Lenovo ThinkPad L380 20M5 - Core i7 8550U 8GB 512GB 13.3" Win10 Pro
Quicklinx: F2BFWS00 Mfr#: 20M50011UK
  • Core i7
  • IEEE 802.11n
You work hard to get the job done, no matter where the job takes you. The 13.3" ThinkPad L380 has the versatility, power, and mobility to keep up - and to make your job easier. It's ultraportable, with the latest processor and graphics, excellent memory and storage capacity, and robust security features. The perfect business partner!
  • Keeps IT departments as happy as their users
    Your IT staff will rest easy with the optional touch fingerprint reader and discrete TPM 2.0 chip, knowing they give the L380 greater security. And it's been fully redesigned for mobility, meaning IT won't have to listen to complaints about a heavy laptop. That mobility is enhanced by its RapidCharge function. The L380 will make your employees' jobs easier, a favor they will return to your IT department.
  • More connectivity, more productivity
    Whether you need to get online or use a peripheral device, the L380 can connect you. Extensive I/O ports such as USB Type-C, USB 3.0, and HDMI make it easy to plug in most peripheral devices, while Near Field Communication (NFC) technology gives you the luxury of wireless communication between your laptop and other nearby NFC devices. And its Dual Band AC (2x2) and Bluetooth 4.2 make wireless online connectivity a snap.
Lenovo ThinkPad L380 - 13.3" - Core i7 8550U - 8 GB RAM - 512 GB SSD - UK
Notebook
Operating System
Win 10 Pro 64-bit
Intel Core i7 (8th Gen) 8550U / 1.8 GHz (4 GHz) / 8 MB Cache
8 GB DDR4 (1 x 8 GB)
Storage
512 GB SSD TCG Opal Encryption 2, NVMe
Optical Drive
No optical drive
Display
13.3" LED backlight 1920 x 1080 / Full HD
Graphics
Intel UHD Graphics 620
Input Device
TrackPoint, UltraNav
Keyboard
Keyboard Backlight
802.11a/b/g/n/ac, Bluetooth 4.1
Up to 16.1 hours
Security
Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader
32.18 cm x 22.42 cm x 1.88 cm
1.46 kg
Manufacturer Selling Program
TopSeller
Environmental Standards
ENERGY STAR Qualified
Limited warranty - 1 year - pick-up and return
Notebook
Operating System
Windows 10 Pro 64-bit Edition
Processor / Chipset
CPU
Max Turbo Speed
4 GHz
Number of Cores
Quad-Core
Cache
8 MB
64-bit Computing
Integrated memory controller
RAM
8 GB (1 x 8 GB)
Max RAM Supported
32 GB
DDR4 SDRAM
Speed
2400 MHz
SO-DIMM 260-pin
Slots Qty
2
Empty Slots
1
Storage
Main Storage
512 GB SSD - (M.2) PCIe - TCG Opal Encryption 2, NVM Express (NVMe)
Display
13.3" - IPS
LCD Backlight Technology
LED backlight
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Aspect Ratio
16:9
Image Brightness
250 cd/m²
Anti-glare
Audio & Video
Graphics Processor
Sound
Stereo speakers, dual array microphone
Codec
Realtek ALC3287
High Definition Audio, Dolby Audio
Input
Keyboard, TrackPoint, UltraNav
Keyboard Backlight
Keyboard Layout
Spill-resistant, multi-touch touchpad, buttonless touchpad
Communications
Wireless
Wireless Controller
Intel Dual Band Wireless-AC 8265 - M.2 Card
Ethernet Controller
Intel I219-V
Gigabit Ethernet via optional Ethernet (RJ-45) adapter
Lithium Ion
45 Wh
Run Time
Up to 16.1 hours
AC Adapter
Input
Output
65 Watt
Connections & Expansion
USB 3.1 Gen 1 , USB 3.1 Gen 1 (Always On) , 2 x USB-C 3.1 Gen 1 , HDMI , Headphone/microphone combo jack , Lenovo Ethernet extension connector
Memory Card Reader
Yes (microSD)
Case Material
Aluminum, glass-fibre reinforced plastic
Security
Administrator password, hard drive password, power-on password, RapidCharge, MIL-STD-810G tested
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
USB-C power adapter
RoHS
Localization
TopSeller
1.46 kg
ENERGY STAR Certified
Essential Accessories (1)
Get more from your purchase from one of our essential accessories
F2BF Lenovo Microsaver Security Cable Lock In Stock £33.41
Other bundles (1)
F2BF Lenovo Optical 3-button W/Mouse USB In Stock £13.83
