Lenovo ThinkPad L380 Yoga Core i5-8250U 256GB 8GB13.3" W10 Pro
Quicklinx: DZ0KWS00 Mfr#: 20M70038UK
Display Size: 13.3in
Processor Model: I5-8250U
Operating System: Windows 10 Pro 64-bit Edition
Installed Memory: 8GB
Hard Drive Capacity: 256GB
  • Core i5
  • IEEE 802.11n
£773.69 ex VAT
£928.42 inc VAT
You work hard to get the job done, no matter where the job takes you. The 13.3" ThinkPad L380 Yoga has the versatility, power, and mobility to keep up - and to make your job easier. It's ultraportable, with the latest processor and graphics, and can be used in four different modes - laptop, tablet, tent, or stand. The perfect business partner!
  • Keeps IT departments as happy as their users
    Your IT staff will rest easy with the infrared camera, knowing it gives the L380 Yoga additional security. And Intel vPro technology means IT can manage the L380 Yoga remotely and securely. It's easy to deploy, offering the hardware compatibility of multiple USB-C and USB 3.0 ports. And because its multiple modes make it more comfortable to use in any scenario, the L380 Yoga will make your employees' jobs easier - a favor they will return to your IT department by not calling to complain.
  • More connectivity, more productivity
    Whether you need to get online or use a peripheral device, the L380 Yoga can connect you. Extensive I/O ports such as USB Type-C, USB 3.0, and HDMI make it easy to plug in most peripheral devices, while Near Field Communication (NFC) technology gives you the luxury of wireless communication between your laptop and other nearby NFC devices. And its Dual Band AC (2x2) and Bluetooth 4.2 make wireless online connectivity a snap.
  • Flexible enough to accommodate every task
    Position the L380 Yoga display the way you need it, for a specific usage mode. Research a topic or fill out a spreadsheet in laptop mode. Open it the full 360 degrees to Tablet mode to read a white paper, use the optional world-facing camera, and enjoy Active Pen Pro technology for its precise, accurate, and natural writing experience. Set it to tent mode when giving presentations, or stand mode for watching videos. It's as flexible as your imagination.
Lenovo ThinkPad L380 Yoga - 13.3" - Core i5 8250U - 8 GB RAM - 256 GB SSD - UK
Notebook - flip design
Operating System
Win 10 Pro 64-bit - English
Intel Core i5 (8th Gen) 8250U / 1.6 GHz (3.4 GHz) / 6 MB Cache
8 GB DDR4 (1 x 8 GB)
Storage
256 GB SSD TCG Opal Encryption, NVMe
Optical Drive
No optical drive
Display
13.3" LED backlight touchscreen 1920 x 1080 / Full HD
Graphics
Intel UHD Graphics 620
Input Device
Digitizer, TrackPoint, digital pen, UltraNav
Keyboard
Keyboard Backlight
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.1
3-cell - up to 12.85 hours
Security
Trusted Platform Module (TPM 2.0) Security Chip
32.2 cm x 22.42 cm x 1.88 cm
1.56 kg
Environmental Standards
ENERGY STAR Qualified
Limited warranty - 1 year - pick-up and return
Operating System
Windows 10 Pro 64-bit Edition - English
Processor / Chipset
CPU
Max Turbo Speed
3.4 GHz
Number of Cores
Quad-Core
Cache
6 MB
64-bit Computing
Integrated memory controller
RAM
8 GB (1 x 8 GB)
Max RAM Supported
32 GB
DDR4 SDRAM
Speed
2400 MHz
Rated Speed
2400 MHz
SO-DIMM 260-pin
Slots Qty
2
Empty Slots
1
Storage
Main Storage
256 GB SSD - (M.2) PCIe - TCG Opal Encryption, NVM Express (NVMe) - Samsung
Display
13.3" - IPS
LCD Backlight Technology
LED backlight
Touchscreen
Yes (10-point multi-touch)
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Aspect Ratio
16:9
Image Brightness
300 cd/m²
Glossy, anti-reflective
Audio & Video
Graphics Processor
Camera
Yes - 720p (front)
Resolution
5 Megapixel (rear)
Sound
Stereo speakers, dual array microphone
Codec
Realtek ALC3287
High Definition Audio, Dolby Advanced Audio
Input
Keyboard, digitizer, TrackPoint, digital pen, UltraNav
Keyboard Backlight
Keyboard Layout
Multi-touch touchpad, buttonless touchpad
Communications
Wireless
Wireless Controller
Intel Dual Band Wireless-AC 8265 - M.2 Card
Gigabit Ethernet via optional Ethernet (RJ-45) adapter
3-cell Lithium Ion
45 Wh
Run Time
Up to 12.85 hours
AC Adapter
Input
Output
65 Watt, 20 V, 3.25 A
Connections & Expansion
USB 3.1 Gen 1 (Always On) , USB 3.1 Gen 1 , 2 x USB-C 3.1 Gen 1 , HDMI , Lenovo Ethernet extension connector , Headphone/microphone combo jack
Memory Card Reader
Yes (microSD)
Case Material
Aluminum, glass-fibre reinforced plastic
Security
Administrator password, hard drive password, power-on password, RapidCharge, MIL-STD-810G tested
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
ThinkPad Pen Pro, USB-C power adapter
RoHS
Localization
1.56 kg
ENERGY STAR Certified
Software applications
Lenovo ThinkPad L380 Yoga Core i5-8250U 256GB 8GB13.3 Bundle deal on Lenovo ThinkPad L380 Yoga Core i5-8250U 256GB 8GB13.3" W10 Pro
£953.27
saving £2.42
£872.86
Essential Accessories (1)
Get more from your purchase from one of our essential accessories
DZ0K Lenovo Microsaver Security Cable Lock In Stock £33.41
Other bundles (1)
DZ0K Lenovo Optical 3-button W/Mouse USB In Stock £12.69
Optical Storage: None
Graphics: Intel UHD Graphics 620
Hard Drive Type: SSD
Brand: Lenovo
Price Range Ex VAT: 750 - 1000
