Lenovo ThinkCentre M920z AIO 23.8" Intel Core i5-9500 8GB 256GB SSD Windows 10 Professional 64-bit
Quicklinx: FPSQWS00 Mfr#: 10S6003JUK
Operating System: Windows 10 Pro 64-bit Edition
Processor Type: Core i5
Processor Model: I5-9500
Hard Drive Capacity: 256GB
Storage Type: SSD
  • Core i5
  • IEEE 802.11n
£858.05 ex VAT
£1,029.66 inc VAT
Make IT's jobs easier
The ThinkCentre M920z makes life easy for your IT team, keeping your enterprise data safe via embedded Trusted Platform Management (TPM) 2.0 data encryption, BIOS-based Smart USB protection, Windows Hello support, and an intrusion switch that sends alerts if someone attempts to open the chassis. It’s also quick and easy to deploy.
Gets your numbers up
Users can expect high responsiveness and seamless multitasking of even the most intensive tasks, thanks to the latest generation of Intel Core processor and PCIe SSD on selected models, not to mention the fast data transfers of its USB 3.1 Gen 2 and USB-C ports. Watch your employees’ productivity soar.
Keeps your data secure
Rest assured your data will stay safe, thanks to Trusted Platform Module (TPM) 2.0 data and password encryption. And its BIOS-based Smart USB Protection lets you configure the USB ports to respond only to specific devices, preventing unauthorized copying of files.
Save space…
The compact footprint of the M920z AIO means it will leave your workspace clutter-free and open for business. It’s also VESA-mountable and borderless, and can use an optional stand to save even more space.
…and save time
With the Keyboard Power On feature, you can switch on the M920z directly from its keyboard. Its Smart Webcam rotates 180 degrees horizontally and 50 degrees vertically, so a user can switch from front to rear camera mode and keep video conferences moving along.
Tested to extremes
The M920z is tested for durability against eight MIL-SPEC standards: low pressure (altitude); vibration; high temperature; low temperature; sand/dust; temperature shock; humidity; and shock. Yes, this AIO is reliable.
Easy on the eyes
The M920z display’s antiglare panel scatters light and stays flicker-free, reducing eye strain. Plus, its Eye Comfort and Low Blue Light certifications ensure your eyes will stay comfortable when working those long hours.
Lenovo ThinkCentre M920z - all-in-one - Core i5 9500 3 GHz - 8 GB - SSD 256 GB - LED 23.8" - UK
Personal computer - all-in-one
Platform Technology
Intel vPro Technology
Intel Core i5 (9th Gen) 9500 / 3 GHz (4.4 GHz) (6-core)
Cache Memory
9 MB
Cache Per Processor
9 MB
RAM
8 GB (installed) / 32 GB (max) - DDR4 SDRAM
Storage Controller
SATA
Hard Drive
SSD 256 GB - PCI Express - M.2 2280 - TCG Opal Encryption, NVM Express (NVMe)
Optical Storage
DVD-Writer
Card Reader
3 in 1
Monitor
23.8" - LED - 1920 x 1080 (Full HD) - 16:9
Graphics Controller
Intel UHD Graphics 630
Camera
GigE, 802.11a, 802.11b/g/n, 802.11ac, Bluetooth 5.0
Keyboard
OS Provided
Business black
54.2 cm x 25.2 cm x 36.3 cm
8.94 kg
Manufacturer Selling Program
TopSeller
Environmental Standards
ENERGY STAR Qualified
Limited warranty - 3 years - on-site
Platform Technology
Personal computer
Product Form Factor
All-in-one - with UltraFlex III Stand
Built-in Devices
Stereo speakers
Embedded Security
Trusted Platform Module (TPM 2.0) Security Chip
Business black
Processor / Chipset
CPU
Max Turbo Speed
4.4 GHz
Number of Cores
6-core
CPU Qty
1
Max CPU Qty
1
Chipset Type
Intel Q370
Cache Memory
Installed Size
9 MB
Cache Per Processor
9 MB
RAM
Installed Size
8 GB / 32 GB (max)
DDR4 SDRAM
Effective Memory Speed
2666 MHz
Rated Memory Speed
2666 MHz
SO-DIMM 260-pin
Slots
2 (Total) / 1 (empty)
Dual channel memory architecture
Configuration Features
1 x 8 GB
Hard Drive
SSD - M.2 2280
1 x 256 GB
Interface Type
PCI Express
Storage Controller
1 x SATA
Optical Storage
DVD-Writer DVD-Writer - SATA
Card Reader
3 in 1 card reader
Monitor
Monitor Type
LED
Diagonal Size
23.8"
Native Resolution
Widescreen Display
Image Aspect Ratio
16:9
Image Brightness
250 cd/m²
Image Contrast Ratio
1000:1
Bezel Type
Flat front
Monitor Features
Anti-glare, Low Blue Light Mode, Wide Viewing Angle, borderless
Graphics Controller
Graphics Processor
Video Interfaces
DisplayPort
Audio Output
High Definition Audio, Dolby Audio Premium
Speakers Included
2 x right / left channel
Camera
Camera
Resolution
1080p
180° rotating function, built-in 2 microphones, LED indicator
Input Device
Mouse, keyboard
Keyboard
USB
Localization & Layout
Mouse
USB
Interface (Bus) Type
M.2 Card
Ethernet Controller
Intel I219-LM
Wireless LAN Supported
Wireless NIC
Intel Wireless-AC 9560
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 5.0
Wake on LAN (WoL)
Slots
2 (total) / 0 (free) x M.2 Card
5 x USB 3.1 Gen 1 (1 front, 4 rear) (one of them supports SmartPower On) , 1 x LAN (Gigabit Ethernet) , 1 x DisplayPort input/output combo , 1 x USB 3.1 Gen 2 (1 in front) (one of them is Always On and fast-charging) , 1 x USB-C 3.1 Gen 1 (1 in front) , 1 x headphones/microphone (1 in front)
Theft/Intrusion Protection
Security lock slot (cable lock sold separately), chassis intrusion switch
Security Slot Type
Kensington security slot
VESA Mounting Interface
100 x 100 mm
RoHS, GREENGUARD, TUV Rheinland Low Blue Light Certification, Energy-Related Products (ErP) Lot 3, TUV Rheinland Eye Comfort Certification, TUV Rheinland Ultra Low Noise Certification
TopSeller
Power supply
Nominal Voltage
Power Provided
150 Watt
Efficiency
90%
Operating System / Software
OS Provided
Windows 10 Pro 64-bit Edition English
Software
Cyberlink PowerDVD, CyberLink Power2Go, Lenovo Vantage, Linkedin
ENERGY STAR Certified
ENERGY STAR Version
7.0
54.2 cm
25.2 cm
36.3 cm
8.94 kg
FPSQ Lenovo Optical 3-button W/Mouse USB In Stock £13.83
Storage Type: SSD
Optical Storage: DVD-Writer
Brand: Lenovo
Price Range Ex VAT: 750 - 1000
