The ThinkPad Bluetooth Silent mouse takes a well-worn concept and turns it on its head, delivering a productivity device that doesn't get in the way of the busy professionals who use it. It sculpted to be comfortable to rest your palm on, with a low-profile, minimalist design that makes the mouse easy to carry and fit into pockets without bulging. Get more done with the blue optical sensor that allows you to work on most surfaces, revolutionary, distraction-free silent buttons, and on-the-fly adjustable DPI controls. Effortlessly pair with up to two devices at once and quickly switch between them with the push of a button, thanks to Bluetooth 5.0 and Microsoft Swift Pair technology.
                Work ComfortablyThe ThinkPad Bluetooth Silent Mouse is sculpted to be comfortable to rest your palm on, with a low-profile, minimalist design that makes the mouse easy to carry and fit into pockets without bulging.
                Get More DoneTake your productivity to the max with a blue optical sensor that allows you to work on almost any surface, revolutionary, distraction-free silent buttons, and on-the-fly adjustable DPI controls.
                Connect ConvenientlyEffortlessly pair with up to two devices at once and quickly switch between them with the push of a button, thanks to Bluetooth 5.0 and Microsoft Swift Pair technology
- Lenovo ThinkPad Silent - mouse - Bluetooth 5.0 - black
- Mouse
- Connectivity Technology
- Wireless - Bluetooth 5.0
- Black
- Orientation
- Right and left-handed
- 5.8 cm x 10.7 cm x 2.9 cm
- 61 g
- Movement Detection Technology
- Blue optical
- Buttons Qty
- 3
- Movement Resolution
- 2400 dpi
- Performance
- Realtime sensitivity switching 800/1600/2400 dpi
- On-the-fly DPI switching, low profile design, Swift Pair, ambidextrous design, scrolling 2-way button
- Battery
- AA type
- Package Type
- Retail
- 1-year warranty
- Mouse
- Orientation
- 5.8 cm
- 10.7 cm
- 2.9 cm
- 61 g
- Black
Input Device
- Wireless
- Interface
- Bluetooth 5.0
- Blue optical
- Buttons Qty
- 3
- 2400 dpi
- Performance
- Included Accessories
- 1 AA battery
- ANATEL, BSMI, CB, EMC, cTUVus, EN 62471:2008, FCC, IC, ictQATAR, IMDA, JRF, KC, MIC, NCC, SRRC, Subtel, TRA, TUV Mark, WPC
- Package Type
- Retail
- AA type
- Run Time (Up To)
- 12 months
- Shipping Width
- 11 cm
- Shipping Depth
- 4 cm
- Shipping Height
- 7.8 cm
- Shipping Weight
- 129 g
- Limited warranty - 1 year
- 0 °C
- 40 °C
- 10 - 90%
