Lenovo ThinkCentre M910Q USFF Core i5-7500T 4GB 128GB SSD Win 10 Pr
Quicklinx: D11NWS00 Mfr#: 10MV001KUK
Processor Type: Core i5
Operating System: Windows 10 Pro 64-bit Edition
Installed Memory: 4GB
Hard Drive Capacity: 128GB
Storage Type: SSD
  • Core i5
  • IEEE 802.11n
£644.03 ex VAT
£772.83 inc VAT
The ThinkCenter M900 Tower is built to military specifications, and can withstand punishing treatment - humid environments, extreme temperatures, sustained vibration, dust, fungus and solar radiation. Add a solid-state drive (SSD), to keep your data safe from damage and PCIe SSD support works great with buffering, caching and content delivery applications, while significantly increasing overall performance.
Ensure your system is always up and running. Intel vPro technology helps to make enterprise-level manageability even more convenient and cost-efficient. Built-in management capabilities of Intel vPro allow IT administrators to access your system remotely - even when powered off - for diagnostics, repair and automating security patches and updates. Also, Intel's Stable Image Platform Program (SIPP) facilitates the often tricky process of transitioning from one technology generation to the next.
  • MIL-SPEC tough
  • Stay up and running
  • Convenience features
    The M900 Tower offers the convenience of an optional removable hard drive and a handle for portability. Attach devices and add-on controller cards to your M900's motherboard with the optional peripheral component interconnect (PCI) slot. And you can extend the life of your ThinkCenter M900 with Lenovo's specially-designed dust filters. The filters reduce dust intake by almost 40 percent - so your machine will last longer with less maintenance. The unobtrusive design can be conveniently removed for cleaning.
Lenovo ThinkCentre M910q - tiny - Core i5 7500T 2.7 GHz - 4 GB - 128 GB
Personal computer - tiny
1 x Intel Core i5 (7th Gen) 7500T / 2.7 GHz (3.3 GHz) (Quad-Core)
Processor Main Features
Intel Turbo Boost Technology 2
Cache Memory
6 MB
Cache Per Processor
6 MB
RAM
4 GB (installed) / 32 GB (max) - DDR4 SDRAM - non-ECC
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
1 x SSD 128 GB - PCI Express 3.0 x4 - M.2 - NVM Express (NVMe)
Optical Storage
No optical drive
Graphics Controller
Intel HD Graphics 630
GigE, 802.11a, 802.11b/g/n, 802.11ac, Bluetooth 4.1
OS Provided
17.9 cm x 18.29 cm x 3.45 cm
1.32 kg
Manufacturer Selling Program
TopSeller
Environmental Standards
ENERGY STAR Qualified
Limited warranty - 3 years - on-site
Personal computer
Product Form Factor
Tiny
Built-in Devices
Speaker
Embedded Security
Trusted Platform Module (TPM 2.0) Security Chip
Processor / Chipset
CPU
Max Turbo Speed
3.3 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
Chipset Type
Intel Q270
Cache Memory
Installed Size
6 MB
Cache Per Processor
6 MB
RAM
Installed Size
4 GB / 32 GB (max)
Effective Memory Speed
2400 MHz
Rated Memory Speed
2400 MHz
SO-DIMM 260-pin
Slots
2 (Total) / 1 (empty)
Dual channel memory architecture
Configuration Features
1 x 4 GB
Hard Drive
SSD - M.2
1 x 128 GB
Interface Type
PCI Express 3.0 x4
NVM Express (NVMe)
Storage Controller
1 x SATA
Controller Interface Type
SATA 6Gb/s
Channel Qty
1
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Video Interfaces
VGA, DisplayPort
Max Monitors Supported
3
Audio Output
High Definition Audio
Input Device
Mouse, keyboard
Keyboard
USB
Mouse
USB
Ethernet Controller
Intel I219-LM
Wireless LAN Supported
Wireless NIC
Intel Dual Band Wireless-AC 8265
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 4.1
Wake on LAN (WoL)
Bays
1 (total) / 1 (free) x internal 2.5"
Slots
2 (total) / 1 (free) x SO-DIMM 260-pin , 1 (total) / 0 (free) x CPU , 2 (total) / 0 (free) x M.2 Card
6 x USB 3.1 Gen 1 (2 front, 4 rear) (one of them is Always On and fast-charging) , 1 x microphone (1 in front) , 1 x headphones/microphone (1 in front) , 1 x LAN (Gigabit Ethernet) , 2 x DisplayPort , 1 x VGA , 1 x serial
Vertical stand, dust filter
Theft/Intrusion Protection
Security lock slot (cable lock sold separately), chassis intrusion switch, tool-less chassis access
Security Slot Type
Kensington security slot
RoHS, GREENGUARD, Energy-Related Products (ErP) Lot 3
TopSeller
Power adapter
Nominal Voltage
Power Provided
65 Watt
Efficiency
88%
Operating System / Software
OS Provided
Software
Lenovo Companion, Lenovo ID
ENERGY STAR Certified
ENERGY STAR Version
6.1
17.9 cm
18.29 cm
3.45 cm
1.32 kg
Lenovo ThinkCentre M910Q USFF Core i5-7500T 4GB 128GB SSD Win 10 Pr Bundle deal on Lenovo ThinkCentre M910Q USFF Core i5-7500T 4GB 128GB SSD Win 10 Pr
£830.49
saving £8.33
£743.79
Keyboards and Mice (1)
D11N Lenovo Optical 3-button W/Mouse USB In Stock £13.60
Other bundles (1)
D11N Lenovo Microsaver Security Cable Lock In Stock £23.87
Storage Type: SSD
Processor Model: I5-7500T
Type: Personal computer
Case Style: Ultra small form factor
Optical Storage: None
Brand: Lenovo
Price Range Ex VAT: 500 - 750
