Lenovo ThinkCentre M910S SFF Core i5-7500 4GB 500GB Win 10 Pro
Quicklinx: D11HWS00 Mfr#: 10MK0000UK
  • Core i5
  • IEEE 802.11n
The ThinkCenter M900 Tower is built to military specifications, and can withstand punishing treatment - humid environments, extreme temperatures, sustained vibration, dust, fungus and solar radiation. Add a solid-state drive (SSD), to keep your data safe from damage and PCIe SSD support works great with buffering, caching and content delivery applications, while significantly increasing overall performance.
Ensure your system is always up and running. Intel vPro technology helps to make enterprise-level manageability even more convenient and cost-efficient. Built-in management capabilities of Intel vPro allow IT administrators to access your system remotely - even when powered off - for diagnostics, repair and automating security patches and updates. Also, Intel's Stable Image Platform Program (SIPP) facilitates the often tricky process of transitioning from one technology generation to the next.
  • MIL-SPEC tough
  • Stay up and running
  • Convenience features
    The M900 Tower offers the convenience of an optional removable hard drive and a handle for portability. Attach devices and add-on controller cards to your M900's motherboard with the optional peripheral component interconnect (PCI) slot. And you can extend the life of your ThinkCenter M900 with Lenovo's specially-designed dust filters. The filters reduce dust intake by almost 40 percent - so your machine will last longer with less maintenance. The unobtrusive design can be conveniently removed for cleaning.
Lenovo ThinkCentre M910s - SFF - Core i5 7500 3.4 GHz - 4 GB - 500 GB - UK
Platform Technology
Intel vPro Technology
Personal computer
Product Form Factor
Small form factor
Built-in Devices
Speaker
Embedded Security
Trusted Platform Module (TPM 2.0) Security Chip
Processor / Chipset
CPU
Intel Core i5 (7th Gen) 7500 / 3.4 GHz
Max Turbo Speed
3.8 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
Processor Main Features
Intel Turbo Boost Technology 2
Chipset Type
Intel Q270
Cache Memory
Installed Size
6 MB
Cache Per Processor
6 MB
RAM
Installed Size
4 GB / 64 GB (max)
DDR4 SDRAM
Effective Memory Speed
2400 MHz
Rated Memory Speed
2400 MHz
DIMM 288-pin
Slots
4 (Total) / 3 (empty)
Unbuffered, dual channel memory architecture
Configuration Features
1 x 4 GB
Hard Drive
HDD
1 x 500 GB
Interface Type
SATA 6Gb/s
Spindle Speed
7200 rpm
Storage Controller
1 x SATA
Controller Interface Type
SATA 6Gb/s
Optical Storage
DVD-Writer - SATA
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Intel HD Graphics 630
Video Interfaces
VGA, DisplayPort
Audio Output
High Definition Audio
Input Device
Mouse, keyboard
Keyboard
USB
Localization & Layout
Mouse
USB
Interface (Bus) Type
M.2 Card
Ethernet Controller
Intel I219-LM
Wireless LAN Supported
Wireless NIC
Intel Dual Band Wireless-AC 8260
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 4.1
Wake on LAN (WoL)
Bays
1 (total) / 0 (free) x external 5.25" Slim Line , 1 (total) / 0 (free) x internal 3.5" , 1 (total) / 1 (free) x internal 2.5"
Slots
4 (total) / 3 (free) x DIMM 288-pin , 1 (total) / 0 (free) x CPU , 1 (total) / 1 (free) x PCIe 3.0 x16 - low-profile , 1 (total) / 1 (free) x PCIe 3.0 x16 - low-profile (x4 mode) , 1 (total) / 1 (free) x PCIe 3.0 x1 - low-profile
8 x USB 3.0 (4 front, 4 rear) , 2 x microphone - mini-jack (1 front, 1 rear) , 1 x headphones - mini-jack (1 in front) , 1 x LAN (Gigabit Ethernet) , 1 x serial , 2 x DisplayPort , 1 x audio line-in - mini-jack , 1 x audio line-out - mini-jack , 1 x VGA
Theft/Intrusion Protection
Security lock slot (cable lock sold separately), padlock loop
Security Slot Type
Kensington security slot
RoHS, GREENGUARD, Energy-Related Products (ErP) Lot 3
Manufacturer Selling Program
TopSeller
Power supply
Nominal Voltage
Power Provided
210 Watt
Efficiency
85%
Operating System / Software
OS Provided
Windows 10 Pro 64-bit Edition
Software
Cyberlink PowerDVD, Lenovo Companion, Intel Unite, PowerDVD Create, Lenovo ID
Environmental Standards
ENERGY STAR Certified
ENERGY STAR Version
6.1
Limited warranty - 3 years - on-site
9.25 cm
29.05 cm
34.35 cm
5.4 kg
Keyboards and Mice (1)
D11H Lenovo Optical 3-button W/Mouse USB In Stock £12.69
Other bundles (1)
D11H Lenovo Microsaver Security Cable Lock In Stock £33.41
