You work hard to get the job done, no matter where the job takes you. The 13.3" ThinkPad L380 Yoga has the versatility, power, and mobility to keep up - and to make your job easier. It's ultraportable, with the latest processor and graphics, and can be used in four different modes - laptop, tablet, tent, or stand. The perfect business partner!
Keeps IT departments as happy as their users
Your IT staff will rest easy with the infrared camera, knowing it gives the L380 Yoga additional security. And Intel vPro technology means IT can manage the L380 Yoga remotely and securely. It's easy to deploy, offering the hardware compatibility of multiple USB-C and USB 3.0 ports. And because its multiple modes make it more comfortable to use in any scenario, the L380 Yoga will make your employees' jobs easier - a favor they will return to your IT department by not calling to complain. -
More connectivity, more productivity
Whether you need to get online or use a peripheral device, the L380 Yoga can connect you. Extensive I/O ports such as USB Type-C, USB 3.0, and HDMI make it easy to plug in most peripheral devices, while Near Field Communication (NFC) technology gives you the luxury of wireless communication between your laptop and other nearby NFC devices. And its Dual Band AC (2x2) and Bluetooth 4.2 make wireless online connectivity a snap. -
Flexible enough to accommodate every task
Position the L380 Yoga display the way you need it, for a specific usage mode. Research a topic or fill out a spreadsheet in laptop mode. Open it the full 360 degrees to Tablet mode to read a white paper, use the optional world-facing camera, and enjoy Active Pen Pro technology for its precise, accurate, and natural writing experience. Set it to tent mode when giving presentations, or stand mode for watching videos. It's as flexible as your imagination.
- Lenovo ThinkPad L380 Yoga - 13.3" - Core i5 8250U - 8 GB RAM - 256 GB SSD - UK
- Product Type
- Notebook - flip design
- Operating System
- Win 10 Pro 64-bit - English
- Processor
- Intel Core i5 (8th Gen) 8250U / 1.6 GHz (3.4 GHz) / 6 MB Cache
- Memory
- 8 GB DDR4 (1 x 8 GB)
- Storage
- 256 GB SSD TCG Opal Encryption, NVMe
- Optical Drive
- No optical drive
- Display
- 13.3" LED backlight touchscreen 1920 x 1080 / Full HD
- Graphics
- Intel UHD Graphics 620
- Input Device
- Digitizer, TrackPoint, digital pen, UltraNav
- Keyboard
- UK
- Keyboard Backlight
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac, Bluetooth 4.1
- Battery
- 3-cell - up to 12.85 hours
- Security
- Trusted Platform Module (TPM 2.0) Security Chip
- Black
- 32.2 cm x 22.42 cm x 1.88 cm
- 1.56 kg
- Localisation
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - 1 year - pick-up and return
- Product Type
- Operating System
- Windows 10 Pro 64-bit Edition - English
Processor / Chipset
- CPU
- Max Turbo Speed
- 3.4 GHz
- Number of Cores
- Quad-Core
- Cache
- 6 MB
- 64-bit Computing
- Integrated memory controller
- RAM
- 8 GB (1 x 8 GB)
- Max RAM Supported
- 32 GB
- Technology
- DDR4 SDRAM
- Speed
- 2400 MHz
- Rated Speed
- 2400 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots Qty
- 2
- Empty Slots
- 1
Storage
- Main Storage
- 256 GB SSD - (M.2) PCIe - TCG Opal Encryption, NVM Express (NVMe) - Samsung
Display
- 13.3" - IPS
- LCD Backlight Technology
- LED backlight
- Touchscreen
- Yes (10-point multi-touch)
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Image Brightness
- 300 cd/m²
- Glossy, anti-reflective
Audio & Video
- Graphics Processor
- Camera
- Yes - 720p (front)
- Resolution
- 5 Megapixel (rear)
- Sound
- Stereo speakers, dual array microphone
- Codec
- Realtek ALC3287
- High Definition Audio, Dolby Advanced Audio
Input
- Keyboard, digitizer, TrackPoint, digital pen, UltraNav
- Keyboard Layout
- UK
- Multi-touch touchpad, buttonless touchpad
Communications
- Wireless
- Wireless Controller
- Intel Dual Band Wireless-AC 8265 - M.2 Card
- Gigabit Ethernet via optional Ethernet (RJ-45) adapter
- Technology
- 3-cell Lithium Ion
- Capacity
- 45 Wh
- Run Time
- Up to 12.85 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 65 Watt, 20 V, 3.25 A
Connections & Expansion
- USB 3.1 Gen 1 (Always On) , USB 3.1 Gen 1 , 2 x USB-C 3.1 Gen 1 , HDMI , Lenovo Ethernet extension connector , Headphone/microphone combo jack
- Memory Card Reader
- Yes (microSD)
- Black
- Case Material
- Aluminum, glass-fibre reinforced plastic
- Security
- Administrator password, hard drive password, power-on password, RapidCharge, MIL-STD-810G tested
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- Included Accessories
- ThinkPad Pen Pro, USB-C power adapter
- RoHS
- Localization
- 1.56 kg
- ENERGY STAR Certified
Essential Accessories (1)
Get more from your purchase from one of our essential accessories
Lenovo Microsaver Security Cable Lock | In Stock | £33.41 |
Other bundles (1)
Lenovo Optical 3-button W/Mouse USB | In Stock | £13.83 |
