Lenovo Thinkcentre M73 Intel Core i5-4460 4GB 500GB Windows 7 Pro
Quicklinx: BPSQWS00 Mfr#: 10B5000XUK
  • Core i5
  • Microsoft Windows 7 Professional 64-bit Edition
For large enterprise(EDU/GOV/PUB etc.) with a need for an essential desktop PC, the ThinkCentre M73 provides the latest Intel technology at a competitive price without sacrificing security, stability, manageability, and green environment.
  • Small form factor
    The small form factor (SFF) desktop is designed to fit into tight spaces - supporting both horizontal and vertical orientations.
  • Platform stability
    The M73 desktop features Intel Stable Image Platform Program (SIPP), providing stability for long-term deployments to help reduce transition, qualification, and testing costs, ensuring savings for your business.
  • Hyper-fast wireless experience
    The advanced antenna design provides better signal reception and faster performance from your wireless connection.
  • PC Cloud Manager 2
    Keep your PC fleet healthy and green as you effortlessly monitor and manage your desktop's health and power consumption.
  • Lenovo Solution Center
    Lenovo Solution Center provides access to a simplified dashboard that reflects total system health. This hardware diagnostic tool allows quick access to frequently used system management tools, including backup and restore, antivirus and firewall settings, system/software updates, Internet connections, and service and support. Drastically speed migration time with ThinkVantage System Migration Assistant. Spend less time manually searching for drivers and software updates with ThinkVantage System Update.
  • Fast data transfer
    Move data between the M73 and other devices quickly with USB 3.0 - it's faster than previous USB technologies, and is backward-compatible.
  • Green leadership
    Certifications like ENERGY STAR 5.2, EPEAT Gold, and UL Environment Gold mean you'll save money with a more energy-efficient PC. Plus, you can use Desktop Power Manager to customize your power settings and balance power consumption with system performance, helping the planet and your bottom line.
Lenovo ThinkCentre M73 - SFF - Core i5 4460 3.2 GHz - 4 GB - HDD 500 GB - UK
Personal computer - small form factor - administrator password, hard drive password, power-on password, boot without keyboard or mouse, serial port I/O control, USB port control, boot sequence control
Intel Core i5 (4th Gen) 4460 / 3.2 GHz (, up to 3.4 GHz, (Quad-Core)
Processor Socket
LGA1150 Socket
Processor Main Features
Intel Turbo Boost Technology 2
Cache Memory
6 MB
Cache Per Processor
6 MB
RAM
4 GB (installed) / 16 GB (max) - DDR3 SDRAM - PC3-12800
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
HDD 500 GB - SATA 6Gb/s - 7200 rpm
Optical Storage
DVD-Writer
Graphics Controller
Intel HD Graphics 4600
Audio Output
Stereo
GigE
Keyboard
OS Provided
Business black
33.5 cm x 38.2 cm x 10.1 cm
6.6 kg
Environmental Standards
ENERGY STAR Qualified
Limited warranty - 1 year - on-site
Personal computer
Product Form Factor
Small form factor
Built-in Devices
Speaker
Business black
Processor / Chipset
CPU
Clock Speed
3.2 GHz
Max Turbo Speed
3.4 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
CPU Socket
LGA1150 Socket
Chipset Type
Intel H81
Cache Memory
Installed Size
6 MB
Cache Per Processor
6 MB
RAM
Installed Size
4 GB / 16 GB (max)
DDR3 SDRAM
Effective Memory Speed
1600 MHz
Rated Memory Speed
1600 MHz
Memory Specification Compliance
PC3-12800
DIMM 240-pin
Slots
2 (Total) / 1 (empty)
Unbuffered
Configuration Features
1 x 4 GB
Hard Drive
HDD
1 x 500 GB
Interface Type
SATA 6Gb/s
Spindle Speed
7200 rpm
Storage Controller
1 x SATA
Controller Interface Type
SATA 6Gb/s
Optical Storage
DVD-Writer - SATA
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Video Interfaces
VGA, DisplayPort
Max Monitors Supported
2
Audio Output
Sound Output Mode
Stereo
High Definition Audio
Input Device
Mouse, keyboard
Keyboard
Keyboard Name
Preferred Pro USB
USB
Localization & Layout
Mouse
Optical
USB
Ethernet Controller
Realtek RTL8111GN
Wake on LAN (WoL)
Bays
1 (total) / 0 (free) x external 5.25" x 1/2H , 1 (total) / 0 (free) x internal 3.5" x 1/3H
Slots
2 (total) / 1 (free) x DIMM 240-pin , 1 (total) / 0 (free) x CPU , 1 (total) / 1 (free) x PCIe 3.0 x16 - low-profile , 2 (total) / 2 (free) x PCIe 2.0 x1 - low-profile
4 x USB 2.0 (2 front, 2 rear) , 2 x microphone (1 front, 1 rear) , 1 x headphones (1 in front) , 2 x USB 3.0 , 1 x serial , 1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x LAN (Gigabit Ethernet) , 1 x VGA , 1 x DisplayPort , 1 x audio line-in , 1 x audio line-out
Administrator password, hard drive password, power-on password, boot without keyboard or mouse, serial port I/O control, USB port control, boot sequence control
Theft/Intrusion Protection
Security lock slot (cable lock sold separately), padlock loop
Security Slot Type
Kensington security slot
RoHS, GREENGUARD
Power supply
Power Provided
240 Watt
Operating System / Software
OS Provided
Sustainability Information
ENERGY STAR Certified
33.5 cm
38.2 cm
10.1 cm
6.6 kg
BPSQ C2G 3m DisplayPort Cable with Latches M/M - Black In Stock £13.17
