Lenovo ThinkCentre M90n-1 Nano Intel Core i3-8145U 8GB 256GB SSD Windows 10 Professional 64-bit
Quicklinx: FGHVWS00 Mfr#: 11AD000UUK
  • Core i3
  • IEEE 802.11n
Despite being smaller than an old VHS cassette, the ThinkCentre M90n delivers the same powerful performance as a regular desktop computer, yet uses less energy. By boosting productivity and reducing utility bills, the ThinkCentre M90n is a boon for any business.
  • Free up your workspace
    With a wide choice of easy-to-install mounting and bracket accessories, you can house your ThinkCentre M90n almost anywhere - on a wall, under a desk, or on a shelf. It's also compatible with various docking solutions, enabling you to have even more ports and flexibility.
  • Engineered for today & tomorrow
    The modular design of the ThinkCentre M90n lets you custom-build the perfect all-in-one PC. As your business needs change, so can your PC without having to replace the display, which can be more costly.
  • Easy deployment, seamless connectivity
    Deploying the ThinkCentre M90n is simple. Just plug a cable into the USB-C port, hook it up to a monitor, projector, or ThinkCentre Tiny-in-One, and you're good to go. You'll also enjoy lightning-quick connectivity - for faster data transfers, higher-res displays, multitasking, and much more.
  • Built-in security
    Each ThinkCentre M90n is fitted with the Trusted Platform Module (TPM) chipset, an international standard for safeguarding critical data such as passwords and encryption keys. In addition, the M90n is fitted with a Kensington lock slot, so you can secure your device when working in a public place.
  • Tested to the max & beyond
    Part of the renowned Think family, the ThinkCentre M90n is one tough, durable machine. Able to meet military-specification requirements and other stringent quality checks, it can withstand the harshest of working conditions - from the Arctic cold to desert sand and heat.
Lenovo ThinkCentre M90n-1 - nano - Core i3 8145U 2.1 GHz - 8 GB - SSD 256 GB - UK
Personal computer - nano
Intel Core i3 (8th Gen) 8145U / 2.1 GHz (3.9 GHz) (Dual-Core)
Cache Memory
4 MB
Cache Per Processor
4 MB
RAM
8 GB DDR4 SDRAM - non-ECC
Storage Controller
SATA
Hard Drive
SSD 256 GB - PCI Express 3.0 x4 - M.2 2280 - TCG Opal Encryption, NVM Express (NVMe)
Optical Storage
No optical drive
Graphics Controller
Intel UHD Graphics 620
GigE, 802.11a, 802.11b/g/n, Wi-Fi 5, Bluetooth 5.0
Keyboard
OS Provided
Windows 10 Pro 64-bit Edition
Iron grey (top cover), black (mid bezel), red (bottom cover)
17.9 cm x 8.8 cm x 2.2 cm
505 g
Manufacturer Selling Program
TopSeller
Environmental Standards
TCO Certified Desktops 8, ENERGY STAR Qualified
Limited warranty - 3 years - on-site
Personal computer
Product Form Factor
Nano
Built-in Devices
Speaker
Embedded Security
Trusted Platform Module (TPM 2.0) Security Chip
Processor / Chipset
CPU
Clock Speed
2.1 GHz
Max Turbo Speed
3.9 GHz
Number of Cores
Dual-Core
CPU Qty
1
Max CPU Qty
1
Cache Memory
Installed Size
4 MB
Cache Per Processor
4 MB
RAM
Installed Size
8 GB
Effective Memory Speed
2400 MHz
Rated Memory Speed
2666 MHz
Configuration Features
Provided memory is soldered
Hard Drive
SSD - M.2 2280
1 x 256 GB
Interface Type
PCI Express 3.0 x4
Storage Controller
1 x SATA
RAID Level
RAID 0, RAID 1
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Video Interfaces
DisplayPort
Max Monitors Supported
2
Input Device
Mouse, keyboard
Keyboard
Keyboard Name
Lenovo Calliope Keyboard
Wireless
Localization & Layout
Mouse
Mouse Name
Lenovo Calliope Mouse
Wireless
Ethernet Controller
Intel I219-LM
Wireless LAN Supported
Wireless NIC
Intel Wireless-AC 9560
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 5.0
Wake on LAN (WoL)
Slots
3 (total) / 1 (free) x M.2 Card
4 x USB 3.1 Gen 2 (2 front, 2 rear) , 2 x USB-C 3.1 Gen 2 (1 front, 1 rear) , 1 x headphones/microphone (1 in front) , 1 x LAN (Gigabit Ethernet) , 1 x DisplayPort
Theft/Intrusion Protection
Security lock slot (cable lock sold separately), chassis intrusion switch
Security Slot Type
Kensington security slot
RoHS, WEEE, REACH, Energy-Related Products (ErP) Lot 3, MIL-STD-810H
TopSeller
Power adapter
Power Provided
65 Watt
Efficiency
88%
Operating System / Software
OS Provided
Windows 10 Pro 64-bit Edition English
Sustainability Information
TCO Certified
ENERGY STAR Certified
ENERGY STAR Version
7.1
17.9 cm
8.8 cm
2.2 cm
505 g
Monitors (6)
FGHV Lenovo ThinkVision M14 14" 1920x1080 6ms USB-C IPS LED Monitor In Stock £258.14
FGHV Lenovo ThinkVision T24d 24" 1920x1080 VGA HDMI DisplayPort IPS LED Monitor In Stock £202.02
FGHV Lenovo ThinkVision T27p-10 27" 3840x2160 HDMI DisplayPort USB-C IPS LED Monitor In Stock £454.54
FGHV Lenovo ThinkVision P27h-20 27" 2560x1440 6ms HDMI DisplayPort IPS LED Monitor In Stock £336.70
FGHV Lenovo ThinkVision T27q-20 27" 2560x1440 4ms HDMI DisplayPort IPS LED Monitor In Stock £312.68
FGHV Lenovo Tiny-in-One 22 21.5" 1920 x 1080 14ms Full HD LED monitor In Stock £246.91
Keyboards and Mice (4)
FGHV Lenovo Essential Wireless Keyboard and Mouse Combo - UK English 166 In Stock £41.29
FGHV Lenovo Professional Wireless Keyboard In Stock £53.47
FGHV Lenovo Essential Wired Keyboard and Mouse Combo - UK English In Stock £25.39
FGHV Lenovo ThinkPad Bluetooth Silent Mouse - Right and Left-handed In Stock £23.88
Other bundles (4)
FGHV Lenovo ThinkPad USB3.0 to Ethernet Adapter In Stock £16.07
FGHV Kensington Security Cable Lock In Stock £23.65
FGHV Lenovo 100 Headset on ear wired - USB black for IdeaPad 3 ThinkCe In Stock £35.79
FGHV Lenovo Thinkvision MC50 Monitor Webcam In Stock £54.13
