The ThinkCenter M900 Tower is built to military specifications, and can withstand punishing treatment - humid environments, extreme temperatures, sustained vibration, dust, fungus and solar radiation. Add a solid-state drive (SSD), to keep your data safe from damage and PCIe SSD support works great with buffering, caching and content delivery applications, while significantly increasing overall performance.
Ensure your system is always up and running. Intel vPro technology helps to make enterprise-level manageability even more convenient and cost-efficient. Built-in management capabilities of Intel vPro allow IT administrators to access your system remotely - even when powered off - for diagnostics, repair and automating security patches and updates. Also, Intel's Stable Image Platform Program (SIPP) facilitates the often tricky process of transitioning from one technology generation to the next.
- Lenovo ThinkCentre M910q - tiny - Core i7 7700T 2.9 GHz - vPro - 8 GB - SSD 256 GB - UK
- Personal computer - tiny
- Platform Technology
- Intel vPro Platform
- Localisation
- Processor
- Intel Core i7 (7th Gen) 7700T / 2.9 GHz (, up to 3.8 GHz, (Quad-Core)
- Processor Socket
- LGA1151 Socket
- Processor Main Features
- Hyper-Threading Technology, Intel Turbo Boost Technology 2, Intel Smart Cache
- Cache Memory
- 8 MB
- Cache Per Processor
- 8 MB
- RAM
- 8 GB (installed) / 32 GB (max) - DDR4 SDRAM - non-ECC
- Storage Controller
- SATA (SATA 6Gb/s)
- Hard Drive
- SSD 256 GB - PCI Express 3.0 x4 - M.2 - NVM Express (NVMe)
- Optical Storage
- No optical drive
- Graphics Controller
- Intel HD Graphics 630
- Networking
- 1GbE, 802.11a, 802.11b/g/n, Wi-Fi 5, Bluetooth 4.1
- Keyboard
- UK
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Windows 10 Pro 64-bit Edition
- Software Included
- Lenovo Companion, Lenovo ID
- Black
- 17.9 cm x 18.29 cm x 3.45 cm
- 1.32 kg
- Manufacturer Selling Program
- TopSeller
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - 3 years - on-site
- Personal computer
- Product Form Factor
- Tiny
- Built-in Devices
- Speaker
- Embedded Security
- Trusted Platform Module (TPM 2.0) Security Chip
- Black
- Localisation
Processor / Chipset
- CPU
- Clock Speed
- 2.9 GHz
- Max Turbo Speed
- 3.8 GHz
- Number of Cores
- Quad-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Socket
- LGA1151 Socket
- Chipset Type
- Intel Q270
Cache Memory
- Installed Size
- 8 MB
- 8 MB
RAM
- Installed Size
- 8 GB / 32 GB (max)
- Technology
- Effective Memory Speed
- 2400 MHz
- Rated Memory Speed
- 2400 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots
- 2 (Total) / 1 (empty)
- Unbuffered, dual channel memory architecture
- Configuration Features
- 1 x 8 GB
Hard Drive
- SSD - M.2
- Capacity
- 1 x 256 GB
- Interface Type
Storage Controller
- 1 x SATA
- Controller Interface Type
- SATA 6Gb/s
- Channel Qty
- 1
Optical Storage
- No optical drive
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- Video Interfaces
- HDMI, DisplayPort
- Max Monitors Supported
- 3
Audio Output
- High Definition Audio
Input Device
- Mouse, keyboard
Keyboard
- Interface
- USB
- Localization & Layout
- UK
Mouse
- Interface
- USB
- Interface (Bus) Type
- M.2 Card
- Ethernet Controller
- Intel I219-LM
- Wireless LAN Supported
- Wireless NIC
- Intel Dual Band Wireless-AC 8265
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 4.1
- Wake on LAN (WoL)
- Bays
- 1 (total) / 1 (free) x internal 2.5" x 1/8H
- Slots
- 2 (total) / 0 (free) x M.2 Card
- 6 x USB 3.1 Gen 1 (2 front, 4 rear) (one of them is Always On and fast-charging) , 1 x microphone (1 in front) , 1 x headphones/microphone (1 in front) , 1 x LAN (Gigabit Ethernet) , 2 x DisplayPort , 1 x HDMI , 1 x serial
- Included Accessories
- VESA mounting kit, adapter cage
- Theft/Intrusion Protection
- Security lock slot (cable lock sold separately), chassis intrusion switch, tool-less chassis access
- Security Slot Type
- Kensington security slot
- VESA Mounting Interface
- 100 x 100 mm, 75 x 75 mm
- RoHS, GREENGUARD, Energy-Related Products (ErP) Lot 3
- TopSeller
- Power adapter
- Voltage Required
- Power Provided
- 65 Watt
- Efficiency
- 88%
Operating System / Software
- OS Provided
- Software
Sustainability Information
- ENERGY STAR Certified
- ENERGY STAR Version
- 6.1
- 17.9 cm
- 18.29 cm
- 3.45 cm
- 1.32 kg
