Is it better to be powerful or mobile? With the new ThinkPad P1, the answer is... both. No need to choose. It's thinnest and lightest mobile workstation ever at 18.4mm and 1.7 kg. But it still delivers on power with 8th Gen Intel Xeon and Core processors, NVIDIA Quadro graphics, and massive memory and storage options.
Raw power
Count on the ThinkPad P1 mobile workstation when it comes to mission-critical systems and performance. The latest Intel Xeon and Core processing and cutting-edge NVIDIA Quadro graphics make this slim powerhouse pack a punch. -
ISV certified
The ThinkPad P1 has been tested and proven to render key heavy-lifting applications seamlessly. And don't just take word for it: the P1 boasts dozens of the major independent software vendor (ISV) certifications. -
Workstation power has never looked so good
Boasting Think's signature black finish and encased in carbon fiber and magnesium alloy, the P1 has the style to match the power inside. And at a mere 18.4 mm thin, no one will mistake this machine for anything less than an ultra-premium must-have. -
Girded for the toughest ordeals
The P1 has endured 12 military-grade requirements and more than 200 quality checks to ensure it runs in extreme conditions. From the arctic wilderness to desert dust storms, from zero-gravity to spills and drops, you can trust this mobile workstation to handle whatever life throws your way. -
Thin in size, thick with features
It's not just power the ThinkPad P1 packs into its slim chassis. Its robust connectivity - including multiple Thunderbolt ports, as well as more traditional connectors like USB 3.0 and HDMI - put other ultrathin mobile workstations to shame.
- Lenovo ThinkPad P1 - 15.6" - Core i7 8750H - 16 GB RAM - 256 GB SSD - UK
- Product Type
- Notebook
- Operating System
- Win 10 Pro 64-bit
- Processor
- Intel Core i7 (8th Gen) 8750H / 2.2 GHz (4.1 GHz) / 9 MB Cache
- Memory
- 16 GB DDR4 (2 x 8 GB)
- Storage
- 256 GB SSD TCG Opal Encryption 2, NVMe
- Optical Drive
- No optical drive
- Display
- 15.6" LED backlight 1920 x 1080 / Full HD
- Graphics
- NVIDIA Quadro P1000 / Intel UHD Graphics 630
- Video Memory
- 4 GB GDDR5 SDRAM
- Input Device
- TrackPoint, UltraNav
- Keyboard
- UK
- Keyboard Backlight
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac, Bluetooth 5.0, Gigabit Ethernet
- Battery
- Up to 13.87 hours
- Security
- Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader, smart card reader
- Black
- 36.18 cm x 24.57 cm x 1.84 cm
- 1.7 kg
- Localisation
- Manufacturer Selling Program
- TopSeller
- Environmental Standards
- TCO Certified Notebooks 5, ENERGY STAR Qualified
- SAR
- 0.193 W/kg (body), 0.193 W/kg (limb)
- Limited warranty - 3 years - on-site ¦ Limited warranty - battery - 1 year
- Product Type
- Notebook
- Operating System
- Windows 10 Pro 64-bit Edition
Processor / Chipset
- CPU
- Max Turbo Speed
- 4.1 GHz
- Number of Cores
- 6-core
- Cache
- 9 MB
- 64-bit Computing
- Chipset
- Mobile Intel CM246
- Integrated memory controller
- RAM
- 16 GB (2 x 8 GB)
- Max RAM Supported
- 64 GB
- Technology
- DDR4 SDRAM - non-ECC
- Speed
- 2400 MHz
- Rated Speed
- 2666 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots Qty
- 2
- Empty Slots
- 0
Storage
- Main Storage
- 256 GB SSD - (M.2) PCIe - TCG Opal Encryption 2, NVM Express (NVMe)
Display
- 15.6" - IPS
- LCD Backlight Technology
- LED backlight
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Image Brightness
- 300 cd/m²
- Anti-glare, 72% colour gamut
Audio & Video
- Multi-GPU Configuration
- 1 single GPU card / integrated GPU
- Graphics Processor
- Video Memory
- 4 GB GDDR5 SDRAM
- Camera
- Yes - 720p
- Camera Features
- ThinkShutter camera privacy
- Sound
- Stereo speakers, dual array microphone
- Codec
- Realtek ALC3286
- High Definition Audio, Dolby Audio Premium, Dolby Atmos
Input
- Keyboard, TrackPoint, UltraNav
- Keyboard Layout
- UK
- Spill-resistant, multi-touch touchpad, buttonless touchpad
Communications
- Wireless
- Wireless Controller
- Intel Wireless-AC 9560 - M.2 Card
- Network Interface
- Gigabit Ethernet
- Ethernet Controller
- Intel I219-V
- Technology
- Lithium Ion
- Capacity
- 80 Wh
- Run Time
- Up to 13.87 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 135 Watt
Connections & Expansion
- USB 3.1 Gen 1 (Always On) , USB 3.1 Gen 1 , 2 x USB-C/Thunderbolt 3/DisplayPort (Power Delivery) , HDMI , Lenovo Ethernet extension connector , Headphone/microphone combo jack , LAN (on supplied cable)
- Memory Card Reader
- Yes (SD Card, SDHC Card, SDXC UHS-II Card)
- Black
- Case Material
- Aluminum, glass-fibre reinforced plastic, carbon fibre reinforced plastic
- Security
- Administrator password, hard drive password, power-on password, RapidCharge, MIL-STD-810G tested
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- Included Accessories
- Power adapter, ThinkPad Ethernet Extension cable
- RoHS
- SAR Value
- Localization
- TopSeller
- 1.7 kg
- TCO Certified
- ENERGY STAR Certified
Essential Accessories (1)
Get more from your purchase from one of our essential accessories
Lenovo Microsaver Security Cable Lock | In Stock | £34.65 |
Other bundles (1)
Lenovo Optical 3-button W/Mouse USB | In Stock | £13.83 |
