
- ENERGY STAR Certified
