The ThinkPad P50s takes mobility and performance to a higher level. Made for professionals on the go, the P50s features the efficient processor and professional graphics. Lenovo’s thin and light full-function mobile workstation also will last as long as you can use Power Bridge technology. The ThinkPad P50s offers durability and features a beautiful 15.6" 3K IPS display.
Mobile performance
Thin, light and powerful using the efficient processor, impressive graphics card, capacitive memory and flexible storage. -
Powered up
Power Bridge technology lets users hot-swap the rear battery, giving you freedom from the plug. Power Bridge uses two batteries to keep you going at all times. -
Stunning visuals
It boasts an ultra high resolution 3K IPS anti-glare display with wide viewing angles.
- Lenovo ThinkPad P50s - 15.6" - Intel Core i7 - 6500U - 8 GB RAM - 256 GB SSD - UK
- Product Type
- Mobile workstation
- Operating System
- Win 7 Pro 64-bit (downgrade from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence
- Processor
- Intel Core i7 (6th Gen) - 6500U / 2.5 GHz, up to 3.1 GHz / 4 MB Cache
- Memory
- 8 GB DDR3L (1 x 8 GB)
- Storage
- 256 GB SSD - TCG Opal Encryption 2
- Display
- 15.6" LED backlight 1920 x 1080 / Full HD
- Graphics
- NVIDIA Quadro M500M / Intel HD Graphics 520
- Video Memory
- 2 GB
- Input Device
- Keyboard, TrackPoint, UltraNav
- Keyboard
- UK
- Keyboard Backlight
- Numeric Keypad
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac, Bluetooth 4.1, Gigabit Ethernet
- Battery
- 3-cell
- Dockable
- Security
- Trusted Platform Module (TPM 1.2) Security Chip, fingerprint reader, smart card reader
- 38.06 cm x 25.82 cm x 2.245 cm
- 2.47 kg
- Localisation
- Manufacturer Selling Program
- TopSeller
- Environmental Standards
- - ENERGY STAR Qualified EPEAT Climate+
- Limited warranty - 3 years - on-site , Limited warranty - battery - 1 year
- Product Type
- Operating System
- Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence
Processor / Chipset
- CPU
- Intel Core i7 (6th Gen) 6500U / 2.5 GHz
- Max Turbo Speed
- 3.1 GHz
- Number of Cores
- Dual-Core
- Cache
- 4 MB
- 64-bit Computing
- Integrated memory controller
- RAM
- 8 GB (1 x 8 GB)
- Max RAM Supported
- 32 GB
- Technology
- DDR3L SDRAM
- Speed
- 1600 MHz / PC3L-12800
- Rated Speed
- 1600 MHz
- Form Factor
- SO-DIMM 204-pin
- Slots Qty
- 2
- Empty Slots
- 1
Storage
- Main Storage
- 256 GB SSD SATA 6Gb/s - TCG Opal Encryption 2
Display
- 15.6" - IPS
- LCD Backlight Technology
- LED backlight
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Image Brightness
- 250 cd/m²
- Anti-glare
Audio & Video
- Multi-GPU Configuration
- 1 single GPU card / integrated GPU
- Graphics Processor
- Video Memory
- 2 GB
- Camera
- Yes - 720p
- Sound
- Stereo speakers, two microphones
- Codec
- Realtek ALC3245
- High Definition Audio
Input
- Keyboard Layout
- UK
- Numeric Keypad
- Spill-resistant, multi-touch touchpad, buttonless touchpad
Communications
- Wireless
- Wireless Controller
- Intel Dual Band Wireless-AC 8260 - M.2 Card
- Network Interface
- Gigabit Ethernet
- Ethernet Controller
- Intel I219-V
Wireless Broadband (WWAN)
- Generation
- WWAN upgradable
- Technology
- 3-cell lithium polymer
- Max Supported Qty
- 2
- Capacity
- 44 Wh
- Run Time With Included Additional Battery
- Up to 20.5 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 65 Watt, 20 V
Connections & Expansion
- Interfaces Details
- 3 x USB 3.0 , Mini DisplayPort , HDMI , LAN , Dock , Headphone/microphone combo jack
- Memory Card Reader
- 4 in 1 (SD Card, MultiMediaCard, SDHC Card, SDXC Card, SDXC UHS-II Card)
Software
- Software Included
- ThinkVantage Rescue and Recovery, Adobe Reader, ThinkVantage System Update, ThinkVantage Product Recovery, Lenovo Solution Center, McAfee LiveSafe (30 days trial)
- Case Material
- Glass-fibre reinforced plastic, polyphenylene sulfide
- Dockable
- Security
- Administrator password, hard drive password, power-on password, 1 USB 3.0 (Always On), ThinkEngine, MIL-STD-810G tested
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- Included Accessories
- Power adapter, 6-cell Li-Ion 72Wh battery
- RoHS, GREENGUARD
- Localization
- TopSeller
- 2.47 kg
Sustainability Information
- TCO Certified
- EPEAT Compliant
- EPEAT Climate+
- ENERGY STAR Certified
