Amazingly compact, astonishingly powerful
Built for productivity, the incredibly powerful ThinkCentre M75q Tiny packs a lot into its compact 1L chassis. High-performance AMD Ryzen™ PRO processing with lightning-quick memory and storage, plus rich Radeon™ Vega graphics, enables any task to be tackled with ease. What’s more, it’s so small that it doesn’t have to live on a desk, freeing up much-needed space. A big win for clutter-free thinking.
It’s what's inside that counts
ThinkCentre M75q Tiny may be compact but it’s built for productivity and speed. Packed with seamless AMD Ryzen™ 5 Pro processing, advanced DDR4 memory, ultra-fast PCIe SSD storage with 3D NAND technology, and powerful Radeon™ Vega graphics, it’s ready to tackle any task.
One well connected PC
With the M75q Tiny, all the input/output bases are covered—from audio to USB and video. The roster of ports includes a DisplayPort™ and full-function USB Type-C for power, display, and data—enabling fast, easy connectivity to other devices.
Because security counts
To help minimize cyber security attacks, such as malware and phishing, every M75q Tiny comes with AMD GuardMI Technology. This dedicated on-chip security approach provides system-level protection against various cyber threats and helps to safeguard your sensitive data.
Go ahead, reclaim your desk
With the M75q Tiny, you also get back some much-needed desk-space. Just 1L in volume, this sleek desktop can be securely deployed almost anywhere—mounted on the wall, under a desk, or behind a monitor.
A lean, mean, & green machine
MIL-SPEC tested for durability and reliability, the M75q Tiny can be counted on to perform in the most extreme conditions. What’s more, its energy efficiency and green certifications, such as Energy® Star 7.0, will result in lower utility bills for your business.
How do you keep an IT manager happy?
With features like the Trusted Platform Module (TPM) and Smart USB Protection to encrypt and help safeguard data. In addition, the M75q Tiny comes with DASH Manageability and Smart Power On, delivering a more flexible way to manage client systems and remote devices.
IT admin's dream
With the ThinkCentre M715 Tiny, you can create your own modular all-in-one PC. Insert the Tiny inside the back of the optional ThinkCentre Tiny-in-One (TIO). Keep costs down by choosing to upgrade components separately, and get more use from your assets over time. -
Packs a big punch
The ThinkCentre M715 Tiny powers on through convenient keyboard controls to get you up and running almost instantly. The PCIe SSD storage coupled with 3D NAND technology allows you to seamlessly switch between tasks, and handle large files and applications with ease. Its fast-charging USB port enables quick charging and data transmission even when your PC is off. -
Big on security
The ThinkCentre M715 Tiny is optimized for protection and security. Armed with the Trusted Platform Module (TPM), this PC encrypts all your data, as well as your passwords. What's more, Smart USB Protection lets you control what devices can connect so you can prevent any data leaks. With the ThinkCentre M715 Tiny, you can keep all your confidential and critical data safe without worry. -
Tough as it is tiny
The ThinkCentre M715 Tiny is built to last in any environment. It's tested against military-specification requirements, as well as rigorous quality checks. From enduring arctic temperatures of -4 degrees Fahrenheit, to desert heat of 140 degrees F, this device can more than handle anything from minor bumps to extreme temperatures and dusty conditions.
- Lenovo ThinkCentre M75q-1 - tiny Ryzen 3 Pro 3200GE 3.3 GHz - 8 GB - SSD 256 GB - UK
- Personal computer - tiny
- Localisation
- Processor
- AMD Ryzen 3 Pro 3200GE / 3.3 GHz (up to 3.8 GHz, (Quad-Core)
- Cache Memory
- 4 MB L3 Cache
- Cache Per Processor
- 4 MB
- RAM
- 8 GB (installed) / 32 GB (max) - DDR4 SDRAM - non-ECC
- Storage Controller
- SATA (SATA 6Gb/s)
- Hard Drive
- SSD 256 GB - PCI Express 3.0 x4 - M.2 2280 - TCG Opal Encryption, NVM Express (NVMe)
- Optical Storage
- No optical drive
- Graphics Controller
- AMD Radeon Vega 8
- Networking
- 1GbE, 802.11a, 802.11b/g/n, Wi-Fi 5, Bluetooth 5.0
- Keyboard
- UK
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Windows 10 Pro 64-bit Edition
- Black
- 17.9 cm x 18.29 cm x 3.45 cm
- 1.32 kg
- Manufacturer Selling Program
- Lenovo TopSeller
- Environmental Standards
- ENERGY STAR Qualified EPEAT Silver
- Limited warranty - 3 years - on-site
- Personal computer
- Product Form Factor
- Tiny
- Built-in Devices
- Speaker
- Embedded Security
- Trusted Platform Module (TPM 2.0) Security Chip
- Black
- Localisation
Processor / Chipset
- CPU
- Clock Speed
- 3.3 GHz
- Max Turbo Speed
- 3.8 GHz
- Number of Cores
- Quad-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- L2 cache
- 2 MB
- Chipset Type
- AMD B300
Cache Memory
- Installed Size
- L3 Cache - 4 MB
- 4 MB
RAM
- Installed Size
- Technology
- Effective Memory Speed
- 2666 MHz
- Rated Memory Speed
- 1333 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots
- 2 (Total) / 1 (empty)
- Dual channel memory architecture
- Configuration Features
- 1 x 8 GB
Hard Drive
- SSD - M.2 2280
- Capacity
- 1 x 256 GB
- Interface Type
Storage Controller
- 1 x SATA
- Controller Interface Type
- SATA 6Gb/s
- Channel Qty
- 1
Optical Storage
- No optical drive
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- AMD Radeon Vega 8
- Video Interfaces
- HDMI, DisplayPort
Audio Output
- High Definition Audio
Input Device
- Mouse, keyboard
Keyboard
- Interface
- USB
- Localization & Layout
- UK
Mouse
- Mouse Name
- Lenovo Calliope Mouse
- Interface
- USB
- Ethernet Controller
- Realtek RTL8111EPV-CG
- Wireless LAN Supported
- Wireless NIC
- Realtek RTL8822CE
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 5.0
- Wake on LAN (WoL), dual stream (2x2)
- DASH 1.1
- Bays
- 1 (total) / 1 (free) x internal 2.5"
- Slots
- 2 (total) / 0 (free) x M.2 Card
- 2 x USB 3.1 Gen 1 (1 front, 1 rear) (one of them is Always On and fast-charging) , 1 x USB-C 3.1 Gen 1 (1 in front) , 1 x microphone (1 in front) , 1 x headphones/microphone (1 in front) , 3 x USB 2.0 , 1 x LAN (Gigabit Ethernet) , 2 x DisplayPort , 1 x HDMI
- Included Accessories
- VESA mounting kit, adapter cage
- Theft/Intrusion Protection
- Security lock slot (cable lock sold separately), chassis intrusion switch, tool-less chassis access
- Security Slot Type
- Kensington security slot
- VESA Mounting Interface
- 100 x 100 mm, 75 x 75 mm
- RoHS, Energy-Related Products (ErP) Lot 3
- Lenovo TopSeller
- Power adapter
- Voltage Required
- Power Provided
- 65 Watt
- Efficiency
- 88%
Operating System / Software
- OS Provided
- Windows 10 Pro 64-bit Edition English
Sustainability Information
- EPEAT Compliant
- EPEAT Silver
- ENERGY STAR Certified
- ENERGY STAR Version
- 7.1
- 17.9 cm
- 18.29 cm
- 3.45 cm
- 1.32 kg
Lenovo DisplayPort Adapter - DisplayPort (M) to DisplayPort (F) | In Stock | £66.79 |
Lenovo HDMI to VGA Monitor Adapter | In Stock | £22.98 |
Lenovo 2m HDMI Cable | In Stock | £17.20 |
Lenovo ThinkPad USB3.0 to Ethernet Adapter | In Stock | £16.01 |
Kensington Security Cable Lock | In Stock | £23.92 |
APC BACK-UPS BE650G2-UK 650VA 230V | In Stock | £108.75 |
APC BACK-UPS BE850G2-UK 850VA 230V USB | In Stock | £120.84 |
APC BACK UPS PRO BR650MI 650VA 6 Outlets | In Stock | £151.07 |
APC BACK UPS PRO BR900MI 900VA 6 Outlets | In Stock | £208.36 |
