Lenovo ThinkCentre M90s SFF i5 8GB 256GB W10P 3Yr PS
Quicklinx: H2ZWWS00 Mfr#: 11D1003WUK
  • Core i5
ThinkCentre M90s offers robust, unrivaled performance, lightning-fast speed, productivity enhancing upgrades like Modern Standby, and the ability to connect to up to three displays. Maximum expandability lets you bridge between legacy peripherals and future storage needs.
  • Faster than the speed of thought
    ThinkCentre M90s desktop PC runs at the speed of human imagination. With up to 10 th Gen Intel Core i9 vPro processors and 4 DDR4 UDIMM (2933Mhz) slots for up to 128GB memory support, it has the power you need to run the demanding software that your industry requires.
  • Security inside and out
    ThinkCentre devices allow your employees to innovate fearlessly with the reinforced security of ThinkShield. It's the most comprehensive end-to-end security solution, featuring a self-healing BIOS, discrete Trusted Platform Module (dTPM) 2.0 chip, Smart USB protection, and more that can be customized to meet your needs. The option of the Intel vPro accelerates business productivity, safeguards data, and lets you gain long-term stability. Plus, Kensington lock slots and chassis e-locks provide physical security to protect against theft.
  • Exponential growth
    Your business will never outgrow the ThinkCentre M90s small form factor PC, which offers an array of HDD and SDD expansion slots, giving you the ability to swap in newer and bigger storage drives as your needs expand. Add graphics cards to support industry-specific imaging equipment, use the plentiful expansion slots to connect to legacy peripherals-the possibilities are endless.
  • Make every minute a work minute
    Keep the M90s desktop connected to the internet and up to date even in sleep mode with Modern Standby. It saves precious time so you can keep work moving efficiently. Additionally, it offers a more convenient user experience with the ability to connect to three displays and a USB-C port located on the front panel that enables quick data sharing.
  • Comprehensive manageability
    IT professionals will appreciate that ThinkCentre M90s is easy to deploy and easy to manage from both a software and hardware standpoint. Expansion is hassle-free as well, thanks to an ease-of-use design that offers quick access to the DIMM, HDD, SDD, and optical disc drive. The option of Intel vPro platform is built for business, so you have the assurance that you're getting everything you need to run productively, more securely, and cost-effectively, 24/7.
  • Buy this PC and get a Free upgrade to Windows 11 when available. 1
    1 Upgrade rollout plan is being finalized and is scheduled to begin late in 2021 and continue into 2022. Specific timing will vary by device.
Lenovo ThinkCentre M90s - SFF Core i5 10600 3.3 GHz - vPro - 8 GB - SSD 256 GB - UK
Personal computer - SFF
Bundled Services
3 Years Lenovo Premier Support
Platform Technology
Intel vPro Platform
Intel Core i5 (10th Gen) 10600 / 3.3 GHz (up to 4.8 GHz, (6-core)
Cache Memory
12 MB
Cache Per Processor
12 MB
RAM
8 GB (installed) / 128 GB (max) - DDR4 SDRAM - non-ECC
Storage Controller
SATA
Hard Drive
SSD 256 GB - PCI Express 3.0 x4 - M.2 2280 - TCG Opal Encryption
Optical Storage
DVD-Writer
Card Reader
3 in 1
Graphics Controller
Intel UHD Graphics 630 Shared Video Memory (UMA)
1GbE
Keyboard
(50/60 Hz)
OS Provided
Windows 10 Pro 64-bit Edition
9.3 cm x 29.8 cm x 34 cm
5.3 kg
Manufacturer Selling Program
Lenovo TopSeller
Environmental Standards
ENERGY STAR Qualified EPEAT Silver
Limited warranty - 3 years - on-site
Platform Technology
Intel vPro Platform
Personal computer
Bundled Services
Product Form Factor
SFF
Built-in Devices
Speaker
Embedded Security
Trusted Platform Module (TPM 2.0) Security Chip
Processor / Chipset
CPU
Clock Speed
3.3 GHz
Max Turbo Speed
4.8 GHz
Number of Cores
6-core
CPU Qty
1
Max CPU Qty
1
Chipset Type
Intel Q470
Cache Memory
Installed Size
12 MB
Cache Per Processor
12 MB
RAM
Installed Size
Effective Memory Speed
2666 MT/s
DIMM 288-pin
Slots
4 (Total) / 3 (empty)
Unbuffered, dual channel memory architecture
Configuration Features
1 x 8 GB
Hard Drive
SSD - M.2 2280
1 x 256 GB
Interface Type
PCI Express 3.0 x4
TCG Opal Encryption
Storage Controller
1 x SATA
Optical Storage
DVD-Writer - SATA
Card Reader
3 in 1 card reader
Supported Flash Memory Cards
SD Memory Card, SDHC Memory Card, SDXC Memory Card
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Video Interfaces
DisplayPort
Max Monitors Supported
3
Audio Output
High Definition Audio
Input Device
Mouse, keyboard
Keyboard
Keyboard Name
Lenovo Traditional Keyboard
USB
Localization & Layout
Mouse
Mouse Name
Lenovo Calliope Mouse
USB
Ethernet Controller
Intel I219-LM
Wake on LAN (WoL)
DASH
Bays
1 (total) / 0 (free) x external 5.25" Slim Line , 1 (total) / 1 (free) x internal 3.5"
Slots
1 (total) / 1 (free) x PCIe 3.0 x16 - low-profile , 1 (total) / 1 (free) x PCIe 3.0 x1 - low-profile , 1 (total) / 1 (free) x PCIe 3.0 x4 - low-profile , 3 (total) / 2 (free) x M.2 Card
2 x USB 3.2 Gen 2 (2 in front) , 6 x USB 3.2 Gen 1 (2 front, 4 rear) , 1 x USB-C 3.2 Gen 1 (1 in front) , 1 x microphone (1 in front) , 1 x headphones/microphone (1 in front) , 1 x serial , 1 x LAN (Gigabit Ethernet) , 3 x DisplayPort , 1 x audio line-out , 2 x USB 2.0
Smart cable clip
Theft/Intrusion Protection
Security lock slot (cable lock sold separately), padlock loop, chassis intrusion switch
Security Slot Type
Kensington security slot
RoHS, Energy-Related Products (ErP) Lot 3
Lenovo TopSeller
Power supply
AC 100-240 V (50/60 Hz)
Power Provided
260 watt
Efficiency
85%
Operating System / Software
OS Provided
Windows 10 Pro 64-bit Edition English
Sustainability Information
EPEAT Compliant
EPEAT Silver
ENERGY STAR Certified
ENERGY STAR Version
8.0
9.3 cm
29.8 cm
34 cm
5.3 kg
Accessories (1)
H2ZW Lenovo USB Soundbar for Display In Stock £29.71
Keyboards and Mice (1)
H2ZW Lenovo ThinkPad Bluetooth Silent Mouse - Right and Left-handed In Stock £23.75
Other bundles (3)
H2ZW Lenovo DisplayPort Adapter - DisplayPort (M) to DisplayPort (F) In Stock £66.79
H2ZW Kensington Security Cable Lock In Stock £23.88
H2ZW Lenovo Thinkvision MC50 Monitor Webcam In Stock £52.96
