Lenovo ThinkCentre M75q-1 11A4 - Tiny - Ryzen 5 Pro 3400GE / 3.3 GHz - RAM 8 GB - SSD 256 GB - TCG Opal Encryption, NVMe - Radeon Vega 11 - GigE, Bluetooth 5.0 - WLAN: 802.11ac, Bluetooth 5.0 - Win 10 Pro 64-bit - monitor: none - keyboard: UK
IT admin's dream
With the ThinkCentre M715 Tiny, you can create your own modular all-in-one PC. Insert the Tiny inside the back of the optional ThinkCentre Tiny-in-One (TIO). Keep costs down by choosing to upgrade components separately, and get more use from your assets over time. -
Packs a big punch
The ThinkCentre M715 Tiny powers on through convenient keyboard controls to get you up and running almost instantly. The PCIe SSD storage coupled with 3D NAND technology allows you to seamlessly switch between tasks, and handle large files and applications with ease. Its fast-charging USB port enables quick charging and data transmission even when your PC is off. -
Big on security
The ThinkCentre M715 Tiny is optimized for protection and security. Armed with the Trusted Platform Module (TPM), this PC encrypts all your data, as well as your passwords. What's more, Smart USB Protection lets you control what devices can connect so you can prevent any data leaks. With the ThinkCentre M715 Tiny, you can keep all your confidential and critical data safe without worry. -
Tough as it is tiny
The ThinkCentre M715 Tiny is built to last in any environment. It's tested against military-specification requirements, as well as rigorous quality checks. From enduring arctic temperatures of -4 degrees Fahrenheit, to desert heat of 140 degrees F, this device can more than handle anything from minor bumps to extreme temperatures and dusty conditions.
- Lenovo ThinkCentre M75q-1 - tiny - Ryzen 5 Pro 3400GE 3.3 GHz - 8 GB - SSD 256 GB - UK
- Personal computer - tiny
- Localisation
- Processor
- AMD Ryzen 5 Pro 3400GE / 3.3 GHz (, up to 4 GHz, (Quad-Core)
- Cache Memory
- 4 MB L3 Cache
- Cache Per Processor
- 4 MB
- RAM
- 8 GB (installed) / 32 GB (max) - DDR4 SDRAM - non-ECC
- Storage Controller
- SATA (SATA 6Gb/s)
- Hard Drive
- SSD 256 GB - PCI Express 3.0 x4 - M.2 2280 - TCG Opal Encryption, NVM Express (NVMe)
- Optical Storage
- No optical drive
- Graphics Controller
- AMD Radeon Vega 11
- Networking
- GigE, 802.11a, 802.11b/g/n, Wi-Fi 5, Bluetooth 5.0
- Keyboard
- UK
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Windows 10 Pro 64-bit Edition
- Black
- 17.9 cm x 18.29 cm x 3.45 cm
- 1.32 kg
- Manufacturer Selling Program
- TopSeller
- Environmental Standards
- ENERGY STAR Qualified EPEAT Silver
- Limited warranty - 3 years - on-site
- Personal computer
- Product Form Factor
- Tiny
- Built-in Devices
- Speaker
- Embedded Security
- Trusted Platform Module (TPM 2.0) Security Chip
- Black
- Localisation
Processor / Chipset
- CPU
- Clock Speed
- 3.3 GHz
- Max Turbo Speed
- 4 GHz
- Number of Cores
- Quad-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- L2 cache
- 2 MB
- Chipset Type
- AMD B300
Cache Memory
- Installed Size
- L3 Cache - 4 MB
- 4 MB
RAM
- Installed Size
- 8 GB / 32 GB (max)
- Technology
- Effective Memory Speed
- 2666 MHz
- Rated Memory Speed
- 2666 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots
- 2 (Total) / 1 (empty)
- Dual channel memory architecture
- Configuration Features
- 1 x 8 GB
Hard Drive
- SSD - M.2 2280
- Capacity
- 1 x 256 GB
- Interface Type
Storage Controller
- 1 x SATA
- Controller Interface Type
- SATA 6Gb/s
- Channel Qty
- 1
Optical Storage
- No optical drive
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- Video Interfaces
- HDMI, DisplayPort
Audio Output
- High Definition Audio
Input Device
- Mouse, keyboard
Keyboard
- Interface
- USB
- Localization & Layout
- UK
Mouse
- Mouse Name
- Lenovo Calliope Mouse
- Interface
- USB
- Ethernet Controller
- Realtek RTL8111EPV-CG
- Wireless LAN Supported
- Wireless NIC
- Realtek RTL8822CE
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 5.0
- Wake on LAN (WoL)
- DASH 1.1
- Bays
- 1 (total) / 1 (free) x internal 2.5"
- Slots
- 2 (total) / 0 (free) x M.2 Card
- 2 x USB 3.1 Gen 1 (1 front, 1 rear) (one of them is Always On and fast-charging) , 1 x USB-C 3.1 Gen 1 (1 in front) , 1 x microphone (1 in front) , 1 x headphones/microphone (1 in front) , 3 x USB 2.0 , 1 x LAN (Gigabit Ethernet) , 2 x DisplayPort , 1 x HDMI
- Included Accessories
- VESA mounting kit, adapter cage
- Theft/Intrusion Protection
- Security lock slot (cable lock sold separately), chassis intrusion switch, tool-less chassis access
- Security Slot Type
- Kensington security slot
- VESA Mounting Interface
- 100 x 100 mm, 75 x 75 mm
- RoHS, Energy-Related Products (ErP) Lot 3
- TopSeller
- Power adapter
- Voltage Required
- Power Provided
- 65 Watt
- Efficiency
- 88%
Operating System / Software
- OS Provided
- Windows 10 Pro 64-bit Edition English
Sustainability Information
- EPEAT Compliant
- EPEAT Silver
- ENERGY STAR Certified
- ENERGY STAR Version
- 7.1
- 17.9 cm
- 18.29 cm
- 3.45 cm
- 1.32 kg
Monitors (3)
Lenovo ThinkVision T24d 24" 1920x1080 VGA HDMI DisplayPort IPS LED Monitor | In Stock | £202.02 |
Lenovo ThinkVision T27p-10 27" 3840x2160 HDMI DisplayPort USB-C IPS LED Monitor | In Stock | £454.54 |
Lenovo ThinkVision P27h-20 27" 2560x1440 6ms HDMI DisplayPort IPS LED Monitor | In Stock | £336.70 |
Keyboards and Mice (3)
Lenovo Essential Wireless Keyboard and Mouse Combo - UK English 166 | In Stock | £41.29 |
Lenovo Professional Wireless Keyboard | In Stock | £53.47 |
Lenovo Essential Wired Keyboard and Mouse Combo - UK English | In Stock | £25.39 |
Other bundles (6)
Lenovo ThinkPad USB 3.0 Secure HDD-500GB | In Stock | £143.11 |
Lenovo HDMI to VGA Monitor Adapter | In Stock | £23.20 |
Lenovo USB3.0 To VGA/HDMI Adapter | In Stock | £63.85 |
Lenovo 2m HDMI Cable | In Stock | £17.02 |
Lenovo ThinkPad USB3.0 to Ethernet Adapter | In Stock | £16.07 |
Kensington Security Cable Lock | In Stock | £23.65 |
