Designed to offer a fundamental enterprise solution, the ThinkPad L470 business laptop will power you through your day. Get great performance, legendary reliability, and enterprise-worthy security from this versatile business machine.
Helps you get things done
The processor and memory will help you get things done quickly and easily while enjoying the comfort and security you expect from a ThinkPad laptop. -
Tough for any job
Extensively tested, the L470 is engineered to survive die bumps and bruises of life.
- Lenovo ThinkPad L470 - 14" - Intel Core i5 - 7200U - 4 GB RAM - 500 GB HDD - UK
- Product Type
- Notebook
- Operating System
- Win 10 Pro 64-bit
- Processor
- Intel Core i5 (7th Gen) - 7200U / 2.5 GHz, up to 3.1 GHz / 3 MB Cache
- Memory
- 4 GB DDR4 (1 x 4 GB)
- Storage
- 500 GB HDD / 7200 rpm
- Display
- 14" LED backlight 1366 x 768 / HD
- Graphics
- Intel HD Graphics 620
- Input Device
- TrackPoint, UltraNav
- Keyboard
- UK
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac, Bluetooth 4.1, Gigabit Ethernet
- Battery
- 6-cell - up to 14.48 hours
- Dockable
- Security
- Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader, smart card reader
- Black
- 33.9 cm x 23.5 cm x 2.39 cm
- 2.02 kg
- Localisation
- Manufacturer Selling Program
- TopSeller
- Environmental Standards
- - ENERGY STAR Qualified EPEAT Climate+
- Limited warranty - 1 year - pick-up and return
- Product Type
- Notebook
- Operating System
- Windows 10 Pro 64-bit Edition
Processor / Chipset
- CPU
- Intel Core i5 (7th Gen) 7200U / 2.5 GHz
- Max Turbo Speed
- 3.1 GHz
- Number of Cores
- Dual-Core
- Cache
- 3 MB
- 64-bit Computing
- Integrated memory controller
- RAM
- 4 GB (1 x 4 GB)
- Max RAM Supported
- 32 GB
- Technology
- DDR4 SDRAM
- Speed
- 2133 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots Qty
- 2
- Empty Slots
- 1
Storage
- Main Storage
- 500 GB HDD SATA 6Gb/s / 7200 rpm
Display
- 14"
- LCD Backlight Technology
- LED backlight
- Resolution
- 1366 x 768 (HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Image Brightness
- 220 cd/m²
- Anti-glare
Audio & Video
- Graphics Processor
- Camera
- Yes - 720p
- Sound
- Stereo speakers, dual array microphone
- Codec
- Realtek ALC3268
- High Definition Audio
Input
- Keyboard, TrackPoint, UltraNav
- Keyboard Layout
- UK
- Spill-resistant, multi-touch touchpad, buttonless touchpad
Communications
- Wireless
- Wireless Controller
- Intel Dual Band Wireless-AC 8265 - M.2 Card
- Network Interface
- Gigabit Ethernet
- Ethernet Controller
- Intel I219-V
Wireless Broadband (WWAN)
- Generation
- WWAN upgradable
- Technology
- 6-cell Lithium Ion
- Capacity
- 48 Wh
- Run Time
- Up to 14.48 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 45 Watt
Connections & Expansion
- Interfaces Details
- 2 x USB 3.1 Gen 1/USB 3.0 , VGA , Mini DisplayPort , LAN , Dock , Headphone/microphone combo jack , USB 3.1 Gen 1/USB 3.0 (Always On)
- Memory Card Reader
- 4 in 1 (SD Card, MultiMediaCard, SDHC Card, SDXC Card)
Software
- Software Included
- Lenovo Companion, Lenovo Settings
- Black
- Case Material
- Polycarbonate ABS
- Dockable
- Security
- Administrator password, hard drive password, power-on password, ThinkVantage Active Protection System, MIL-STD-810G tested
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- Included Accessories
- Power adapter
- RoHS
- Localization
- TopSeller
- 2.02 kg
Sustainability Information
- TCO Certified
- EPEAT Compliant
- EPEAT Climate+
- ENERGY STAR Certified
