Stay unplugged for longer with the ThinkPad T400s Series 6-Cell Battery. This rechargeable battery uses Lithium-Ion (Li-Ion) technology and can be used as a replacement for ageing system batteries or as a convenient spare battery. (For battery life, go to lenovo.com/alldaycomputing)
Compatible with T400s, T410s.
- Lenovo - laptop battery - Li-Ion - 3900 mAh
- Laptop battery
- 312 g
- Battery
- Lithium Ion 6-cell - 3900 mAh
- Batteries Qty
- 1
- 26.2 cm x 7.4 cm x 1.7 cm
- 1-year warranty
- Designed For
- ThinkPad T400s; T410s; T410si
- Laptop battery
- Quantity
- 1
- Technology
- 6-cell Lithium Ion
- Voltage Provided
- 11.1 V
- Capacity
- 3900 mAh
- C-Tick, cUL, UL 60950, ACA
- Limited warranty - 1 year
- 5 °C
- 35 °C
- 8 - 95%
- 26.2 cm
- 7.4 cm
- 1.7 cm
- 312 g
- Designed For
- Lenovo ThinkPad T400s , Lenovo ThinkPad T410s , Lenovo ThinkPad T410si
