The 3-cell ThinkPad Battery 68 powers X240, X250, W550, L450, T450s, T450, T550, T440 and T440s systems for longer. The rechargeable battery lasts for approximately 23.5 watt hours and can be used with the T440, T440s and X240 systems. Each one utilises advanced Lithium-ion technology and over-discharge protection to prolong the life of the battery. The battery is safeguarded with a chip which authenticates with Lenovo systems.
*Battery life is affected by a multitude of factors, including features, battery conditioning, power management, applications, screen brightness and other customer preferences.
- Lenovo ThinkPad Battery 68 - laptop battery - Li-Ion - 2.06 Ah
- Laptop battery
- 180 g
- Battery
- Lithium Ion 3-cell - 2.06 Ah
- 20.67 cm x 6.4 cm x 1.075 cm
- 1-year warranty
- Designed For
- ThinkPad A275 20KC, 20KD; L450 20DS, 20DT; L460 20FU, 20FV; L470 20JU, 20JV; P50s 20FK, 20FL; T460 20FM; T460p 20FW, 20FX; T470p 20J6, 20J7; T560 20FH, 20FJ; W550s 20E2; X12 Detachable 20UV, 20UW; X260 20F5, 20F6; X270 20HM, 20HN, 20K5, 20K6
- Laptop battery
- Technology
- 3-cell Lithium Ion
- Voltage Provided
- 11.4 V
- Capacity
- 2.06 Ah
- UL, C-Tick, cUL, ACA
- Limited warranty - 1 year
- 5 °C
- 35 °C
- 8 - 95%
- 20.67 cm
- 6.4 cm
- 1.075 cm
- 180 g
- Designed For
- Lenovo ThinkPad A275 20KC, 20KD , Lenovo ThinkPad L450 20DS, 20DT , Lenovo ThinkPad L460 20FU, 20FV , Lenovo ThinkPad L470 20JU, 20JV , Lenovo ThinkPad P50s 20FK, 20FL , Lenovo ThinkPad T460 20FM , Lenovo ThinkPad T460p 20FW, 20FX , Lenovo ThinkPad T470p 20J6, 20J7 , Lenovo ThinkPad T560 20FH, 20FJ , Lenovo ThinkPad W550s 20E2 , Lenovo ThinkPad X12 Detachable 20UV, 20UW , Lenovo ThinkPad X260 20F5, 20F6 , Lenovo ThinkPad X270 20HM, 20HN, 20K5, 20K6
