The Lenovo ThinkPad 170 W AC adapter provides instant power to your W520/W530 laptop. It's designed for the older, round-barrel tip and performs to the specifications of the standard AC charger that is supplied with ThinkPad W520 and W530 laptops. Use it as a replacement or as a convenient spare to ensure you're never without power. Lenovo safeguards each adapter with a one-year warranty, offering renowned support and service.
- Lenovo ThinkPad 170W AC Adapter - power adapter - 170 Watt
- Power adapter - external
- 0.77 kg
- Localisation
- Saudi Arabia, Hong Kong, Myanmar, Malaysia, Singapore, Brunei, Malta, United Kingdom, Ireland
- Input Voltage
- AC 100-240 V
- Power Capacity
- 170 Watt
- 8 cm x 17 cm x 3.5 cm
- 1-year warranty
- Designed For
- ThinkPad P15 Gen 1 20SU; W520 4249, 4260, 4270, 4276, 4281, 4282, 4284; W530
- Localisation
- Input Voltage
- AC 100-240 V
- Frequency Required
- 50/60 Hz
- Power Capacity
- 170 Watt
- Cables Included
- Power cable
- Limited warranty - 1 year
- 5 °C
- 40 °C
- 8 - 80%
- 8 cm
- 17 cm
- 3.5 cm
- 0.77 kg
- Designed For
- Lenovo ThinkPad P15 Gen 1 20SU , Lenovo ThinkPad W520 4249, 4260, 4270, 4276, 4281, 4282, 4284 , Lenovo ThinkPad W530
