Lenovo ThinkCentre M90n-1 Nano Intel Core i7-8665U 16GB 512GB SSD Windows 10 Professional 64-bit
Quicklinx: FGHXWS00 Mfr#: 11AD000YUK
Processor Type: Core i7
Operating System: Windows 10 Pro 64-bit Edition
Installed Memory: 16GB, 16GB
Hard Drive Capacity: 512GB
Storage Type: SSD
  • Core i7
£891.34 ex VAT
£1,069.60 inc VAT
Despite being smaller than an old VHS cassette, the ThinkCentre M90n delivers the same powerful performance as a regular desktop computer, yet uses less energy. By boosting productivity and reducing utility bills, the ThinkCentre M90n is a boon for any business.
  • Free up your workspace
    With a wide choice of easy-to-install mounting and bracket accessories, you can house your ThinkCentre M90n almost anywhere - on a wall, under a desk, or on a shelf. It's also compatible with various docking solutions, enabling you to have even more ports and flexibility.
  • Engineered for today & tomorrow
    The modular design of the ThinkCentre M90n lets you custom-build the perfect all-in-one PC. As your business needs change, so can your PC without having to replace the display, which can be more costly.
  • Easy deployment, seamless connectivity
    Deploying the ThinkCentre M90n is simple. Just plug a cable into the USB-C port, hook it up to a monitor, projector, or ThinkCentre Tiny-in-One, and you're good to go. You'll also enjoy lightning-quick connectivity - for faster data transfers, higher-res displays, multitasking, and much more.
  • Built-in security
    Each ThinkCentre M90n is fitted with the Trusted Platform Module (TPM) chipset, an international standard for safeguarding critical data such as passwords and encryption keys. In addition, the M90n is fitted with a Kensington lock slot, so you can secure your device when working in a public place.
  • Tested to the max & beyond
    Part of the renowned Think family, the ThinkCentre M90n is one tough, durable machine. Able to meet military-specification requirements and other stringent quality checks, it can withstand the harshest of working conditions - from the Arctic cold to desert sand and heat.
Lenovo ThinkCentre M90n-1 - nano - Core i7 8665U 1.9 GHz - 16 GB - SSD 512 GB - UK
Personal computer - nano
Platform Technology
Intel vPro Technology
Intel Core i7 (8th Gen) 8665U / 1.9 GHz (4.8 GHz) (Quad-Core)
Cache Memory
8 MB
Cache Per Processor
8 MB
RAM
16 GB DDR4 SDRAM - non-ECC
Storage Controller
SATA
Hard Drive
SSD 512 GB - PCI Express 3.0 x4 - M.2 2280 - TCG Opal Encryption, NVM Express (NVMe)
Optical Storage
No optical drive
Graphics Controller
Intel UHD Graphics 620
GigE, 802.11ac, Bluetooth 5.0
Keyboard
OS Provided
Iron grey (top cover), black (mid bezel), red (bottom cover)
17.9 cm x 8.8 cm x 2.2 cm
505 g
Manufacturer Selling Program
TopSeller
Environmental Standards
TCO Certified Desktops 8, ENERGY STAR Qualified
Limited warranty - 3 years - on-site
Platform Technology
Personal computer
Product Form Factor
Nano
Built-in Devices
Speaker
Embedded Security
Trusted Platform Module (TPM 2.0) Security Chip
Processor / Chipset
CPU
Max Turbo Speed
4.8 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
Cache Memory
Installed Size
8 MB
Cache Per Processor
8 MB
RAM
Installed Size
16 GB
Effective Memory Speed
2400 MHz
Rated Memory Speed
2666 MHz
Configuration Features
Provided memory is soldered
Hard Drive
SSD - M.2 2280
1 x 512 GB
Interface Type
PCI Express 3.0 x4
Storage Controller
1 x SATA
RAID Level
RAID 0, RAID 1
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Video Interfaces
DisplayPort
Max Monitors Supported
2
Input Device
Mouse, keyboard
Keyboard
Keyboard Name
Lenovo Calliope Keyboard
Wireless
Localization & Layout
Mouse
Mouse Name
Lenovo Calliope Mouse
Wireless
Ethernet Controller
Intel I219-LM
Wireless LAN Supported
Wireless NIC
Intel Wireless-AC 9560
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11ac, Bluetooth 5.0
Wake on LAN (WoL)
Slots
3 (total) / 1 (free) x M.2 Card
4 x USB 3.1 Gen 2 (2 front, 2 rear) , 2 x USB-C 3.1 Gen 2 (1 front, 1 rear) , 1 x headphones/microphone (1 in front) , 1 x LAN (Gigabit Ethernet) , 1 x DisplayPort
Theft/Intrusion Protection
Security lock slot (cable lock sold separately), chassis intrusion switch
Security Slot Type
Kensington security slot
RoHS, WEEE, REACH, Energy-Related Products (ErP) Lot 3, MIL-STD-810H
TopSeller
Power adapter
Nominal Voltage
Power Provided
65 Watt
Efficiency
88%
Operating System / Software
OS Provided
Windows 10 Pro 64-bit Edition English
TCO Certified
ENERGY STAR Certified
ENERGY STAR Version
7.1
17.9 cm
8.8 cm
2.2 cm
505 g
FGHX Lenovo Microsaver Security Cable Lock In Stock £34.29
Storage Type: SSD
Processor Model: I7-8665U
Type: Personal computer
Case Style: Ultra small form factor
Optical Storage: None
Brand: Lenovo
Price Range Ex VAT: 750 - 1000
