Despite being smaller than an old VHS cassette, the ThinkCentre M90n delivers the same powerful performance as a regular desktop computer, yet uses less energy. By boosting productivity and reducing utility bills, the ThinkCentre M90n is a boon for any business.
Free up your workspace
With a wide choice of easy-to-install mounting and bracket accessories, you can house your ThinkCentre M90n almost anywhere - on a wall, under a desk, or on a shelf. It's also compatible with various docking solutions, enabling you to have even more ports and flexibility. -
Engineered for today & tomorrow
The modular design of the ThinkCentre M90n lets you custom-build the perfect all-in-one PC. As your business needs change, so can your PC without having to replace the display, which can be more costly. -
Easy deployment, seamless connectivity
Deploying the ThinkCentre M90n is simple. Just plug a cable into the USB-C port, hook it up to a monitor, projector, or ThinkCentre Tiny-in-One, and you're good to go. You'll also enjoy lightning-quick connectivity - for faster data transfers, higher-res displays, multitasking, and much more. -
Built-in security
Each ThinkCentre M90n is fitted with the Trusted Platform Module (TPM) chipset, an international standard for safeguarding critical data such as passwords and encryption keys. In addition, the M90n is fitted with a Kensington lock slot, so you can secure your device when working in a public place. -
Tested to the max & beyond
Part of the renowned Think family, the ThinkCentre M90n is one tough, durable machine. Able to meet military-specification requirements and other stringent quality checks, it can withstand the harshest of working conditions - from the Arctic cold to desert sand and heat.
- Lenovo ThinkCentre M90n-1 - nano - Core i7 8665U 1.9 GHz - 16 GB - SSD 512 GB - UK
- Personal computer - nano
- Platform Technology
- Intel vPro Technology
- Localisation
- Processor
- Intel Core i7 (8th Gen) 8665U / 1.9 GHz (4.8 GHz) (Quad-Core)
- Cache Memory
- 8 MB
- Cache Per Processor
- 8 MB
- RAM
- 16 GB DDR4 SDRAM - non-ECC
- Storage Controller
- SATA
- Hard Drive
- SSD 512 GB - PCI Express 3.0 x4 - M.2 2280 - TCG Opal Encryption, NVM Express (NVMe)
- Optical Storage
- No optical drive
- Graphics Controller
- Intel UHD Graphics 620
- Networking
- GigE, 802.11ac, Bluetooth 5.0
- Keyboard
- UK
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Windows 10 Pro 64-bit Edition
- Iron grey (top cover), black (mid bezel), red (bottom cover)
- 17.9 cm x 8.8 cm x 2.2 cm
- 505 g
- Manufacturer Selling Program
- TopSeller
- Environmental Standards
- TCO Certified Desktops 8, ENERGY STAR Qualified
- Limited warranty - 3 years - on-site
- Personal computer
- Product Form Factor
- Nano
- Built-in Devices
- Speaker
- Embedded Security
- Trusted Platform Module (TPM 2.0) Security Chip
- Localisation
Processor / Chipset
- CPU
- Max Turbo Speed
- 4.8 GHz
- Number of Cores
- Quad-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
Cache Memory
- Installed Size
- 8 MB
- 8 MB
RAM
- Installed Size
- 16 GB
- Technology
- DDR4 SDRAM - non-ECC
- Effective Memory Speed
- 2400 MHz
- Rated Memory Speed
- 2666 MHz
- Configuration Features
- Provided memory is soldered
Hard Drive
- SSD - M.2 2280
- Capacity
- 1 x 512 GB
- Interface Type
Storage Controller
- 1 x SATA
- RAID Level
- RAID 0, RAID 1
Optical Storage
- No optical drive
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- Video Interfaces
- DisplayPort
- Max Monitors Supported
- 2
Input Device
- Mouse, keyboard
Keyboard
- Keyboard Name
- Lenovo Calliope Keyboard
- Connectivity
- Wireless
- Localization & Layout
- UK
Mouse
- Mouse Name
- Lenovo Calliope Mouse
- Connectivity
- Wireless
- Ethernet Controller
- Intel I219-LM
- Wireless LAN Supported
- Wireless NIC
- Intel Wireless-AC 9560
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11ac, Bluetooth 5.0
- Wake on LAN (WoL)
- Slots
- 3 (total) / 1 (free) x M.2 Card
- 4 x USB 3.1 Gen 2 (2 front, 2 rear) , 2 x USB-C 3.1 Gen 2 (1 front, 1 rear) , 1 x headphones/microphone (1 in front) , 1 x LAN (Gigabit Ethernet) , 1 x DisplayPort
- Theft/Intrusion Protection
- Security lock slot (cable lock sold separately), chassis intrusion switch
- Security Slot Type
- Kensington security slot
- RoHS, WEEE, REACH, Energy-Related Products (ErP) Lot 3, MIL-STD-810H
- TopSeller
- Power adapter
- Nominal Voltage
- Power Provided
- 65 Watt
- Efficiency
- 88%
Operating System / Software
- OS Provided
- Windows 10 Pro 64-bit Edition English
- TCO Certified
- ENERGY STAR Certified
- ENERGY STAR Version
- 7.1
- 17.9 cm
- 8.8 cm
- 2.2 cm
- 505 g
Lenovo Microsaver Security Cable Lock | In Stock | £34.29 |
