Stop wasting time, money and IT resources on sluggish, aging PCs. More than just competitively priced, the highly stable, reliable, ergonomic ThinkPad L Series enterprise laptops help you do more in less time while keeping costs low.
High-performance features and lots of memory-deliver unprecedented speed and responsiveness to help employees multitask and get more done.
L Series laptops are lighter than similar competing laptops and feature less-bulky batteries for all-day computing.
Keeps the IT department happy
The ThinkPad L390 is designed to be secure, reliable, and mobile. Its discrete TPM 2.0 chip and optional Match-on-Host fingerprint reader help to safeguard data. Durablity your business can count on is baked into its DNA. What's more, it weighs from just 1.46 kg and can be used anywhere. -
Freedom to work anywhere
Thanks to the high-performance Intel processors, high-speed DDR4 memory, and a 14-hour battery life, the L390 is no slouch. It also has Rapid Charge to boost the battery back up to 80% in just one hour. -
Very well connected
With a full range of ports, including USB-C and HDMI, plus smooth wireless technology, the streamlined L390 lets you hook up all your favourite devices-and stay in the loop wherever you are. Available in black or silver color. -
Easy on the eyes& the pocket
There's a choice of 13.3" displays, including IPS FHD for wide-angle viewing and enhanced colours. You can opt for a multitouch version as well, enabling you to interact in more ways. And there's an optional backlit keyboard, perfect for low-light surroundings. Whatever your choice, you'll find the price most agreeable, too -
Extra security at your fingertips
With an optional touch fingerprint reader, logging into your L390 is faster and easier than typing a password. In addition, should your laptop fall into the wrong hands, it's harder for someone to access your files without your fingerprint than it is without your password. -
Looking for something? Ask Cortana
With up to Windows 10 Pro, you can say goodbye to hunting for files, photos, and meeting notes. And hello to Cortana.A search engine, secretary, concierge, and more, she can even things by dates and people's names, rather than by file names.
- Lenovo ThinkPad L390 Yoga - 13.3" - Intel Core i7 8565U - 8 GB RAM - 512 GB SSD - UK
- Product Type
- Notebook - flip design
- Operating System
- Win 10 Pro 64-bit - English
- Processor
- Intel Core i7 (8th Gen) 8565U / 1.8 GHz (4.6 GHz) / 8 MB Cache
- Memory
- 8 GB DDR4 (1 x 8 GB)
- Storage
- 512 GB SSD - TCG Opal Encryption 2, NVMe
- Display
- 13.3" LED backlight touchscreen 1920 x 1080 / Full HD
- Graphics
- Intel UHD Graphics
- Input Device
- Digitizer, TrackPoint, digital pen, UltraNav
- Keyboard
- UK
- Keyboard Backlight
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac, Bluetooth 5.0
- Battery
- Up to 12.17 hours
- Security
- Trusted Platform Module (TPM 2.0) Security Chip
- Black
- 32.18 cm x 22.42 cm x 1.88 cm
- 1.56 kg
- Localisation
- Manufacturer Selling Program
- TopSeller
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - 1 year - pick-up and return
- Product Type
- Operating System
- Windows 10 Pro 64-bit Edition - English
Processor / Chipset
- CPU
- Max Turbo Speed
- 4.6 GHz
- Number of Cores
- Quad-Core
- Cache
- 8 MB
- 64-bit Computing
- Integrated memory controller
- RAM
- 8 GB (1 x 8 GB)
- Max RAM Supported
- 32 GB
- Technology
- DDR4 SDRAM
- Speed
- 2400 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots Qty
- 2
- Empty Slots
- 1
Storage
- Main Storage
- 512 GB SSD M.2 2280 PCIe - TCG Opal Encryption 2, NVM Express (NVMe)
Display
- 13.3" - IPS
- LCD Backlight Technology
- LED backlight
- Touchscreen
- Yes (10-point multi-touch)
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Image Brightness
- 300 cd/m²
- Colour Gamut
- 72%
- Anti-glare, anti-reflective, capacitive touch screen, 170° viewing angle
Audio & Video
- Graphics Processor
- Camera
- Yes - 720p (front)
- Resolution
- 5 Megapixel (rear)
- Sound
- Stereo speakers, dual array microphone
- Codec
- Realtek ALC3287
- High Definition Audio, Dolby Audio Premium
Input
- Keyboard, digitizer, TrackPoint, digital pen, UltraNav
- Keyboard Layout
- UK
- Spill-resistant, multi-touch touchpad, buttonless touchpad
Communications
- Wireless
- Wireless Controller
- Intel Wireless-AC 9560 - M.2 Card
- Gigabit Ethernet via optional Ethernet (RJ-45) adapter
- Technology
- Lithium Ion
- Capacity
- 45 Wh
- Run Time
- Up to 12.17 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 65 Watt
Connections & Expansion
- USB 3.1 Gen 1 (Always On) , USB 3.1 Gen 1 , 2 x USB-C 3.1 Gen 1 , HDMI , Lenovo Ethernet extension connector , Headphone/microphone combo jack
- Memory Card Reader
- Yes (microSD)
- Black
- Case Material
- Glass-fibre reinforced plastic, magnesium-aluminum alloy
- Security
- Administrator password, hard drive password, power-on password, RapidCharge, MIL-STD-810G tested
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- Included Accessories
- ThinkPad Pen Pro, USB-C power adapter
- RoHS
- Localization
- TopSeller
- 1.56 kg
Sustainability Information
- ENERGY STAR Certified
