The Lenovo ThinkCentre Mp83 takes productivity, manageability and efficiency to the next level. The desktop is available in Mini TW, SFF Pro and Tiny and is designed specifically for the rigorous demands of large enterprises, public customers and the world of education. As a leading 1L-sized product, Tiny supports Intel Core i7 for extreme computing power. Tiny can also support the industry no. 1 USB KB power on for a better user experience. The innovative SFF Pro supports Dual HDDs and Dual Graphics, which provide TW expansion ability.
Platform stability
The M83 desktop features Intel Stable Image Platform Program (SIPP) and a life cycle with no planned hardware changes that affect the preloaded software image. Image stability for long-term deployments helps to reduce transition, qualification, and testing costs to ensure savings for your business. -
Multiple monitor display
Maximize productivity with independent display support for up to three monitors - or four via mosaic mode. The expanded work area and easier navigation between applications helps reduce errors and improve productivity as you extend your desktop across multiple monitors. -
Solid security and manageability
M83 desktops include some of the best security tools available in the industry, including USB ports disablement to help prevent data theft and network security risks against unauthorized use of storage devices. The Trusted Platform Module (TPM) encrypts data and key information like passwords and digital certificates, further securing applications, electronic transactions, and online communication. -
Advanced thermal design
Intelligent Cooling Engine (ICE) 3.0 is designed to provide a balance between thermals and acoustics resulting in long desktop life. With two optimized settings, you choose the performance mode that best suits your work environment, prioritizing temperature or sound. Plus, ICE 3.0 allows for working in hotter temperatures and enables system monitoring with thermal alerts that preempt overheating possibilities.
- Lenovo ThinkCentre M83 - tiny - Core i3 4150T 3 GHz - 4 GB - HDD 500 GB - UK
- Personal computer - tiny - 1 USB 3.0 (Always On)
- Localisation
- Processor
- Intel Core i3 (4th Gen) 4150T / 3 GHz (Dual-Core)
- Processor Socket
- LGA1150 Socket
- Cache Memory
- 3 MB
- Cache Per Processor
- 3 MB
- RAM
- 4 GB (installed) / 16 GB (max) - DDR3 SDRAM - PC3-12800
- Storage Controller
- SATA (SATA 6Gb/s)
- Hard Drive
- HDD 500 GB - SATA - 7200 rpm
- Optical Storage
- No optical drive
- Graphics Controller
- Intel HD Graphics 4400
- Audio Output
- Integrated
- Networking
- GigE
- Keyboard
- UK
- OS Provided
- Microsoft Windows 7 Professional 64-bit Edition (downgrade from Windows 8.1 Pro 64-bit) + Windows 8.1 Pro 64-bit Licence
- 17.9 cm x 18.2 cm x 3.45 cm
- 1.98 kg
- Limited warranty - 3 years - on-site
- Personal computer
- Product Form Factor
- Tiny
- Built-in Devices
- Speaker
- Localisation
Processor / Chipset
- CPU
- Clock Speed
- 3 GHz
- Number of Cores
- Dual-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Socket
- LGA1150 Socket
Cache Memory
- Installed Size
- 3 MB
- 3 MB
RAM
- Installed Size
- 4 GB / 16 GB (max)
- Technology
- DDR3 SDRAM
- Effective Memory Speed
- 1600 MHz
- Rated Memory Speed
- 1600 MHz
- Memory Specification Compliance
- PC3-12800
- Form Factor
- SO-DIMM 204-pin
- Slots
- 2 (Total)
Hard Drive
- HDD
- Capacity
- 1 x 500 GB
- Interface Type
- SATA
- Spindle Speed
- 7200 rpm
Storage Controller
- 1 x SATA - integrated
- Controller Interface Type
- SATA 6Gb/s
Optical Storage
- No optical drive
Monitor
- Monitor Type
- None.
Graphics Controller
- Integrated
- Graphics Processor
- Video Interfaces
- VGA, DisplayPort
Audio Output
- Integrated
Input Device
- Mouse, keyboard
Keyboard
- Interface
- USB
- Localization & Layout
- UK
Mouse
- Technology
- Optical
- Interface
- USB
- Integrated
- Data Link Protocol
- Slots
- 2 SO-DIMM 204-pin , 1 (total) / 0 (free) x CPU , 1 (total) / 1 (free) x PCIe Mini Card
- 2 x USB 3.0 (2 in front) , 3 x USB 2.0 , 1 x microphone (1 in front) , 1 x headphones/microphone (1 in front) , 1 x LAN (Gigabit Ethernet) , 1 x VGA , 1 x DisplayPort
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- Power adapter
Operating System / Software
- OS Provided
- Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 8.1 Pro 64-bit) + Windows 8.1 Pro 64-bit Licence
- 17.9 cm
- 18.2 cm
- 3.45 cm
- 1.98 kg
C2G 2m DisplayPort Male to Single Link DVI-D Male Adapter Cable | In Stock | £32.58 |
C2G 3m DisplayPort Cable with Latches M/M - Black | In Stock | £12.82 |
