Lenovo ThinkCentre M900 Core i5-6500 4GB 500GB Windows 7 Pro
Quicklinx: CFJJWS00 Mfr#: 10FD0013UK
  • Core i5
  • IEEE 802.11n
  • Microsoft Windows 7 Professional 64-bit Edition
For large businesses (EDU/GOV/PUB etc.) with a need for a high-performance desktop PC, the ThinkCentre M900 provides the latest Intel technology without sacrificing security, stability, manageability and environmental friendliness.
  • Tiny form factor
    ThinkCent?r M900 Tiny is an ultra-small form factor. It offers mounting solutions, including support for standard VESA mounts and Tiny-in-One configurations - which transform your PC into a space-saving modular all-in-one. Tiny desktops fit just about anywhere, while still delivering reliable performance.
  • Intel vPro-ready
    The M900 Tiny includes vPro technology to make enterprise-level manageability even more convenient and cost-efficient. The built-in management capabilities of vPro allow IT administrators to access your PC remotely, even when the system if powered off, to diagnose and repair systems and automate security patches and updates - ensuring your system is always up and running.
  • Stable Image Platform Program
    Stable Image Platform Program (SIPP) facilitates the often tricky process of transitioning from one technology generation to the next.
  • Multiple monitor support
    Maximize productivity with independent display support for up to three monitors. The expanded work area and easier navigation between applications help reduce errors and improve productivity as you extend your desktop across multiple monitors.
  • Keyboard power-on support
    If you choose to mount this compact unit on the back of your monitor, you can still power on conveniently from the front, by simply pressing Alt+P on a USB-connected keyboard.
  • Fast data transfer
    Move data between the M900 Tiny and other devices quickly with USB 3.0 - it's extremely fast.
  • Variety of I/O support
    No matter your port needs, this desktop has you covered, with support for USB 3.0, DisplayPort, VGA, HDMI, LAN, and serial connections.
Lenovo ThinkCentre M900 - MT - Core i5 6500 3.2 GHz - vPro - 4 GB - HDD 500 GB - UK
Personal computer - mini tower
Platform Technology
Intel vPro Platform
Intel Core i5 (6th Gen) 6500 / 3.2 GHz (, up to 3.6 GHz, (Quad-Core)
Processor Socket
LGA1151 Socket
Processor Main Features
Intel Turbo Boost Technology 2
Cache Memory
6 MB
Cache Per Processor
6 MB
RAM
4 GB (installed) / 64 GB (max) - DDR4 SDRAM - non-ECC - PC4-17000
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
HDD 500 GB - SATA 6Gb/s - 7200 rpm
Optical Storage
DVD-Writer
Graphics Controller
Intel HD Graphics 530
GigE, 802.11a, 802.11b/g/n, Wi-Fi 5
Keyboard
OS Provided
Microsoft Windows 7 Professional 64-bit Edition (downgrade from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence
17.5 cm x 41.3 cm x 40.62 cm
12.5 kg
Limited warranty - 3 years - on-site
Platform Technology
Intel vPro Platform
Personal computer
Product Form Factor
Mini tower
Built-in Devices
Speaker
Processor / Chipset
CPU
Clock Speed
3.2 GHz
Max Turbo Speed
3.6 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
CPU Socket
LGA1151 Socket
Chipset Type
Intel Q170
Cache Memory
Installed Size
6 MB
Cache Per Processor
6 MB
RAM
Installed Size
4 GB / 64 GB (max)
Effective Memory Speed
2133 MHz
Rated Memory Speed
2133 MHz
Memory Specification Compliance
PC4-17000
DIMM 288-pin
Slots
4 (Total) / 3 (empty)
Unbuffered
Configuration Features
1 x 4 GB
Hard Drive
HDD
1 x 500 GB
Interface Type
SATA 6Gb/s
Spindle Speed
7200 rpm
Storage Controller
1 x SATA
Controller Interface Type
SATA 6Gb/s
Optical Storage
DVD-Writer - SATA
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Video Interfaces
VGA, DisplayPort
Input Device
Mouse, keyboard
Keyboard
USB
Localization & Layout
Mouse
Optical
USB
Wireless LAN Supported
Wireless NIC
Intel Dual Band Wireless-AC 8260
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Bays
2 (total) / 1 (free) x external 5.25" x 1/2H , 1 (total) / 0 (free) x internal 3.5" x 1/3H
Slots
4 (total) / 3 (free) x DIMM 288-pin , 1 (total) / 0 (free) x CPU
8 x USB 3.0 (2 front, 6 rear) , 1 x VGA , 2 x DisplayPort , 1 x LAN (Gigabit Ethernet) , 1 x serial
Power supply
Power Provided
250 Watt
Efficiency
85%
Operating System / Software
OS Provided
Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence
17.5 cm
41.3 cm
40.62 cm
12.5 kg
CFJJ C2G 3m DisplayPort Cable with Latches M/M - Black In Stock £13.17
