Make IT's jobs easier
The ThinkCentre M920z makes life easy for your IT team, keeping your enterprise data safe via embedded Trusted Platform Management (TPM) 2.0 data encryption, BIOS-based Smart USB protection, Windows Hello support, and an intrusion switch that sends alerts if someone attempts to open the chassis. It’s also quick and easy to deploy.
Gets your numbers up
Users can expect high responsiveness and seamless multitasking of even the most intensive tasks, thanks to the latest generation of Intel Core processor and PCIe SSD on selected models, not to mention the fast data transfers of its USB 3.1 Gen 2 and USB-C ports. Watch your employees’ productivity soar.
Keeps your data secure
Rest assured your data will stay safe, thanks to Trusted Platform Module (TPM) 2.0 data and password encryption. And its BIOS-based Smart USB Protection lets you configure the USB ports to respond only to specific devices, preventing unauthorized copying of files.
Save space…
The compact footprint of the M920z AIO means it will leave your workspace clutter-free and open for business. It’s also VESA-mountable and borderless, and can use an optional stand to save even more space.
…and save time
With the Keyboard Power On feature, you can switch on the M920z directly from its keyboard. Its Smart Webcam rotates 180 degrees horizontally and 50 degrees vertically, so a user can switch from front to rear camera mode and keep video conferences moving along.
Tested to extremes
The M920z is tested for durability against eight MIL-SPEC standards: low pressure (altitude); vibration; high temperature; low temperature; sand/dust; temperature shock; humidity; and shock. Yes, this AIO is reliable.
Easy on the eyes
The M920z display’s antiglare panel scatters light and stays flicker-free, reducing eye strain. Plus, its Eye Comfort and Low Blue Light certifications ensure your eyes will stay comfortable when working those long hours.
- Lenovo ThinkCentre M920z AIO - all-in-one - Core i5 9500 3 GHz - vPro - 8 GB - SSD 256 GB - LED 23.8" - UK
- Personal computer - all-in-one
- Platform Technology
- Intel vPro Platform
- Localisation
- Processor
- Intel Core i5 (9th Gen) 9500 / 3 GHz (4.4 GHz) (6-core)
- Cache Memory
- 9 MB
- Cache Per Processor
- 9 MB
- RAM
- 8 GB (installed) / 32 GB (max) - DDR4 SDRAM
- Storage Controller
- SATA
- Hard Drive
- SSD 256 GB - PCI Express - M.2 2280 - TCG Opal Encryption, NVM Express (NVMe)
- Optical Storage
- DVD-Writer
- Card Reader
- 3 in 1
- Monitor
- 23.8" - LED - 1920 x 1080 (Full HD) - 16:9
- Graphics Controller
- Intel UHD Graphics 630
- Camera
- Networking
- GigE, 802.11a, 802.11b/g/n, Wi-Fi 5, Bluetooth 5.0
- Keyboard
- UK
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Windows 10 Pro 64-bit Edition
- Software Included
- Cyberlink PowerDVD, CyberLink Power2Go, Lenovo Vantage, Linkedin
- Business black
- 54.2 cm x 25.2 cm x 36.3 cm
- 8.94 kg
- Manufacturer Selling Program
- TopSeller
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - 3 years - on-site
- Personal computer
- Product Form Factor
- All-in-one - with UltraFlex III Stand
- Built-in Devices
- Stereo speakers
- Embedded Security
- Trusted Platform Module (TPM 2.0) Security Chip
- Business black
- Localisation
Processor / Chipset
- CPU
- Clock Speed
- 3 GHz
- Max Turbo Speed
- 4.4 GHz
- Number of Cores
- 6-core
- CPU Qty
- 1
- Max CPU Qty
- 1
- Chipset Type
- Intel Q370
Cache Memory
- Installed Size
- 9 MB
- 9 MB
RAM
- Installed Size
- 8 GB / 32 GB (max)
- Technology
- DDR4 SDRAM
- Effective Memory Speed
- 2666 MHz
- Rated Memory Speed
- 2666 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots
- 2 (Total) / 1 (empty)
- Dual channel memory architecture
- Configuration Features
- 1 x 8 GB
Hard Drive
- SSD - M.2 2280
- Capacity
- 1 x 256 GB
- Interface Type
- PCI Express
Storage Controller
- 1 x SATA
Optical Storage
- DVD-Writer - SATA
Card Reader
- 3 in 1 card reader
Monitor
- Monitor Type
- LED
- Diagonal Size
- 23.8"
- Native Resolution
- Widescreen Display
- Image Aspect Ratio
- 16:9
- Image Brightness
- 250 cd/m²
- Image Contrast Ratio
- 1000:1
- Monitor Features
- Anti-glare, Low Blue Light Mode, Wide Viewing Angle, borderless
Graphics Controller
- Graphics Processor
- Video Interfaces
- DisplayPort
Audio Output
- High Definition Audio, Dolby Audio Premium
- Speakers Included
- 2 x right / left channel
Camera
- Camera
- Resolution
- 1080p
- 180° rotating function, built-in 2 microphones, LED indicator
Input Device
- Mouse, keyboard
Keyboard
- Interface
- USB
- Localization & Layout
- UK
Mouse
- Interface
- USB
- Interface (Bus) Type
- M.2 Card
- Ethernet Controller
- Intel I219-LM
- Wireless LAN Supported
- Wireless NIC
- Intel Wireless-AC 9560
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 5.0
- Wake on LAN (WoL)
- Slots
- 2 (total) / 0 (free) x M.2 Card
- 5 x USB 3.1 Gen 1 (1 front, 4 rear) (one of them supports SmartPower On) , 1 x LAN (Gigabit Ethernet) , 1 x DisplayPort input/output combo , 1 x USB 3.1 Gen 2 (1 in front) (one of them is Always On and fast-charging) , 1 x USB-C 3.1 Gen 1 (1 in front) , 1 x headphones/microphone (1 in front)
- Theft/Intrusion Protection
- Security lock slot (cable lock sold separately), chassis intrusion switch
- Security Slot Type
- Kensington security slot
- VESA Mounting Interface
- 100 x 100 mm
- RoHS, GREENGUARD, TUV Rheinland Low Blue Light Certification, Energy-Related Products (ErP) Lot 3, TUV Rheinland Eye Comfort Certification, TUV Rheinland Ultra Low Noise Certification
- TopSeller
- Power supply
- Voltage Required
- Power Provided
- 150 Watt
- Efficiency
- 90%
Operating System / Software
- OS Provided
- Windows 10 Pro 64-bit Edition English
- Software
Sustainability Information
- ENERGY STAR Certified
- ENERGY STAR Version
- 7.0
- 54.2 cm
- 25.2 cm
- 36.3 cm
- 8.94 kg
Lenovo Essential Wireless Keyboard and Mouse Combo - UK English 166 | In Stock | £41.29 |
Lenovo Professional Wireless Keyboard | In Stock | £53.21 |
Lenovo ThinkPad USB3.0 to Ethernet Adapter | In Stock | £16.07 |
Kensington Security Cable Lock | In Stock | £23.65 |
Lenovo Essential Wired Keyboard and Mouse Combo - UK English | In Stock | £25.39 |
Lenovo ThinkVision T24d 24" 1920x1080 VGA HDMI DisplayPort IPS LED Monitor | In Stock | £201.00 |
Lenovo ThinkVision T27p-10 27" 3840x2160 HDMI DisplayPort USB-C IPS LED Monitor | In Stock | £454.54 |
Lenovo 100 Headset on ear wired - USB black for IdeaPad 3 ThinkCe | In Stock | £35.79 |
Lenovo ThinkPad Bluetooth Silent Mouse - Right and Left-handed | In Stock | £23.88 |
Lenovo Tiny-in-One 22 21.5" 1920 x 1080 14ms Full HD LED monitor | In Stock | £246.91 |
Lenovo Thinkvision MC50 Monitor Webcam | In Stock | £52.71 |
