Lenovo ThinkPad E590 20NB Intel Core i5-8265U 8GB 256GB SSD 15.6" Windows 10 Professional 64-bit
Quicklinx: F5Q3WS00 Mfr#: 20NB001AUK
  • Core i5
  • IEEE 802.11n
A sleek design, smart metallic construction, and high performance ensure the ThinkPad E590 laptop is the perfect choice for professionals who take technology seriously.
  • Packed with power
    The ThinkPad E590 features powerful processors which means everything's accelerated, from everyday computing and opening media-rich files to loading high-performance games.
  • Built for business - tested for life
    The ThinkPad E590 is tested against military-grade requirements and quality checks to ensure it runs in extreme conditions. The ThinkPads undergo some of the most stringent product testing in the industry, so you get the perfect blend of value and durability. From the Arctic wilderness to desert dust storms, from zero-gravity to spills and drops, you can trust this laptop to handle whatever life throws your way.
  • Rein in your travel budget
    When your meetings take you around the world, you can trust the ThinkPad E590 to deliver superb web conferencing. This business machine features enhanced VoIP calls with an HD webcam, dual-array noise cancelling microphones, and Dolby Advanced Audio. No matter where you are, you'll feel like you're in the same room - plus, the E590 is even Lync-certified.
  • Go from 0 to 80 in 60 minutes
    The ThinkPad E590 boosts your productivity with 13 hours of battery life. What's more, when you do need to plug in, Rapid Charge technology provides 80% capacity in just an hour. So a 60-minute lunch break or a layover can easily boost your battery up for more than a day's work.
Lenovo ThinkPad E590 - 15.6" - Core i5 8265U - 8 GB RAM - 256 GB SSD - UK
Notebook
Operating System
Win 10 Pro 64-bit - English
Intel Core i5 (8th Gen) 8265U / 1.6 GHz (3.9 GHz) / 6 MB Cache
8 GB DDR4 (1 x 8 GB)
Storage
256 GB SSD - NVMe
Optical Drive
No optical drive
Display
15.6" LED backlight 1920 x 1080 / Full HD
Graphics
Intel UHD Graphics
Input Device
TrackPoint, UltraNav
Keyboard
Numeric Keypad
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 5.0, Gigabit Ethernet
Up to 11 hours
Security
Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader
36.9 cm x 25.25 cm x 1.99 cm
2.12 kg
Manufacturer Selling Program
TopSeller
Environmental Standards
ENERGY STAR Qualified
SAR
0.436 W/kg (body), 0.436 W/kg (limb)
Limited warranty - 1 year - pick-up and return
Notebook
Operating System
Windows 10 Pro 64-bit Edition - English
Processor / Chipset
CPU
Max Turbo Speed
3.9 GHz
Number of Cores
Quad-Core
Cache
6 MB
64-bit Computing
Integrated memory controller
RAM
8 GB (1 x 8 GB)
Max RAM Supported
32 GB
DDR4 SDRAM
Speed
2400 MHz
SO-DIMM 260-pin
Slots Qty
2
Empty Slots
1
Storage
Main Storage
256 GB SSD M.2 PCIe 3.0 x2 - NVM Express (NVMe)
Display
15.6" - IPS
LCD Backlight Technology
LED backlight
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Aspect Ratio
16:9
Image Brightness
250 cd/m²
Anti-glare, 170° viewing angle
Audio & Video
Graphics Processor
Intel UHD Graphics
Camera
Yes - 720p
Sound
Stereo speakers, dual array microphone
Codec
Conexant CX11880
High Definition Audio, Dolby Advanced Audio
Input
Keyboard, TrackPoint, UltraNav
Keyboard Layout
Numeric Keypad
Spill-resistant, multi-touch touchpad, buttonless touchpad
Communications
Wireless
Wireless Controller
Intel Dual Band Wireless-AC 9260 - M.2 Card
Network Interface
Gigabit Ethernet
Ethernet Controller
Realtek R8111GUS
Lithium Ion
45 Wh
Run Time
Up to 11 hours
AC Adapter
Input
Output
65 Watt
Connections & Expansion
USB 3.1 Gen 1 , USB 3.1 Gen 1 (Always On) , USB-C 3.1 Gen 2 , USB 2.0 , HDMI , LAN , Headphone/microphone combo jack
Memory Card Reader
Yes (microSD)
Case Material
Aluminum, polycarbonate ABS
Security
Administrator password, hard drive password, power-on password, RapidCharge, MIL-STD-810G tested
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
USB-C power adapter
RoHS
SAR Value
Localization
TopSeller
2.12 kg
ENERGY STAR Certified
