Lenovo ThinkPad P43s Intel Core i7-8565U 8GB 256GB SSD 14" Windows 10 Professional 64-bit
Quicklinx: FPT0WS00 Mfr#: 20RH0029UK
  • Core i7
  • IEEE 802.11n
The ThinkPad P43s mobile workstation is ideal for light-duty computer-aided design (CAD) in fields such as architecture or engineering, as well as technical education such as STEM. It includes ISV certification from major vendors such as Autodesk, Siemens NX, SketchUp, SolidWorks, and more.
  • Don't miss a sound
    User-facing speakers and dual far-field mic help provide a premium audio experience. Dolby Audio delivers a rich, powerful sound that adjusts, to deliver home theater quality in a virtual surround sound experience. This is listening, made easy.
  • Built to withstand almost anything
    The ThinkPad P43s mobile workstation is tested against 12 military-grade requirements and more than 200 quality checks, to ensure it will run in extreme conditions. You can rely on it from the Arctic wilderness to desert dust storms, from zero gravity to spills and drops. Its durability will keep it working for you.
  • Keeps your data and your privacy safe
    This mobile workstation's security features protect your business-critical info. Its discrete Trusted Platform Module (dTPM) encrypts data and works in conjunction with integrated security features. ThinkShutter, a physical camera cover, blocks the lens to ensure that you're only seen when you want to be.
Lenovo ThinkPad P43s - 14" - Intel Core i7 8565U - 8 GB RAM - 256 GB SSD - UK
Mobile workstation
Operating System
Win 10 Pro 64-bit - English
Intel Core i7 (8th Gen) 8565U / 1.8 GHz (4.6 GHz) / 8 MB Cache
8 GB DDR4 (provided memory is soldered)
Storage
256 GB SSD - TCG Opal Encryption 2, NVMe
Display
14" LED backlight 1920 x 1080 / Full HD
Graphics
NVIDIA Quadro P520 / Intel UHD Graphics 620
Video Memory
2 GB GDDR5 SDRAM
Input Device
Keyboard, TrackPoint, UltraNav
Keyboard
Keyboard Backlight
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 5.0, Gigabit Ethernet
Up to 14.7 hours
Dockable
Security
Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader, smart card reader
32.9 cm x 22.7 cm x 1.79 cm
1.55 kg
Manufacturer Selling Program
TopSeller
Environmental Standards
ENERGY STAR Qualified EPEAT Silver
Limited warranty - 3 years - on-site , Limited warranty - battery - 1 year
Mobile workstation
Operating System
Windows 10 Pro 64-bit Edition - English
Processor / Chipset
CPU
Max Turbo Speed
4.6 GHz
Number of Cores
Quad-Core
Cache
8 MB
64-bit Computing
Integrated memory controller
RAM
8 GB (provided memory is soldered)
Max RAM Supported
40 GB
DDR4 SDRAM
Speed
2400 MHz
Rated Speed
2666 MHz
SO-DIMM 260-pin
Slots Qty
1
Empty Slots
1
Storage
Main Storage
256 GB SSD M.2 2280 PCIe 3.0 x4 - TCG Opal Encryption 2, NVM Express (NVMe)
Display
14" - IPS
LCD Backlight Technology
LED backlight
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Aspect Ratio
16:9
Image Brightness
250 cd/m²
Colour Gamut
45%
Anti-glare, 170° viewing angle
Audio & Video
Multi-GPU Configuration
1 single GPU card / integrated GPU
Graphics Processor
Video Memory
2 GB GDDR5 SDRAM
Camera
Yes - 720p
Camera Features
ThinkShutter camera privacy
Sound
Stereo speakers, dual array microphone
Codec
Realtek ALC3287
High Definition Audio, Dolby Audio Premium
Input
Keyboard Backlight
Keyboard Layout
Spill-resistant, multi-touch touchpad, buttonless touchpad
Communications
Wireless
Wireless Controller
Intel Wireless-AC 9560
Network Interface
Gigabit Ethernet
Ethernet Controller
Intel I219-V
Lithium Ion
50 Wh
Run Time
Up to 14.7 hours
AC Adapter
Input
Output
65 Watt
Connections & Expansion
USB 3.1 Gen 1 , USB 3.1 Gen 1 (Always On) , USB-C 3.1 Gen 1 (supports DisplayPort Alt Mode) (Power Delivery) , USB-C 3.1 Gen 2 (supports Thunderbolt 3, DisplayPort Alt Mode) (Power Delivery) , HDMI , LAN , Dock , Headphone/microphone combo jack
Memory Card Reader
Yes (microSD)
Case Material
Glass-fibre, polyphenylene sulfide, polyamide
Dockable
Security
Administrator password, hard drive password, power-on password, RapidCharge, MIL-STD-810G tested
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
USB-C power adapter
RoHS
Localization
TopSeller
1.55 kg
Sustainability Information
EPEAT Compliant
EPEAT Silver
ENERGY STAR Certified
Essential Accessories (6)
Get more from your purchase from one of our essential accessories
FPT0 Lenovo 3M 14.0W Privacy Filter In Stock £37.84
FPT0 Lenovo 45W Standard AC Adapter (USB Type-C) Power Adapter In Stock £26.01
FPT0 Lenovo 65W Standard AC Adapter USB-C In Stock £29.56
FPT0 Lenovo USB-C 65W AC Adapter AC 100-240 V 65Watt for ThinkPad A275 In Stock £29.56
FPT0 Lenovo ThinkPad Hybrid USB-C with USB-A Dock - Do In Stock £194.89
FPT0 Kensington Security Cable Lock In Stock £23.65
Other bundles (13)
FPT0 Lenovo ThinkPad USB 3.0 Secure HDD-500GB In Stock £143.11
FPT0 Lenovo HDMI to VGA Monitor Adapter In Stock £23.20
FPT0 Lenovo USB3.0 To VGA/HDMI Adapter In Stock £63.85
FPT0 Lenovo 2m HDMI Cable In Stock £17.02
FPT0 Lenovo Essential Wireless Keyboard and Mouse Combo - UK English 166 In Stock £41.29
FPT0 Lenovo Professional Wireless Keyboard In Stock £53.47
FPT0 Lenovo ThinkPad USB3.0 to Ethernet Adapter In Stock £16.07
FPT0 Lenovo Essential Wired Keyboard and Mouse Combo - UK English In Stock £25.39
FPT0 Lenovo ThinkVision M14 14" 1920x1080 6ms USB-C IPS LED Monitor In Stock £258.14
FPT0 Lenovo ThinkVision T24d 24" 1920x1080 VGA HDMI DisplayPort IPS LED Monitor In Stock £202.02
FPT0 Lenovo ThinkVision T27p-10 27" 3840x2160 HDMI DisplayPort USB-C IPS LED Monitor In Stock £454.54
FPT0 Lenovo ThinkVision P27h-20 27" 2560x1440 6ms HDMI DisplayPort IPS LED Monitor In Stock £336.70
FPT0 Lenovo ThinkVision T27q-20 27" 2560x1440 4ms HDMI DisplayPort IPS LED Monitor In Stock £321.24
