Lenovo ThinkPad Miix 510 Intel i5-7200U 8GB 256GB 12.2" Win 10 P
Quicklinx: CXSVWS00 Mfr#: 80XE001FUK
  • Core i5
  • IEEE 802.11n
Work or play - you decide. The Lenovo Miix 510 is the 2-in-1 PC that adapts to every moment. With its sleek design, amazing watchband hinges, and high performance - you can rely on the Miix 510 to power you through any situation.
  • Design That Stands Out
    With a premium one-piece aluminum design, the Miix 510 is bound to attract attention. This detachable 2-in-1 easily transitions from tablet to laptop to support you wherever you go-and looks great too.
  • Unique Watchband Hinges
    Made from 280 individual pieces of stainless steel, the hinges provide strength and flexibility. Adjustable up to 150°, they help you find your perfect viewing angle for watching videos, typing, or using the touchscreen.
  • Everything You Need To Stay Productive
    With the blazing-fast performance and built-in security of up to the latest Gen Intel Core i7 processors, the Miix 510 is ready to take your productivity and creativity to the next level. Now, you can power through tasks like creating/editing documents and photos, plus so much more. It also features a 12.2" FHD+ touchscreen in addition to the power and agility of a regular laptop PC.
  • Do Great Things With Windows 10 Home
    Enjoy the best of what Windows 10 Home has to offer: from fast start-ups, to the expanded Start menu and all-new browser, to Cortana-your very own digital personal assistant.
  • Open Programs and Files in a Flash
    Miix 510 features the latest Solid State Drive (SSD) technology, enabling it to boot up within seconds and open files/apps in a flash. What's more, since SSDs have no spinning parts, you'll benefit from a virtually silent machine with the durability to withstand accidents, such as dropping your laptop bag!
  • Simplicity with Accuracy
    No space to use a mouse? The integrated precision touchpad can be adjusted to respond to the lightest of touches or the firmest of clicks.
  • Be Creative With Lenovo Active Pen
    Draw, sign documents, take notes, and more-the optional Lenovo Active Pen is sensitive to every detail.
  • Time to Relax
    Whether you're watching movies, playing games or simply browsing the web, you'll love the flexibility of switching between a handheld tablet and a full productivity keyboard. And with Dolby enabled stereo speakers, everything sounds better.
  • Snap Photos, Then Edit
    Enjoy taking high-quality photos with the rear-facing 5MP camera. Then edit them in a snap by reattaching the keyboard-or use the optional Lenovo Active Pen to select them.
  • All-day Battery Life
    Miix 510 keeps you connected all day long with up to 8 hours of battery life.
  • Always Online
    With optional LTE, you can stay online even when you are away from WiFi.
  • Talking With Others is Easier
    Whether voice or video calls, Miix 510 is optimized for VoIP with a 2 MP HD webcam, and dual array mics with noise cancellation technology that reduces background noise and interference.
Lenovo IdeaPad Miix 510-12IKB - 12.2" - Intel Core i5 - 7200U - 8 GB RAM - 256 GB SSD - UK
Tablet - with detachable keyboard
Operating System
Win 10 Pro 64-bit
Intel Core i5 (7th Gen) - 7200U / 2.5 GHz, up to 3.1 GHz / 3 MB Cache
8 GB DDR4 (provided memory is soldered)
Storage
256 GB SSD
Display
12.2" LED backlight touchscreen 1920 x 1200 / WUXGA
Graphics
Intel HD Graphics 620
Input Device
Keyboard, digitizer, touchpad, digital pen
Keyboard
Keyboard Backlight
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.1
2-cell - up to 7.5 hours
Platinum silver
Dimensions (WxDxH) - tablet
30 cm x 20.5 cm x 0.99 cm
880 g
Environmental Standards
- EPEAT Climate+
Limited warranty - 1 year - pick-up and return
Operating System
Windows 10 Pro 64-bit Edition
Processor / Chipset
CPU
Intel Core i5 (7th Gen) 7200U / 2.5 GHz
Max Turbo Speed
3.1 GHz
Number of Cores
Dual-Core
Cache
3 MB
64-bit Computing
Integrated memory controller
RAM
8 GB (provided memory is soldered)
DDR4 SDRAM
Speed
2133 MHz
Storage
Main Storage
256 GB SSD PCIe
Display
12.2" - IPS
LCD Backlight Technology
LED backlight
Touchscreen
Yes (multi-touch)
Resolution
1920 x 1200 (WUXGA)
Widescreen
Image Aspect Ratio
16:10
Image Brightness
320 cd/m²
Corning Gorilla glass
Audio & Video
Graphics Processor
Camera
Resolution
5 Megapixel (rear), 2 Megapixel (front)
Camera Features
Rear camera with auto focus
Sound
Stereo speakers, microphone
Input
Keyboard Backlight
Keyboard Layout
Communications
Wireless
2-cell Lithium Ion
39 Wh
Run Time
Up to 7.5 hours
AC Adapter
Input
Output
45 Watt, 20 V, 2.25 A
Connections & Expansion
Interfaces Details
USB 3.0 (Always On) , USB-C , Headphone/microphone combo jack
Memory Card Reader
Yes (microSD)
Platinum silver
Administrator password, power-on password
Power adapter, keyboard, active pen, pen holder
Localization
880 g
Dimensions (WxDxH) / Weight Details
30 cm x 20.5 cm x 0.99 cm / 880 g - tablet , 30 cm x 20.5 cm x 1.59 cm / 1.25 kg - tablet with keyboard , 30.39 cm x 21.91 cm x 0.6 cm / 380 g - keyboard dock
Sustainability Information
TCO Certified
EPEAT Compliant
EPEAT Climate+
