Thanks to the ThinkShutter, optional touch fingerprint reader and IR camera, the ThinkPad L590 is designed to be secure - and give your IT department one less thing to worry about. This configurable 15.6" laptop will also make your employees' lives easier with its seamless performance and longs battery life.
The ThinkPad L590 can run all day with long hours of battery life. When low on power, its rapid-charging technology will give you 80% battery capacity in just 60 minutes.
The ThinkPad L590 comes with plenty of ports, including HDMI and USB-C. When you're out and about, stay online even when there's no Wi-Fi.
Happy IT department, even happier users
Thanks to the ThinkShutter, optional touch fingerprint reader and IR camera, the ThinkPad L590 is designed to be secure - and give your IT department one less thing to worry about. This configurable 15.6" laptop will also make your employees' lives easier with its seamless performance and longs battery life. -
For those who are going places
The ThinkPad L590 can run all day with long hours of battery life. When low on power, its rapid-charging technology will give you 80% battery capacity in just 60 minutes. -
All the right connections
The ThinkPad L590 comes with plenty of ports, including HDMI and USB-C. When you're out and about, stay online even when there's no Wi-Fi. -
Log in more quickly & securely
Why type a password? Thanks to the optional touch fingerprint reader and infrared camera, logging in is quick and secure - via advanced biometric technology and Windows Hello facial software. Plus, with ThinkShutter, you can close the webcam when it's not in use. -
Technology your business can count on
Like all ThinkPad laptops, the ThinkPad L590 is tested against 12 military-grade requirements and more than 200 quality checks to ensure it runs in extreme conditions. From the Arctic wilderness to desert dust storms, from zero gravity to spills and drops, you can trust the ThinkPad L590 to handle whatever life throws your way.
- Lenovo ThinkPad L590 - 15.6" - Intel Core i7 8565U - 8 GB RAM - 256 GB SSD - UK
- Product Type
- Notebook
- Operating System
- Win 10 Pro 64-bit - English
- Processor
- Intel Core i7 (8th Gen) 8565U / 1.8 GHz (4.6 GHz) / 8 MB Cache
- Memory
- 8 GB DDR4 (1 x 8 GB)
- Storage
- 256 GB SSD - TCG Opal Encryption 2, NVMe
- Display
- 15.6" LED backlight 1920 x 1080 / Full HD
- Graphics
- Intel UHD Graphics
- Input Device
- TrackPoint, UltraNav
- Keyboard
- UK
- Keyboard Backlight
- Numeric Keypad
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac, Bluetooth 5.0, Gigabit Ethernet
- Battery
- Up to 12 hours
- Dockable
- Security
- Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader, smart card reader
- Black
- 37.65 cm x 25.45 cm x 2.295 cm
- 2.03 kg
- Localisation
- Manufacturer Selling Program
- TopSeller
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - 1 year - pick-up and return
- Product Type
- Notebook
- Operating System
- Windows 10 Pro 64-bit Edition - English
Processor / Chipset
- CPU
- Max Turbo Speed
- 4.6 GHz
- Number of Cores
- Quad-Core
- Cache
- 8 MB
- 64-bit Computing
- Integrated memory controller
- RAM
- 8 GB (1 x 8 GB)
- Max RAM Supported
- 64 GB
- Technology
- DDR4 SDRAM
- Speed
- 2400 MHz
- Rated Speed
- 2666 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots Qty
- 2
- Empty Slots
- 1
Storage
- Main Storage
- 256 GB SSD M.2 2280 PCIe 3.0 x2 - TCG Opal Encryption 2, NVM Express (NVMe)
Display
- 15.6" - IPS
- LCD Backlight Technology
- LED backlight
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Image Brightness
- 250 cd/m²
- Colour Gamut
- 45%
- Anti-glare, 170° viewing angle
Audio & Video
- Graphics Processor
- Camera
- Yes - 720p
- Camera Features
- ThinkShutter camera privacy
- Sound
- Stereo speakers, dual array microphone
- Codec
- Realtek ALC3287
- High Definition Audio, Dolby Advanced Audio
Input
- Keyboard, TrackPoint, UltraNav
- Keyboard Layout
- UK
- Numeric Keypad
- Spill-resistant, multi-touch touchpad, buttonless touchpad
Communications
- Wireless
- Wireless Controller
- Intel Dual Band Wireless-AC 9260 - M.2 Card
- Network Interface
- Gigabit Ethernet
- Ethernet Controller
- Intel I219-V
- Technology
- Lithium Ion
- Capacity
- 45 Wh
- Run Time
- Up to 12 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 65 Watt
Connections & Expansion
- USB 3.1 Gen 1 (Always On) , USB-C 3.1 Gen 1 (supports DisplayPort Alt Mode) (Power Delivery) , USB-C 3.1 Gen 2 (supports DisplayPort Alt Mode) (Power Delivery) , HDMI , LAN , Headphone/microphone combo jack , Dock , USB 3.1 Gen 1
- Memory Card Reader
- Yes (microSD)
- Black
- Case Material
- Polycarbonate ABS
- Dockable
- Security
- Administrator password, hard drive password, power-on password, RapidCharge
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- Included Accessories
- USB-C power adapter
- RoHS
- Localization
- TopSeller
- 2.03 kg
Sustainability Information
- ENERGY STAR Certified
