Lenovo ThinkPad 65W DC Travel Adapter
Quicklinx: 95WMWS00 Mfr#: 0B47481
Power up your notebook when and where you need it with a Lenovo 65 W DC Travel adapter. This Lenovo travel adapter is ideal for travellers who need convenient access to power while on the go. With a CLA and Empower adapter for both in-car and in-flight use, this versatile adapter can meet almost all of your mobile power needs. It provides 12 VDC power for in-vehicle use and 15 VDC power for aeroplane use. Equipped with a fixed "slim tip" specifically for ThinkPad systems, end users will not be burdened with the inconvenience of keeping up with multiple interchangeable tips that can easily be lost or forgotten. It is compatible with all Lenovo notebooks with "slim-tip" power plugs and provides a constant power output of 65 watts. The Lenovo travel adapter is very compact, energy-efficient and, of course, is backed by our official Lenovo one-year warranty.
Lenovo ThinkPad 65W DC Travel Adapter - power adapter - 65 Watt
Power adapter - external
130 g
Input Voltage
12 / 15 V
Output Voltage
20 V
Power Capacity
65 Watt
1-year warranty
Input Voltage
12 / 15 V
Output Voltage
20 V
Power Capacity
65 Watt
Power cable
UL, C-Tick, GS, NOM, SASO, EMC, FCC, SII
Limited warranty - 1 year
5 °C
8 - 80% (non-condensing)
130 g
