Dependable and productive, M Series SFFs are a blessing for any IT team. These industry-leading business machines are compact, stable, and manageable, making them the perfect solution for any corporate rollout. Powerful and secure, ThinkCentre M Series small form factor desktops are designed to boost your productivity while saving you much-needed time, effort, and desk space. With advanced security features and easy-to-use management tools as standard, they can be configured with the right components to suit your needs now and can be easily expanded as your business grows. From high-end graphic design and intense data crunching to multimedia-rich presentations, ThinkCentre M Series PCs can handle whatever you throw at them. And still come back for more. Ultrafast and ultra-responsive, they help you get things done quicker than before so that you can focus on the things that really matter, like running a successful business.
Compact yet powerful enterprise desktops
Dependable and productive, M Series SFFs are a blessing for any IT team. These industry-leading business machines are compact, stable, and manageable, making them the perfect solution for any corporate rollout. -
Designed for productivity and the future
Powerful and secure, ThinkCentre M Series small form factor desktops are designed to boost your productivity while saving you much-needed time, effort, and desk space. With advanced security features and easy-to-use management tools as standard, they can be configured with the right components to suit your needs now and can be easily expanded as your business grows. -
Make light work of tight deadlines
- Lenovo ThinkCentre M75s-1 - SFF - Ryzen 5 Pro 3400G 3.7 GHz - 8 GB - SSD 256 GB - UK
- Personal computer - small form factor
- Localisation
- Processor
- AMD Ryzen 5 Pro 3400G / 3.7 GHz (, up to 4.2 GHz, (Quad-Core)
- Cache Memory
- 4 MB L3 Cache
- Cache Per Processor
- 4 MB
- RAM
- 8 GB (installed) / 64 GB (max) - DDR4 SDRAM - non-ECC
- Storage Controller
- SATA (SATA 6Gb/s)
- Hard Drive
- SSD 256 GB - PCI Express 3.0 x4 - M.2 2280 - TCG Opal Encryption, NVM Express (NVMe)
- Optical Storage
- DVD-Writer
- Card Reader
- 7 in 1
- Graphics Controller
- AMD Radeon Vega 11
- Networking
- GigE
- Keyboard
- UK
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Windows 10 Pro 64-bit Edition
- Software Included
- Microsoft Office (Trial)
- Black
- 9.25 cm x 29.05 cm x 34.35 cm
- 6 kg
- Manufacturer Selling Program
- TopSeller
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - 3 years - on-site
- Personal computer
- Product Form Factor
- Small form factor
- Built-in Devices
- Speaker
- Embedded Security
- Trusted Platform Module (TPM 2.0) Security Chip
- Black
- Localisation
Processor / Chipset
- CPU
- Clock Speed
- 3.7 GHz
- Max Turbo Speed
- 4.2 GHz
- Number of Cores
- Quad-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- L2 cache
- 2 MB
- Chipset Type
- AMD PRO 560 FCH
Cache Memory
- Installed Size
- L3 Cache - 4 MB
- 4 MB
RAM
- Installed Size
- 8 GB / 64 GB (max)
- Technology
- Effective Memory Speed
- 2666 MHz
- Rated Memory Speed
- 2666 MHz
- Form Factor
- DIMM 288-pin
- Slots
- 4 (Total) / 3 (empty)
- Unbuffered, dual channel memory architecture
- Configuration Features
- 1 x 8 GB
Hard Drive
- SSD - M.2 2280
- Capacity
- 1 x 256 GB
- Interface Type
Storage Controller
- 1 x SATA
- Controller Interface Type
- SATA 6Gb/s
- Channel Qty
- 3
- RAID Level
- RAID 0, RAID 1
Optical Storage
- DVD-Writer - SATA
Card Reader
- 7 in 1 card reader
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- Video Interfaces
- VGA, DisplayPort
- Max Monitors Supported
- 3
Audio Output
- High Definition Audio
Input Device
- Mouse, keyboard
Keyboard
- Interface
- USB
- Localization & Layout
- UK
Mouse
- Mouse Name
- Lenovo Calliope Mouse
- Interface
- USB
- Ethernet Controller
- Realtek RTL8111EPV
- Data Link Protocol
- Wake on LAN (WoL)
- DASH 1.1
- Bays
- 1 (total) / 0 (free) x external 5.25" Slim Line , 1 (total) / 1 (free) x internal 3.5"
- Slots
- 1 (total) / 1 (free) x PCIe 3.0 x16 - low-profile , 2 (total) / 2 (free) x PCIe 2.0 x1 - low-profile , 1 (total) / 1 (free) x PCI - low-profile , 2 (total) / 1 (free) x M.2 Card
- 2 x USB 3.1 Gen 2 (2 in front) , 4 x USB 3.1 Gen 1 (2 front, 2 rear) (one of them supports SmartPower On) , 2 x microphone (1 front, 1 rear) , 1 x headphones (1 in front) , 2 x USB 2.0 , 1 x serial , 1 x LAN (Gigabit Ethernet) , 1 x VGA , 2 x DisplayPort , 1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x audio line-in , 1 x audio line-out
- Theft/Intrusion Protection
- Security lock slot (cable lock sold separately), padlock loop, chassis intrusion switch
- Security Slot Type
- Kensington security slot
- RoHS, WEEE, Energy-Related Products (ErP) Lot 3
- TopSeller
- Power supply
- Voltage Required
- Power Provided
- 180 Watt
- Efficiency
- 85%
Operating System / Software
- OS Provided
- Windows 10 Pro 64-bit Edition English
- Software
Sustainability Information
- ENERGY STAR Certified
- ENERGY STAR Version
- 7.0
- 9.25 cm
- 29.05 cm
- 34.35 cm
- 6 kg
Monitors (5)
Lenovo ThinkVision T24d 24" 1920x1080 VGA HDMI DisplayPort IPS LED Monitor | In Stock | £202.02 |
Lenovo ThinkVision T27p-10 27" 3840x2160 HDMI DisplayPort USB-C IPS LED Monitor | In Stock | £454.54 |
Lenovo ThinkVision P27h-20 27" 2560x1440 6ms HDMI DisplayPort IPS LED Monitor | In Stock | £336.70 |
Lenovo ThinkVision T27q-20 27" 2560x1440 4ms HDMI DisplayPort IPS LED Monitor | In Stock | £321.24 |
Lenovo Tiny-in-One 22 21.5" 1920 x 1080 14ms Full HD LED monitor | In Stock | £246.91 |
Keyboards and Mice (3)
Lenovo Professional Wireless Keyboard | In Stock | £53.47 |
Lenovo Essential Wired Keyboard and Mouse Combo - UK English | In Stock | £25.39 |
Lenovo ThinkPad Bluetooth Silent Mouse - Right and Left-handed | In Stock | £23.88 |
Other bundles (9)
Lenovo ThinkPad USB3.0 to Ethernet Adapter | In Stock | £16.07 |
Kensington Security Cable Lock | In Stock | £23.65 |
APC BACK-UPS BE650G2-UK 650VA 230V | In Stock | £99.31 |
APC BACK-UPS BE850G2-UK 850VA 230V USB | In Stock | £110.10 |
APC BACK UPS PRO BR650MI 650VA 6 Outlets | In Stock | £140.55 |
APC BACK UPS PRO BR900MI 900VA 6 Outlets | In Stock | £195.26 |
Lenovo 100 Headset on ear wired - USB black for IdeaPad 3 ThinkCe | In Stock | £34.84 |
APC BACK-UPS CS 325VA 230V | In Stock | £70.14 |
Lenovo Thinkvision MC50 Monitor Webcam | In Stock | £54.13 |
